Question about Fantom Vacums Cyclone XT Upright Vacuum
My Fantom Vacum Cyclone et was smoking and smelled of rubber burning. I'm sure it is the belt but I don't know how to get into the vacuum to see the belt.
  • 555 Answers
To replace the belt, Remove the covers over the headlights and under the shiny foul. there are two screws. (In other words: Remove the lens covers, bulbs and the foil. under the foil are two screws.)
Then, there are two tabs that hold down the cover over the wheels, they just pop on/off with a click. Now the belt should be exposed and can be replaced.
You may also need to clean the rolling brush to avoid damages to the new band. To remove the rolling brush and clean out all the hair that was stuck in the bearings, just remove the screw holding down the motor and belt. pry out the roller brush to get to the bearings.
Hope it helps, good luck!
Posted on Oct 02, 2009
I took the vacuum apart and cleaned it. Now there is an odor coming from the round filter and the vacuum is not picking anything up.
  • hi there
  • Does the odor smell like burnt rubber....if so you may have burned out the belt which is common. The filter can smell if you have pets and the machine will blow the odor back in to the room after the filter gets older.Check to see that the roller brush is spinning when it is turned on if not shut it off and try to turn it manually with your hands. If it turns very easily the belt gone if it is almost impossible to turn you need a new roller brush.You can replace the filter to help with the smell but if it is the belt you smell it will go away in time. Also make sure that you have the container on perfectly as if it is not it will not create a perfect seal and you will have very little suction. The other thing you can check is the hose to see if the suction is good through it. If the hose has good suction then the power head may be plugged with something and you will need to get a screwdriver and take the bottom plate off the same way as if you were changing the belt and then you can look for a blockage as well as access the belt and roller brush. I hope this was helpful to you ...good luck
Oct 13, 2010 | Fantom Vacums Cyclone XT Upright Vacuum
We replaced the belt after about 5 uses, and now every once in a while it smells like burning rubber, I checked to belt to make sure it was ok, and then last week it started smoking. Is there reported...
If the belt is hot or burning during use, it could be due to a beater brush, which the belt drives, being bound up in some manner. The beater brush is removed during belt changes and should be cleaned of all debris as best you can. At each end of the beater brush there is a plastic clip of sorts that holds it in the vacuum. Spray some WD40 between the bar and the plastic clips then rotate the clips to be sure they move freely. Reassemble with a new belt and put it to use.
If you find this solution to be of help to you I would appreciate a Thumbs UP rating. Paul
Oct 09, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
Changed belt in my vacum and it is now smoking and i smell burnt rubber
Check the brush and make sure that it seated correctly...between pulling on the new belt and getting the brush back into the slots sometimes it will bind up...
You also will now want to put a new belt in now... the belt is toast if it smoked...
heatman101
Sep 01, 2010 | Eureka 4467AV Upright Vacuum
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
I am trying to get to the belt on my fantom cyclone xt, although I am unable to see any screws to remove. I took the rubber bumper off thinking this would be of some help although nothing there either. Can...
remove the lens covers, bulbs and the foil. under the foil are two screws. remove the screws and the cover lifts off. the motor for the belt is held in with one screw.
Jan 03, 2009 | Fantom Vacums Cyclone XT Upright Vacuum
Fantom cyclone xt
Go Fantom Vac site ,type in model #.A PDF
booklet will describe it.
Aug 20, 2008 | Fantom Vacums XT450K Upright Vacuum
Circuit board
You should be able to locate parts for your vacum at this link by entering the model number.
http://www.fantom.com/fantom/default.aspx
Mar 25, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Fantom Vacums Cyclone XT Upright Vacuum Logo
78 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
