Question about MSI K7N2 (MS-6570) Motherboard
I tried to overclock it
I tried to over clock the board with really knowing what I was doing. I'm running xp pro with two EIDE harddrives 30 and 40 gig. has a old video card and a 350 watt power supply. I set the bus speed to 200 and the multiplier to 7 (I know I know)... Anyway as soon as I saved the BIOS info the computer just shut off.. Now when I turn It back on It runs (power supply, hard drives) for about 5 seconds then shuts off.
I tried resetting the bios but its the same thing. I doesnt even stay on long enough to boot from a floppy..........Did I burn something???? Memory maybe?
  • Jeff Hibdon Dec 20, 2007
    sorry for the typos.. I ment to say with out know what I was doing
    the board is a MS-6570 K7N2 with an AMD athlon xp 2500 and is running Pc2100 256x2 512 total
Doesnt sound good - When you said you reset the bios that meant you reset the CMOS jumper on the mainboard?
If that doesnt do it then i would try just one stick of ram at a time.
You may even have burned up the CPU trying to overclock it so far. If you could find another athlon xp then i would try that last.
If that isnt practical then it is likely the mainboard is shot.
It would probably be best at that point to use this as an excuse to upgrade to a newer platform - an athlon x2 5600 with mainboard and RAM is only about $200-$250 depending on the combo you get. Keep in mind most newer boards will use PCI Express instead of AGP video cards.
Posted on Dec 20, 2007
How do I overclock the CPU of a HP ENVY 15-j028tx? I've searched on Google but haven't found any overclocking info... or much info at all about this model really. I don't want to mess with anything until...
Personally I never over clock my cpu it makes it run way to hot and lessons the lifespan greatly if you want more speed in your laptop get more RAM first I bet you will solve your slow pc concerns without PC damage.
Sep 29, 2013 | HP Computers & Internet
I looking for a pcb boad for hd western digital
That would be on another WD2500JB Caviar harddrive
Either that, or start looking on the internet posting -
WD2500JB PCB Board, and see what search hits come up.
Here,.....let me try.............
http://www.hdd-parts.com/18100096.html
Before you replace it, let me ask........
1) Was it in a Desktop PC?
2) Was it in an external harddrive?
External harddrive?
Then suggest you obtain a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3883498&CatId=2780
In an external harddrive there is a small interface circuit board.
The Harddrive plugs into the small interface circuit board, and the USB cable is attached to the small interface circuit board.
It is this small interface circuit board that usually goes bad.
The external enclosure is just like the case of the external harddrive.
Has a USB cable going to a small interface circuit board, and the harddrive plugs into it.
Regards,
joecoolvette
Mar 13, 2013 | Western Digital WD2500JB WD Caviar EIDE...
Just inherited a d410. runs XP pro. whats largest hdd I can upgrade to?
Disk-drives either have an EIDE interface or a SATA interface.
The largest EIDE disk-drive is 500 Gbytes.
SATA disk-drives can be much larger.
Check the manufacturer's web-site: http://support.dell.com
and select your model-number, and read the "specifications",
to determine whether you have an EIDE or a SATA disk-drive.
Oct 16, 2010 | Dell Latitude D410 Notebook
Mobo Compatibility and tech/spec variations
All Asus P5GC-MX/1333 mobos are "X-series" boards.
If you put higher speed ram on that mobo, it will just run the ram at lower speeds.
The board will not take 1333 speed DDR3, because it is only DDR2 compatible.
OVerclocking is complicated and risky, here is neither the place to teach or learn overclocking.
Some newer core 2 chips will automatically overclock, when all but 1 core is in hibernation (which will never happen if you are using vista). Other than that overclocking involves setting the bios to increase the memory buss speed, as well as slightly increasing the cpu and ram voltages as needed for stability. There is a great risk associated with manually overclocking and adjusting voltages, and should not be attempted by beginners on machines they value.
