Question about Kenmore 73189 Air Conditioner
It shut down and wll not turn on again, even after
Kenmore Model 73189 room AC. It shut down and wll not turn on again, even after a 3 minute rest. The 220V wall power checks OK.
  • 101 Answers
Check fusable link
Posted on Oct 02, 2009
I have a Craig jukebox Bluetooth model CHT935BT-BLS..after turning on it plays music for 15 minutes than shuts off,I power it back on than it shuts off again
Sounds like its either low on power or the memory in it is to full to operate. To check the power issue does the unit run on built in batteries that need charged or is it a fixed ac power unit that plugs into the wall? If it plugs into the wall ensure the plug os securly connected both to the unit and inyo the wall receptacle too. If its a built in re-chargeable unit plug your charger into it for at least 6 hours and then try using the unit again if it doesnt shut down this time it was a low battery; however if it still shuts down try removing 3 -4 of the longer or bigger music files from it and then try using it again and see if it shuts down. Hopefully this will help somehow.
Apr 16, 2016 | Craig Audio Players & Recorders
I shut down my computer now I can not get it to turn on when I push the power button
Unplug the computer and hold down the power button for 15 seconds, and then plug it back in and see if it will re-start.
Jun 12, 2011 | Dell Inspiron 530 Desktop Computer
My lg wall unit (LWHD1009R) 10,000 btu the compressor keeps turning off after it gets going. even though I have it on a low temp. the comressor turns off after 5-10 minutes even though the room is not cold
either going off on low charge which would cause it to ice up, which means you need refrigerant. or high head pressure might just have to clean the coils or check condensor fan.
May 05, 2010 | LG Art Cool LA121CNP wall/window Air...
No heat, noise when drum turns Sears series 80 electric dryer model # 110.66842501 serial # 11T2010304
Verify that you have 220V ac at the wall . Inspect power cord for damage. Verify that you have 220Vac to the machine.
If you have 220v to the machine then you may have a bad heating element or a loose or bad wire inside the machine.
What kind of noise when drum turns?
I hope this helps. Let me know if I can help in any way.
Mar 22, 2010 | Kenmore Dryers
Kenmore 76081 cycling rapidly
check voltage when it shuts down possible motor overheating
Mar 09, 2017 | Kenmore 76081 Wall/Window Air Conditioner
Window 1.5 AC Problem During Day
Chack size of wire. Should be at least number 10 wire. Check loose connections. Call power company to check your voltage. This time of year in different parts of the country they have brownouts which is a voltage drop becaus of the load on the lines. Have power checked. Rus
Jun 15, 2009 | Heating & Cooling
Put in new wall oven , turned on power and set
my kenmore double oven model 41165 has no power....its hardwired 40 amp....it stopped working when it was cooling down after the slf cleaning cycle..we had a storm and had a minute power outage. Finakky got the door open but it wont turn on at all. Tried the breakers but i stll get no power....no even the bulb.......thanks....
Jun 07, 2009 | Ovens
Cooling problem with my ac.
The start capacitor may be the problem. Is your AC a central unit or window unit? Whats the model and make? If a window unit it could also be the thermostat is defective or too close to evaporator fins. Dirt on the condenser outside can cause the motor to heat up to the point it shuts down to cool the internal overload. Let me Know, Sea Breeze
May 18, 2009 | Carrier Heating & Cooling
Kenmore Model #731893 Room Air Conditioner
Does you air conditioner have a GFCI on the end of the plug if it does there is a reset there.. let me know if it doesn't and you want to go deeper?
Aug 07, 2007 | Kenmore 73189 Air Conditioner
Kenmore 73189 Air Conditioner Logo
162 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
