The lid switch was broken apart on a kenmore washer.Can it be reinstalled?
  • 5,911 Answers
Not likely. You really should replace it. This is not an expensive part and its a fairly simple repair. The following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A replacement can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all of them for the best price.
This is a very simple repair, that usually costs about $25 to $35 to repair yourself. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Oct 02, 2009
HI I HAVE A KENMORE WASHER MODEL #82881100 SERIAL #C92167486 THE WASHER FILLS AND NOTHING ELSE.DOESN`T AGITATE,SPIN OR DRAIN. THANK YOU IF YOU CAN HELP. BOB
you forgot the first three 110.82881100 is the full model,you'll need that to order the right parts.it sounds like you have a broken lid switch,i looked up your machine and it takes the older cherry switch part number 279347 and it's around 35 dollars.close the lid down,then open it around an inch or two,do this a few times,you should hear a clicking sound,if it isn't clicking the lid switch is broke,i'll send you a video from utube but it's for a different lid switch but you take the machine apart the same way but it's for a 247 lid switch and you need a 279347.if you can hear the motor running and this is happening you could have broken the motor coupling and i'll send that along too.http://www.youtube.com/watch?v=MFsvLiuTniU this is for the lid switch copy and paste.this is for the motor coupling http://www.youtube.com/watch?v=9K1KHEogf3c hope this helps salde
Sep 04, 2011 | Kenmore Washing Machines
Washer quit working in rinse cycle before spin cycle tub full water does nothing but fill with more water when you increase water level
99% of the time the lid switch is what causes this issue, below are two links one where you can get the lid switch and the other explains how to take the washer apart to test and access the washers lid switch.
Cheap Appliance Parts Click Here
Good luck with your repair!
How To Take Kenmore Washer Apart Click Here
Mar 05, 2011 | Kenmore 26882 Top Load Washer
Kenmore mod 23832100 Lid Switch broken HOw do I
Good day,
There are 3 different style lid switches used on Whirlpool/Kenmore washers. You have to break down the unit to determine which one you use. Any appliance parts house will carry what you need.
Here is an excellent tutorial.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Mar 01, 2010 | Kenmore 23822 Top Load Washer
I have a Kenmore 70 Series Washer. The lid switch
Bob your an the right track.. remove the two screws ( unplug washer ) pull sw from mount and the wires will folow. they are hooked to a wire clip . with it in hand you can see if sw is cracked or broken .. the new sw will come wire& plug/ you can splice it or remove wire harness and reinstall as you took it appart . the 70 series has a lift up top / two clip in front / use a putty knife . ..mm
Dec 04, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 110 80 Series. Agitates, fills, won't spin
This is most likely the lid/door switch loose in its mount or, switch has dirty contacts or, it's broken. The lid switch is a safety feature which keep the tub from spinning if the lid/door is up/open.
Don't know if switch comes apart to clean contacts, but if its tight in the mount (which means loose mount is not the problem) then you could remove it, soak it in rubbing alcohol for a while to clean it (if you can't easily take it apart and reassemble).
Charlie
Aug 26, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Type 111 filled with water and stopped
with the machine off, turn the cycle dial around 3x very harshly, then try it again. If it works normally now, you'll need a new cycle switch soon!
Mar 27, 2009 | Kenmore 24032\24036 Top Load Washer
I think it is the same proble as you discribe
Hey chiki76
You still have a lid switch problem. The switch has to be replaced. The switch usually comes apart or the clips securing them are broken
regards
Sep 04, 2008 | Kenmore 22422 Top Load Washer
Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Jun 23, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 series stops after rinsing
Hi Coldcut, I joined the pic of my solution , where the pen is inserted is where a the problem is during the cycle this is where the depression should be constant which I am not gettin when the door is closed , so I open it and do it manually .d6db1c8.jpg
Jan 30, 2008 | Washing Machines
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
