Question about Kenmore Elite Oasis 27052 Top Load Washer
The washer will fill then it will stop but will not start to wash, it will stay 49 minutes on the timer but will then start drain and go back 50 minutes and start the same process again and again!!!
  • warrenkimhil Oct 02, 2009
    THE UNIT IS NOW FLASHING F THEN THE # 51
  • 10,515 Answers
F 51 - Uh, ho.
This machine has what they call a RPS sensor . It sits down on the stator motor and monitors how fast the machine is spinning. Right now it is not sensing and needs to be replaced.
Once replaced, the code would not appear.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Do accept the solution, if 100% satisfied from my service!!
Posted on Oct 02, 2009
    President:
  • 2,923 Answers
When the washer will fill but nothing else the most likely cause would be the lid switch.
On this washer if the lid switch is defective it will not agitate or spin at all. The motor will not run with an open lid switch.
Another problem could be the pressure switch not closing the violet to pink wire to allow agitation.
You may test the lid switch by bypassing it. You may remove the cover from the back or top of the washer and you will see the switch where the lid is under the top. Remove the wire connector and jump it across with another wire. If the washer works, then the problem is the lid switch.
If you are having a trouble accessing the lid switch, contact a tech person to test it for you. Lid switch is not expensive and you should not spend too much money just for replacing it.
Have a great day!
My GE washer WM0642H is not going through the entire wash cycle. It will be at the second cycle of the wash and the timer will say 49 minutes. The washer pauses for a couple minutes and jumps to the r
Hello Jacqueline;
My name is Peter. I am a retired field service appliance technician.
The model number you have given is for a LG washer.
Anyway, you have a draining problem. FE = Fill Error. Your washer will not fill if it has not drained.
To fix the issue you will have to remove both the washer top and front cover to access the problem components.
Before the start of any work disconnect the washer power!
1.) Pump & or Pump housing is plugged up.
You will need to remove and clean these components:
Part Number 4681EA2001D - $57.00
On this component to check if the pump has failed you will need a multi-meter. Set the meter on the lowest Ohms. Disconnect the wire leads to the pump. Put one meter lead on one pump contact and the other lead on the other contact. If the pump is good the meter should read '0'. Perform this after cleaning.
Clean the pump housing
Check the drain switch.
Part number 6600FA1704X - $24.00
You will need a multi-meter as described above to check this component.
Hopefully, you are just plugged up.
Nov 30, 2014 | GE Washing Machines
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
My Miele W1119 washer won't run. It was fine earlier today and I just completed a load of wash. When I started the next load on the Normal cycle, the timer lights to 58 minutes as always and the...
sounds like bushes mine done the same changed them now all good check it is not leaking water on to the bottom of machine this will activate the sensor to stop washing and drain water
Jun 04, 2017 | Miele Touchtronic W1119 Large Capacity...
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
    Soon as i set cycle and swich on door light flashes open
    hi,
    Thanks for your question.
    Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
    Washer wont stop draining
    hi. thanks for the question .does the drain hose go down a long pipe, to drain the water out. your drain hose must be 36 inches from the floor or it will fill & drain at the same time. check this. the appliance doc
    Sep 28, 2008 | GE WJSE3110A Top Load Washer
    Kenmore Elite Oasis 27052 Top Load Washer Logo
    43 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
