Question about Maytag MDE308DAYW Electric Dryer
We had a power outage the other day, and now our Maytag MDE308DAYW dryer just buzzes when we try to start it. At first, I unplugged the power, let it sit a few minutes, and plugged the power back in, and it started and ran OK. But after that first time it won't start at all, just buzzes when we try to start it. Any ideas?
Hi fixya. I solved the problem myself, it was pretty easy. I just unplugged the power; let it sit for a minute; plugged the power back in; then I opened the dryer door and while manually holding down the door switch, I manually spun the dryer drum and simultaneously my son hit the start switch - you need three hands to perform this procedure - and it started running! Then I let it run for at least an hour, and ever since that it has started perfectly well.
Posted on Oct 14, 2009
    President:
  • Maytag Master
  • 1,922 Answers
It could be a myrid of things, power surges do strange things to electrical/electronic equip,it could be your motor protector,your cycling switch,your motor windings,hi-limit switch,etc,look over the entire unit and see if there are any suspicious burns,wires burned off terminals,etc,then can you blame the outage on your power supplier? if not and you have home owners ins you might have a tech declare machine un fit for refix
Posted on Oct 04, 2009
Is there a secret to unplugging a dryer?
No, just pull the plug. If you'd feel better, wrap the plug with a small towel when you pull it out. Be blessed.
Feb 25, 2013 | Maytag MDE308DAYW Electric Dryer
Please in very careful detail exsplain how to attach four prong plug wires to my maytag model no mde308dayw please help?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2011 | Maytag MDE308DAYW Electric Dryer
I have a Maytag Dryer that has a twist knob selector that you push to start the dryer. The dryer stopped producing heat and then the knob would no longer start the dryer. The light inside went out at the...
Has the Timer gone bad? check the connections to the dryer because the timers sometimes die, make sure to turn of the power and unplug the unit form the wall.
Mar 25, 2011 | Maytag Dryers
I have a maytag dryer that will not start. When I push the start knob, I get a buzzing noise that sounds like there is something wrong electrically behind the control panel. I took off the panel in the...
http://allrepairmanuals.com/maytag-dryer.htm?model_number=MDE308DAYW
Hi, what you describe indeed sounds very bad, and should be looked into asap, to do this yourself you will need a service and repair manual, accordingly i have provided a link above for you to obtain one.
You will need to be very careful, as with any electrical fault, the service manual has troubleshooting steps for you to follow so you can isolate and repair your problem.
Buzzing noises usually have to do with the motor, or gears belt etc.
Also to help below is a DIY website that will help you also
.http://www.acmehowto.com/howto/appliance/dryergoe.php
Feb 01, 2011 | Maytag MDE308DAYW Electric Dryer
Dryer won't come on - when you push the start button it just buzzes - what's wrong
I had a dryer not the same model like yours but It had the same problem.
Well it happens because of :-
Heating - When it heats then it stops untill its cool
I hope it helps
Dec 28, 2010 | Maytag MDE308DAYW Electric Dryer
Maytag dryer model MDE308DAYW will not start. Why?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 27, 2010 | Maytag MDE308DAYW Electric Dryer
Dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 07, 2010 | Maytag MDE308DAYW Electric Dryer
How do you expose the heat element
Take of back of unit, unplug first. Heat element is near heat duct side with wires attached to it. Unscrew and slide it out. You could also put a tester to each wire to see if you have a complete connection. If ok check thermal switches, one could have gone bad.
Aug 17, 2009 | Maytag MDE308DAYW Electric Dryer
Maytag MDE308DAYW Electric Dryer Logo
315 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
