Cars & Trucks Logo
Posted on Oct 02, 2009
Where is the speed sensor located on a 2000 jeep Grand cherokee v6 4.0 L?
ArcheryDude
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Oct 02, 2009
ArcheryDude
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
6423
Points
53
Since you have the die hard, can not kill 4.0, I believe this mated with the 42RE transmission. My understanding It use's a single sensor (located on the overdrive gear case, over the park gear).The 42RE transmissions use a single sensor (located on the overdrive gear case, over the park gear). The 42RE transmissions use a single sensor (located on the overdrive gear case, over the park gear).
Hi there I have a 2000 jeep Cherokee diesel 3.1 I'm looking for a crank position sensor thanks
Grand Cherokee, ? left off GRAND?
NO COUNTRY TOLD AT ALL, I had 1999 gas, in USA, so yah.
AND PARTS ARE SOLD BEST IN YOUR COUNTRY NOT 12,000 MILES AWAY ,RIGHT?
THE DEALER OF your car has the parts, ask them.
sounds like you have car sold in another country new
and the car is not there now, and no Jeep dealers in town?
bingo, off grid, a in jeep.
3.1L , 5 cylinders?
but did bingo on Grand (WG) model. I hAVE THE BOOK ON THIS.
Jeep Grand Cherokee (WG) (2001); WG (Europe) model w/ 3.1L Diesel (not in USA 2000) no 3.1 sold or part stores with it.
only outside USA has these parts, CKP sensor
I do have a real shop manual on the WG.
WG manual words
"The engine speed sensor is mounted to the trans-
Fig. 4 Engine Speed Sensor Location
mission bellhousing at the right/rear side of the
engine block (Fig. 4) it is a flywheel sensor.
(A FLY tone wheel /RELUCTOR DEVICE.)
seen from rear of bell at 1pm location
2 screws hold it down SEEN IN MANUAL OF CAR.
now the P/N
then who sells it we google earth for this part
YES RARE PARTS SELLER, I see youR problem on this.
engine is from Motori VM m maker. 531 OHV
V.M. VANCINI MOTORI Motor VM 531 OHV - 3.1
I see one in Italy on youtube.
Jeep Grand Cherokee (WJ) (1999-2000) w/ 3.1L Diesel engine.
Jeep Grand Cherokee Diesel 3.1L LTD (TD A) Turbo 1999 Mk II
I say ask UK, THIS SITE DOES LIST 3.1L
http://www.jeepchryslerparts.co.uk/shop/jeep/grand-cherokee/1999-2004-wj-wg/engine/3-1-td/1/jeep.html?symbol=&nazwa=ckp
2helpful
Where is the speed sensor at on a 1993 jeep grand cherokee
On 1993 Jeep Grand Cherokee 4WD 5.2L MFI 8cyl the Vehicle Speed Sensor - is located in Transmission / Transfer case extension housing (tail section), near where the drive shaft attaches to the transmission. The sensor has three wires (white / black, black / light blue and white / orange).
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
1helpful
Speed sensor location
For 1998 Jeep Grand Cherokee 4WD 5.2L MFI 8cyl the Vehicle Speed Sensor is located on Transmission / Transfer case
Check this Service Manual.
Hope this help.
3helpful
The location of the speed sensor. How can I get to it?
1995 Jeep Grand Cherokee 4WD 5.2L MFI 8cyl
The Vehicle Speed Sensor is located in the Transmission / Transfer case.
For more details, can visit the Jeep ZJ Service and Repair Manual.
Good luck. (remember rated this help)
3helpful
2answers
Is a Vehicle Speed Sensor and Transmission Speed Sensor the same?
YEP BOTH CAN MEAN THE SAME.BUT REAL NAME IS VECHICLE SPEED SENSOR.EVERY VECHICLE YOU LOOK UP YOU WILL SEE VSS SENSOR.
Where's the output transmi. sensor on a 2000 Jeep Grand Cherokee?
if you mean speed sensor it is located on reductor where shaft comes out to rear dif. if you mean rpm sensor, it is located on top of transmition screwed vith two bolts in cilinder block.
marko
1helpful
Brake problems 2000 jeep cherokee
this vehicle has three sensors two front and one on the rear end this sounds like most of your problems but have all your brakes checked .thank for your question
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
