Question about Maytag MSD2732GR Side by Side Refrigerator
My maytag side by side clicks on and makes a loud
My maytag side by side clicks on and makes a loud humming noise for about 5-6 seconds then makes a loud click Its gotten more frequent in the last couple days
  • Fuji May 11, 2010
    Sounds like your compressor won't start.
    It's either a faulty compressor starting circuit or the compressor itself.
    You'll have to get a serviceman in for this one.
    Sorry for the bad news.
aborcass
  • 2651 Answers
SOURCE: maytag msd2756de side-by-side: loud clicking noise from top right of refrigerator
sounds like the adaptive defrost controller part number 61005988. not to bad to repace, the top control panel is removed by pulling down on both rear corners ( youls find little finger holes across the top rear panel to free and pulll foward, the n there are 2 1/4in screws across th efron of control, and 2 phillips head screws jus behind each light bulb, one last 1/4in screw directly on back wall will drop entire panel adn after that youl see the control in the right hand corner unplug the old replug the new . DISCONNECT POWER PRIOR TO REPAIR<
Posted on Oct 27, 2008
  • 198 Answers
SOURCE: Maytag MSD2756GE Side by Side Fridge
You have a bad compressor, time for a new refrigerator. Check your warantee for compressor failure. Might be 5 years.
Posted on Jan 09, 2009
Testimonial: "Thanks for the help."
SOURCE: my maytag refrigerator started making a buzzing
I have the same problem. It is ice buildup around the evaporator fan that begins as a buzzing (the fan blades hitting the advancing "glacier"), which ultimately stops the fan and then the freezer/fridge stop cooling. Just pull the lower sheet metal from the inside rear of the freezer (need to remove some screws from upper sheet also) and chip the ice away. I've got a question in to Maytag now to see how to prevent this from recurring. I've had to take the thing apart 3 times in 2 years.
Posted on Aug 27, 2009
  • 254 Answers
SOURCE: maytag freezer does not work. it hums and stops
if you evap fan is not working this wouldnt produce any coldness,, or possibly it sounds like your compressor start realy is tryin to start but not working,,,
Posted on Feb 03, 2010
  • 50 Answers
SOURCE: Maytag MSD2351HEB sidebyside occasionaly goe
if this model has the techumse compressor it is probably drawing high amperage and kicking out. the click and buzz is the compressor winding stressing to draw the energy needed. compressor maybe bad. the compressor model usually starts with a t11...
Posted on Aug 01, 2010
Maytag refrigerator making a loud noise when dispensing water
If it is a loud "humming" noise... make sure the water supply is not restricted, if that is OK, replace the water inlet valve.
Nov 23, 2016 | Maytag Refrigerators
I get a loud humming noise . The dryer works good but makes a loud humming noise when it's working .
The motor is going bad and this will make that loud humming when it is running...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2010 | Maytag Dryers
WMSD2756GES Clicking, slight burnt smell, humming then repeats
Replace the overload relays down at the compressor. Easy repair and too expensive. Do this and you'll be good to go.
Feb 01, 2010 | Maytag MSD2756GES Side by Side...
Really loud humming noise and freezer is defrosting/refreezing
Connect only to an outlet, do not use an extension cord. If you really must use an extension, make sure it is capable of handling the load. Should be a 16ga minimum, 14ga preferred and not exceed 25 feet. If you are having this issue while plugged directly into an outlet, perhaps the circuit is weak, and you should try another outlet.
Other possibilities include: a short-cycling thermostat. This is when the thermostat tries to kick the compressor back on too soon after the last running. OR Your compressor is on the way out. Sometimes the installation of a "Hard Start Kit" will aid a failing or stubborn compressor. If you've eliminated all else, consult an appliance servicer to buy the hard start kit. They typically are a universal fit, and come with instructions.
Jul 06, 2009 | Amana ASD2626HE Side by Side Refrigerator
New Maytag dryer model mgdc400vw makes loud humming noise
Weird, try making sure it is level, and make sure your vent pipe aint too long. Tip the cabinet back while running if the noise goes away the damn metal vent pipe is too dang long.
Jun 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dec 31, 2008 | Maytag MSD2756G Side by Side Refrigerator
Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
PROBLEM WITH HUMMING NOISE
Sounds like your compressor is having a hard time to start
Replace Relay/Overload combination that should do it let me know if you need additional assistance email me at hvac.tech7872pr@gmail.com
Apr 18, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag Netune Mah4000AWW
Makes a loud humming noise. Does the machine go thru its cycles ? Is the humm ther all the time ?
Jan 06, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag MSD2732GR Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
