Question about Panasonic VIERA TH-C50FD18 50 in. Plasma HDTV
I tried to change a channel and the screen went totally green - still have volume but no picture
  • Panasonic Master
  • 8,457 Answers
Ur backligt video board is dead,need it to be replaced.
Posted on Oct 02, 2009
  • cherrylane18 Mar 14, 2011
    Not always. I turned off the power supply to everything and the TV came back on fine. It's been ok for several hours. We'll see if it happens again.
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
Tv screen has turned blue and I can't watch tv
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
Jan 21, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Jul 28, 2008 | LG 42LC7D-UB Television
Screen went BLACK!
My Sony FD Trinitron TV did samething, started flashing, then eventually went completely black with volume. I got on internet searched found a solution, i tried it, it worked. unplug tv, remove all screws, remove back. towards bottom right theres a transmitter with a couple of knobs, we plugged tv in and moved knobs around and it worked. Also was extremally dusty, we used computer duster for a better connection. hope it helps you
Jan 26, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
After 2 years of use, screen on TV went to white but sounds still works
Hi Sounds to me like the Tuner Module went out, this is something a qualified technician would have to fix.
Mar 08, 2007 | Apex Digital PF2720 27" TV
Open Questions:
See all Panasonic VIERA TH-C50FD18 50 in. Plasma HDTV Questions
Panasonic VIERA TH-C50FD18 50 in. Plasma HDTV Logo
230 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
