Question about Saws
I am replacing power switch on ryobi table saw BTS20R
I am replacing power wwitch on ryobi table saw model bts20r. what do the two white wires on the switch control?
Hi, I have got a Ryobi ETS-1525SC Table Saw. Suddently it stop and as far as I can see the machine is ok but the blad is not moving. Could some one help please
Posted on Dec 16, 2009
  • 2,176 Answers
I don't like the Ryobi site, I can't find anything so you will have to call them direct at 1-800-525-2579 and have them send you the print in a PDF file. Good luck
Posted on Oct 02, 2009
  • DougDeinal May 31, 2016
    I am wanting to know how hatd it is to replace on/off switch on Ryobi 10"portable table saw? Doug in maine
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
WHEN I USED OLD TABLE SAW WITH UNGROUNDED POWER CORD. I ALSO HAD JIG SAW PLUGGED INTO SAME OUTLET. wHEN I LAID THE JIG SAW ON THE TABLE SAW IT SPARKED AND THE MOTOR ON THE POWER SAW DOESNT WORK. NEX
If you're lucky, there's a circuit breaker built into the table saw motor and a little red button somewhere on the motor to reset it.
When you re-wire it. know that the cord should have a black wire (hot), a white wire (neutral), and a green wire (ground).
When you wire the power cord to the switch, the black wire should be the one that goes directly to the switch contacts and gets disconnected when you turn off the switch. The white wire goes through the rest of the system up to the motor. The green wire grounds out the metal parts that you might touch.
If you have to replace the motor, get a 3450 rpm to 3600 rpm motor. Harbor Freight has one for about $140 before any discount.
I recommend at least 1.5 HP
Sep 16, 2014 | Saws
Wire diagram for craftsman 10" table saw
Hi there.
Prior to plug it try this.From your 3 prong grounded plug trace it up to your saw were you should have a black and a white from the same wire's end.Now the two whites are probably from the reset that you haven't replaced?Write back to let me know if this is right and I'll proceed.
Jul 25, 2013 | Craftsman 10" Table Saw
Need a wiring diagram for ryobi ets 1525 table saw switch
http://www.motoruf.de/n/ersatzteillisten.html?id=657306
This is as much as I'm able to find regarding the breakdown and wiring. Sorry I cant seem to fins anything more detailed.
Apr 05, 2013 | Ryobi Table Saw Manual
I received a new on/off switch for my Ryobi BT3100 table saw. Does anyone know the wire config to hook it up? There's 2 white and 2 black wires. Thanks.
The white wires go on one side of the switch and the black wires go on the other side of the switch.
Keith (at) BT3000.com
Jun 01, 2011 | Garden
Need advice on installing new switch on my Ryobi BTS20r 1 table saw
What kind of help do you need? I'll see if I can answer your questions.
Handie Andie
Mar 31, 2011 | Garden
Bosch 4000 table saw will not start. I changed the switch and still won't start, not even a sound. The saw is relatively new, and the outlet works. What should I try next?
A real Weakness of this saw is sawdust and debri entering the cooling ports of the motor causing intermittent contact of brushes which damages the motor speed control board ($40.00). Don't ever operate this saw with out a vacuum saw dust extraction system. Also when you replace the Speed control board also replace the Brushes ($6.00). It helps extend the operational life of the motor components to blow out the contaminants regularly with compressed air through the motor cooling ports (turn off saw first).
You can bypass the speed control board (if you want to disable this wonderful engineering feature by attaching black and white power wires directly to the black and white wires to motor.
Feb 22, 2010 | Bosch 4000 - 07 Electric Table Saws
Ryobi 10 in Portable Table Saw modl #BTS12S won't turn on
Look for a trip switch on the saw motor
Nov 02, 2009 | Saws
I have Ryobi 10
Your can download a fresh copy by clicking RIGHT HERE. Just click the "get manual " button and you'll get a fresh pdf copy. an adobe acrobat file.
Sep 02, 2009 | Saws
Hi i need to rewire my ryobi table saw switch thanx lee
What I do is to take a photo of the wiring and effected area so I can refer to it when I get lost. Just replace each wire one at a time from the old switch to the new. Good luck
May 05, 2009 | Hitachi 10", Table Saw with Stand,...
Saws Logo
1,563 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