Dec 27, 2009 | ASUS P5GC-MX/1333 Motherboard
Overclocking
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Avid media composer with windows7
no need it will definitely work on windows 7. because it has xp mode that run all the xp compatible applications in windows 7. u know that windows 7 is really amzing.....
Aug 26, 2009 | Avid Xpress Pro 4.8.1 Full Version for PC,...
OverClocking Problem when startup my system
Most motherboards have settings that allow the board to try and overclock itself upon bootup. Take a look in your manual and it should lead you to the correct setting in the bios that will allow you to have the computer boot up in normal mode. Failing that, you may have to force the motherboard back to the default setup. There is a jumper you would have to move, then you would remove the battery from the motherboard. Check your manual for how to clear the CMOS settings if you need to do that step.
Jul 10, 2009 | Computers & Internet
Overclock
I do not condone overclocking!
You can try upgrading your bios to the latest version. It may let you change the CPU settings.
http://downloadcenter.intel.com/Fi [...] &strOSs=38
Intel boards are usually "locked" (BIOS), and are difficult if not impossible to overclock.
I DO NOT CONDONE OVERCLOCKING. IT CAN RUIN,TRASH, BREAK FOREVER, MAKE CEASE TO FUNCTION, if something goes wrong, not yelling at you just want to make sure you know what you are trying toget into.
But...They do sell boards designed for that purpose, I think you can get the board you have w/CPU for under $100. Look for a different board if you are serious about it.
Mar 29, 2009 | Intel PENTIUM E2200 LGA775 2.20G 1MB...
Windows XP SP2, Intel DG965WH mobo. Two SATA hard drives, two EIDE hard drives (WD200EB). Suddenly one day, without warning, the two EIDE drives just disappeared from the Hard Disk Drive list and files...
the problem sounds like you either lost the IDE channels on the MOBO or the chipset was updated with corrupt files.
run everest home and see if there are current updates for the northbridge chipset. if you have 2 ide channels on the board switch the primary and secondary ribbons and see if the hard drives are there. if your cdrom's are ide and after switching ribbon cables they disappear and the hard drives reappear your mobo lost an ide channel, you would need to replace the board.
Aug 01, 2008 | Computers & Internet
P4PE-X Motherboard bus speed
JAAh,
I have the same motherboard and did a little reading. The chipset on these motherboards was not really designed for the 800MHz, but it was still used by ASUS anyways. I have reduced the FSB speed on my system for increased stability. Here is the posting from another site which I found.
The 845PE Northbridge was designed for FSB400/FSB533 processors,using DDR266/DDR333 memory. (See page 11 in the Intel spec.)
http://developer.intel.com/design/ch...s/25192401.pdf
No matter how many different models of this motherboard that
Asus made, it is still based on the 845PE. Operation at FSB800
with DDR400 memory constitutes overclocking, and overclocking
comes with no guarantees (only Intel can test the chips and
bin them for speed, and the chips are not tested at FSB800/DDR400, so Asus has no way of knowing how far they can be pushed).
I've read descriptions of other people's luck with the 845PE
and it is described as "I can set the clock to 200MHz and
not a stitch more". That means even in the best case, there is
absolutely no margin left. The fact that your board runs stable
at 190MHz, instead of 200MHz, should not be a surprise, as Intel only has to guarantee the chips work at 133MHz (for FSB533).
The sin being committed here, is the user manual should state
that "overclocking comes with no guarantees". Persons interested in buying FSB800 processors, should be buying a P4P800/P4C800 or equivalent board, as the Northbridge chips on boards like that are guaranteed by Intel to run at FSB800.
If you want rock solid operation, pair a 3.06/FSB533/512K
Northwood processor with the 845PE Northbridge.
http://www.asus.com/products/mb/fsb800.htm
HTH,
Paul
Dec 24, 2007 | ASUS P4PE-X Motherboard
MSI K7N2 (MS-6570) Motherboard Logo
118 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
David
David
Robert Monigold
Robert Monigold
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
