Question about Casio Exilim EX-Z60 6MP Digital Camera with 3x Optical Zoom (Red)
I dropped it in the Winchester Mystery House. :/ Now the lens doesn't quite lay flat and the top half of the pictures are black.
What caliber is my model 1876 winchester riffel
Winchester - Model 1876
  • Winchester 1876 .45-60 (W5880) Winchester 1876 .45-60 caliber rifle. Made in 1883. Unusual gun as it has a half round half octagon barrel which is something you rarely find on a 1876. Gun is excellent with approximately 97% of the original finish. Wood is...
  • Winchester 1876 .45-75 (W2960) Winchester 1876 .45-75 caliber rifle in 35xxx serial number range with 95% blue overall and excellent wood. Has a tiny T.J.H. on receiver. This is a top condition '76 with factory letter.
  • Winchester 1876 .45-75 (W3037) Winchester 1876 .45-75 caliber rifle with very good wood and metal. Rare 7 leaf sight called for in factory letter. Rare 7 leaf sights are found on some 73's but not mentioned in the factory letter.
Aug 29, 2014 | Foam Mattress Discounts 10 King 5 Lb...
Tip
How to replace a defective LCD screen in a Kodak V803 Digital Camera
This tip is for Kodak V803 cameras that will take pictures fine but you can only be able to see them if you download them onto a PC.
A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00.
To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector.
Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place.
Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard.
Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
on Jan 25, 2008 | Kodak V803 Digital Camera
How to adjust tracking ondvd player model LHT854. also when I play the dvd it split screen or half up top and half of the picture on the bottom. then the picture frezes up but the...
There is no "tracking control" on a DVD player it is probably either a dirty lens, dirty disc or faulty laser assembly.
Try cleaning the laser lens with a cotton bud before looking for a replacement unit.
Dec 30, 2010 | Televison & Video
Horizontal lines across screen picture going fuzzy in and out and then no picture at all
A horizontal line that rolls from the bottom to the top of the tv could be a Hum Bar. This is from a bad ground either for the house electric system or for the cable system. By code, these grounds are supposed to be connected (bonded) together. In other words, the electrical interference is going through your tv instead of into the ground. Fuzzy picture is usually from low cable signal. This can be due to bad cables, connections, or splitters or problems outside with the drop (cable line outside that runs to the house). Splitters, by design, lower the cable signal (i.e. a 2 way splitter cuts the signal in half). If you have unnecessary splitters you should remove them. If you have more than about 6 or 7 tvs, you may need to add an amplifier.
Jun 25, 2010 | Vizio VF551XVT 55 in. HDTV
Half of the screen is black; picture only on the right side of the screen.
your tv has one the Y buffers defective.which half is black,the botton or the top? i believe that you have to call the repairman .
good luck
May 21, 2009 | HP PL4260N 42 in. Plasma HDTV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Lens jammed
The lens needs to be removed.  The camera case can be taken apart by using a small philips screw driver and a small flat head. Take the batteries out. Have a nice flat space to lay the screws out.  Pry out the little chrome piece with the UL sticker on it. (Carefully use the flat head). Start somewhere you will remember and begin to remove the screws going clockwise around the camera.  There is a screw under the rubber flap of the "3X" chrome cover.  The top of that must be pryed out and lifted up to remove. Take the back cover off. Lift out the top of the LCD screen and remove the 4 screws that hold it in. Start a new row of removed screws. The LCD ribbon can be removed by popping the white plastic clasp up. Next remove the menu pad ribbon from the board by lightly tugging on it. You should be able to remove the front cover by lifting it up to unhook it from the top power button strip. There are 2 screws that hold the top power strip in place. There is also a plastic hook on the front side. There are 6 screws holdong the board to the frame. A different size screw is located underneath the power strip ribbon. Loosen the 2 screws holding the flash.  THe white ribbon will be the flash ribbon and the gold one next to it will be the lens ribbon. NOTICE the lens ribbon must pass under the flash.  The side with the lens will have a small board that pushes into the main board.  To seperate it, gently pry it apart with a small flathead. There is a hidden screw for the board at the top where the end of the battery compartment. It needs to be removed before the board will come out. Once the board is out, there are three screws holding the lens in the case (they are black screws, not the chrome ones)  Once they are removed, the lense will fall out. There are 3 black screws holding the largest motor on the lens.  They are above the text "Sony Lens" remove those and the gears of the lense will be able to move freely. Twist the base to get the lense unstuck.
Jun 27, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Dropped camera and lens Dstuck , sony cyber shot DSC-W50
There are 3 pins in the camera lens that slide in grooves allowing it to move you have knocked out 1 or more.
only an experienced tech can attempt fix , camera must be totally disassembled.
Jan 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Camera Screen
The following procedure works on the V603. It uses the same LCD screen as the V803 & V1003.
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable, as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
Jan 25, 2008 | Kodak EasyShare V603 Digital Camera
Kodak V803
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
Nov 25, 2007 | Kodak V803 Digital Camera
Casio Exilim EX-Z60 6MP Digital Camera with 3x Optical Zoom (Red) Logo
14 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
