Question about Ovens
GE oven JDC27GP, bake coil turns red comes up to temp. then stops working. Only heats up to 200 degrees. Ohms in coil is 26.3
    President:
  • Ovens Master
  • 1,922 Answers
Oven thermocouple is defective
Posted on Oct 02, 2009
On "bake" my GE profile
make sure the display is correct put a thermometor in oven to get correct reading
Mar 18, 2011 | GE Ovens
GE Oven is not heating to full temperature.. Also heating up real slow
Thank you for contacting Fixya.com.
First you need to check whether you are getting full 220 volts + to the oven. Some oven controls have adjustable knobs where can be fine tuned. The temperature can be calibrated by 25 degrees but not any 200 degrees. I think these can get you may be up to 75 degrees max. It seems like your sensing bulb is mounted right your oven control which has the sensing bulb attached could very well be shot. Also check if the elements work? Does the broil get red when set on broil; does the bake get red when set on bake? If yes the wiring should be ok and possibly/probably is a bad oven temp control. If the elements do not get red, that would have to be investigated (burnt wire, bad selector switch, bad oven control, burnt wire. Turn on the oven with the meter connected. It should show full voltage when you first turn it on and the thermostat will turn it on and off.
If the sensor inside the ovens baking compartment is not damaged, touching any metal part, bent, pitted, no foil is used on the racks or lower plate, in an attempt to keep ovens internal clean, etc, then temp sensor is likely defective. Which means the ECR (control unit) will need to be replaced.
Please get back to us if you have any further query.
Have a nice day.
Nov 13, 2010 | Ovens
Oven won't heat past 200 degrees
Unplug the range.
Remove the oven racks.
Remove the screws on the bake element.
Carefully pull the bake element out.
Remove the wires from the element.
Use a volt meter set for ohms/continuity and touch one meter lead to one element terminal and the other lead to the other element terminal.
No reading is a bad element/
If you get a reading your oven control is bad.
Jul 24, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Ge gas oven goes to f2 and beeps when we set the oven over 375f. 400f guaranteed to go off. We replace the glow coil last year and it stopped but its back. We use the oven at 375f for the top temp. We...
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
F2- Failed Oven temp sensor, or control board.
Concerning the glow ignitior.
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
Nov 12, 2009 | GE Ovens
I have Whirlpool oven Model # RB220PXK (almost 30 years old) and the lower element sparked and stopped working. I measured the resistance of the element and it showed 1.6M ohms. Is my element bad or is...
HI. You can Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.
NOTE- The element may have small holes and bubbles on the coils as well. This is a sign of a burned out element. Test the element connectors as well.
Oct 12, 2009 | Ovens
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
GE JRS04BOW3BB Will not turn on.
turn the broil on high by itself wait a couple min. and see if it comes on. if it does the your bake element needs to be replaced or you may just have a burned wire where the bake element plugs in. just remember to turn the breaker off to the oven before trying to pull out the element
Nov 25, 2007 | GE JRS04 Electric Single Oven
Ovens Logo
159 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
