Question about Motorola Mobility RAZR V3
Razr lock up
When attempting to enter text, phone locks up. Can only enter 3 charactors. Have read that I should use P2K phone manager and delete the iTap_user_dictionary from the a file and then re boot phone. Comments?
  • kgst_bob Dec 25, 2007
    Thanks, Bajanguru but that was the first thing I tried minus the re-flash. I went ahead and deleted the iTap_user_directory, re-booted phone and Bob's your uncle...worked like a charm. Phone no longer locks up and text messaging working great, entering new contact names,..no problem.
    Brigadier General:
  • 7,752 Answers
First try and do a master clear and reset and see if that works.....i really don't think deleting the file would help that , you may also need to try reflashing the firmware if the master reset/clear does not fix the problem.
Posted on Dec 21, 2007
How to delete or add new web sessions.......???????
This will do it....it is P2KAE, or P2k Advanced Editor. It should let you modify lock and unlock the websessions.
http://rapidshare.com/files/91361718/P2KAE_4929.ZIP
Feb 05, 2011 | Motorola Mobility RAZR V3i Cellular Phone
Verizon Razr V3 with locked screen. Verizon
yes ,down load p2k or another flashing utility,then flash your phone
Mar 11, 2010 | Motorola Mobility RAZR V3
Flex error:phone subsidy-locked how can i get rid of this message
You have to get it unloked from a cell shop or call the phones original carrier and get the subsidy unlock code which they might give you or might not. If you have a data cabe you can google how to unlock it yourself.
Here is the procedure if you have cable. I wil allso post a link that will help you.
My phone displays a "enter subsidy code" message but the phone is not locked. What can I do?
Open up P2K Manager and search for file "secure_pds_init."
Delete it.
Go to Settings -> Personalize -> Greeting & delete the "Flex Error: Phone Subsidy-Locked" message.
Finally restart the phone
http://forums.mobiledia.com/topic30504.html
Jan 29, 2010 | Motorola Mobility RAZR V3
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
Download pictures from my motorola V3 RAZR
is that a razr v3 not v3x??well all you have to do is download the motorola drivers and p2ktools, p2k manager or skiman. connect your v3 via cable, install the drivers correctly and then the computer will detect your phone as p2k, if not, open one of the applications that you have downloaded and that should do the work.. then the application will read to your phone files and you can now transfer files from pc to phone and from phone to pc! you can also read the instructions on www.modmymoto.com! thanks and goodluck..
Oct 26, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola razor v3
try master resetting the phone
Aug 31, 2008 | Motorola Mobility RAZR V3
Lost lock code my moto razr
u can make the code to default by doing the following....
download the software called p2ktools from net ... and connect your cell to pc it will ask for driver to install then give the location "drv folder" inside p2k tools.. then just go p2k mode then give flex ... by flexing your problem may get solved(there will one more option called check for codes from there you can remove codes).....
note: while downloading p2k tools download the old version dont download the new version (new version may be p2k tools3)
Feb 10, 2008 | Motorola Mobility RAZR V3
Motorola Razr locks up when texting
try re-flash you language flex. google for a language flex then download it . it sud b compatible to your V3. use RSD lite to reflash it don't forgot p2k driver to connect your phone -google again.
google is the ans for those key i gave you. if you having problem find those let me know so i can upload them for you
Jan 14, 2008 | Motorola Mobility RAZR V3
Unlocks by itself
totally lock you need these tools. P2K easy Tool 3.9 warez-google for P2K Motorola Driver 2.9-google for Cable. buy from local store and a downgrade file i will be provided
Aug 14, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
29 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
