Question about Dean Guitars Dean Ml79 Electric Guitar
How do i plug my eletric guitar into an amp - Dean Guitars Dean Ml79 Electric Guitar
  • 4 Answers
Buy a cable plug it into input jack one of the guitar and one on the amp
Posted on Apr 08, 2010
    Problem Solver:
  • 10 Answers
A 1/4" cable is required, it's worth spending a little extra on a good one to stop any unwanted buzzing! Also, be sure your amp is OFF before you plug your guitar in...plugging your guitar in to a live amp can damage both the guitar and amplifier. When I started learning guitar I bought a maintenance guide from www.raeguitars.com
I seriously would recommend buying one...it'll save you a lot of time and money! :0) Enjoy!
Posted on Nov 30, 2009
  • 31 Answers
You can buy a 7 mm jack double ended lead to plug into the guitar and the amps input or just ask in a shop for a guitar lead its really that simple :)
Posted on Oct 21, 2009
  • Kyle Steven OHare
    Kyle Steven OHare Aug 26, 2014
    7mm? WTF are you talking about??
    Scholar:
  • 109 Answers
Connect a 1/4" instrument cable from the guitar's 1/4" jack to the amp's 1/4" input.
Posted on Oct 02, 2009
I turn on the amp plug in my guitar turn the volume up on the guitar and amp and no sound through amp
If it's a tube amp, it may be on Standby and needs to be switched to Play. It may also be a bad cord. Plug a different guitar into the system and eliminate at least that part.
Jan 18, 2017 | AMP Music
I have gotten an amp for my guitar..It worked fine the first 2 day...when I went back to it today...it was not working...could it be my guitar?
Hi Deb:
A couple of ways to check:
1) Plug your guitar into a different amp and see if it works.
2) Plug a different guitar into your amp and see if it works.
3) Try your guitar on your amp but use a different cord.
I'd be betting that the nearest music/instrument store would be quite happy to check your equipment for you, and most reasonably experienced musicians would likely volunteer to help. I know I would if you were my neighbor.
Cheers.
Dec 30, 2015 | Dean Guitars Music
Why is there no sound when I plug the guitar to the amp?
You first need to deterime where the problem is, in the amp or the guitar? Plug the guitar into another amp, and then another guitar into the amp. Also try a different cord. That will isolate were your problem actually is, then we can better help you.
Sep 02, 2015 | Fender Music
05050961, this guitar won't make any noise when plugged into the amp
First, plug something else into the amp with the same cord to make sure it's the guitar that's the problem. it's more commonly the cable, then the amp, then the guitar that goes dead. If it's indeed the guitar, check that the jack is wired correctly and that the jack contacts are gripping the plug. Next check the switch, then the individual pickups.
If you haven't done this before, you'll be time ahead to take it to the shop. Normally labor rates are minimal, and any decent tech can dianose the problem in short order.
Jun 15, 2015 | AMP Music
When I plug in my guitar to the Fender Frontman 64R Amp and I just barely move the cord, it make this really loud screeching type noise. It's not an old amp; I got it about five months ago. I can't...
Yes, there are several possibilities. First thing is to disconnect your guitar and then plug in the cord to the amp. Expect a bit of hum. If it screeches, then problem is not feedback via the guitar. If it doesn't MAYBE your guitar is "hearing the amp" which the guitar is then a microphone and can feedback. Moving the cable generates electrical noise which can trigger the feedback to start.
If you get the screech without the guitar connected, then TRY a new guitar cable. Make sure it is an INSTRUMENT cable... I have seen some try to use speaker cables or junky 1/4 inch cables intended for home stereo... these will NOT work and can cause the feedback. The next possibility is a broken jack on the amp. This would require repair. The common cause of this is to fail to run the cord through the handle of the amp... one trip on the cord or step on it pulling the plug sideways in the amp and the jack is broken and it is a trip to the shop as well. While on the subject ALWAYS run the cord at the guitar end either through the strap or your belt loop. Cords left dangling keep rotating and soon wear out the plug and also the jack in the guitar and then that has to go to the shop.
May 16, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
I plugged my guitar into the amp one day only to get no sound from the guitar. The amp is working - I plugged a different guitar in and it worked - but the guitar seems unresponsive.
If the guitar is active and the battery is dead you will not get any sound. If the output jack or some of the controlls have been twisted and may have broken the connections on the inside.
Feb 11, 2011 | Washburn Electric Guitars Modelno X11B
I have a gibson eletric guitar serial number K 9734628 and i cant find any information on it can you help
Here is the link you will need:http://www.gibson.com/Files/downloads/bluebook/GibsonSERIALNUMBERS.pdf also:http://home.provide.net/~cfh/gibson.html
Nov 08, 2010 | Gibson Acoustic J 185 Ec Acoustic Electric...
I've plugged my SX RST guitar into the SX GA-1065 amp but I can't get sound to come from the amp. I've made sure everything is plugged in and adjusted, but it still won't work. Why can't I get it to play?
Test the amp cable by plugging in the guitar cable an touching the end of the cord and you should get hum from the amp if the volume controls are up.
Many guitars require a battery to operate the preamp inside them.. Verify if yours needs a battery and it is fresh and properly installed.
These batteries are turned on by plugging in the guitar cable into the guitar. Leaving the cable in will exhaaust the battery, often within a day.
Sep 01, 2010 | Sx Guitars SX SST SE CAR + GA1065 STCAD...
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 | Music
Dean Guitars Dean Ml79 Electric Guitar Logo
325 people viewed this question
Top Dean Guitars Music Experts
Michial Gueffroy
Ted Maxwell
adam adms
adam adms
Are you a Dean Guitars Music Expert? Answer questions, earn points and help others
