Question about LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone
My LG Cookie does not ring.
It is not on silent mode. I can only hear the ring through the headset(wired as well as bluetooth). Also, when taking call, the voice cannot be heard on the earpiece. Here again, I have to essentially use a headset
The sound on my iPhone suddenly stopped working, it does not work for music like pandora, videos, youtube, police scanner, the ringer fully works and I can hear people talking when they call so I do n
Try resettin, hold home button and power button for about 25 seconds, if this doesnt work the speaker prob went out. they have two speakers, one u hear people on and the one u hear music from.
Nov 01, 2012 | Cell Phones
No ring volume
might be in silent mode try to change your profile to general(normal) mode
Aug 24, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Having hearing problems with my phone
Take off mute in the sound menu.
Oct 28, 2009 | Cell Phones
My LG Voyager seems to be stuck in car kit mode, it did not get wet, (I read alll the blogs on getting wet is cause and the verzion rep said thats what it was, however, it didnt get wet, I copmpared the...
I just had this same problem. It is a hardware issue. Call verizon back explain the situation, they will call your phone to verify that the mic and speaker aren't working and they will send you a replacement within 2 days.
A temporary solution is plugging a wired headset into the phone and taking it out, it will work for a few hours.
Sep 04, 2009 | LG VOYAGER VX10000 Cellular Phone
My LG cookie is not able to detect the Nokia Bluetooth headset
Sorry if you have done this but let's see if we can get you connected!
On your Nokia headset press and hold the multi-function key for roughly 8 seconds. Your green light will begin to flash quickly. Your Bluetooth headset is now in pairing mode.
Now using your LG Cookie, press Menu > Settings > Bluetooth > Search
Once found, you will need to type the pass code which is normally set as four zeros (0000).
You should now be connected.
We hope this helps!
Jul 03, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
How to connect LG cookie with Nokia Bluetooth BH 101
Put your Nokia Bluetooth BH 101 into pairing mode - this is normally done by pressing and holding the power key for several seconds. An alternate bleep will sound with a flash light to indicate that you are in pairing mode.
Now using your Cookie, press Menu > Settings > Bluetooth > Search
Your Cookie will find the Nokia BH101 bluetooth headset and then it will ask for a pass code. This is usually four zeros (0000).
You should now be connected!
Apr 10, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Silent Headset
You may have your phone on silent.
Apr 25, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Dear Kathiwc
Why wud u want to use a headset to tap a call and that to to ur phone without u answering is it. You have not made urself clear towards the end of ur explanation.
Feb 07, 2008 | LG HBM 730 Bluetooth Headset Wireless...
I can set up my headset to my new phone
Step 1 - Enable Bluetooth functionality on the Motorola V3m. Note: The Bluetooth power must be set to ON position to pair the device. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Setup, press [Center NavKey]. Scroll to Power XXX, press [Center NavKey]. Scroll to On or OFF, press [Center NavKey]. Step 2 - Put your fully charged Bluetooth headset into pairing mode. Start with your Bluetooth accessory powered off. Hold down the power/end key for 5 seconds. You'll hear a short beep and the LED light turns red. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset. Step 3 - Pair the Motorola V3m with a Bluetooth Accessory. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Handsfree, press [Center NavKey]. Place accessory in pairing mode. See accessory pairing instructions. Scroll to Look For Devices, press [Center NavKey]. Phone displays Scanning. Scroll to XXXAccessory NameXXX, press [Center NavKey]. Phone displays Bond With XXXAccessory NameXXX. Press Yes [Right SoftKey]. Phone displays Enter Passkey. Enter 0000, press [Center NavKey]. (See accessory instructions as passcode may vary.) Phone displays Connected.
Jun 17, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG KP500 Cookie black on T-Mobile U-Fix £25 Text , with 30 mins & 500 txts a month Cell Phone Logo
244 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
