Question about Fuji FinePix S5000 Digital Camera
When I turn it on, the screen is white and flickers. It won't show what I'm trying to photogragh through the viewfinder
There is something wrong with my Nikon D3000. It turns on but doesn't show anything on the screen and when I look through the lens it's shows a grainy dark film. It can't be the lense because I...
There seems to be two separate issues here. I'm going to assume you have a charged battery pack in the camera.
First, the screen. Turn the camera on. Do you see the menu when you press the MENU button? Does the shooting info show when you press the Info button? Can you see previously taken photos when you press the Playback button? If none of those show up then something is wrong with the screen (or the battery is dead).
Second, the viewfinder. First, make sure the viewfinder in the back is clean. Now turn the camera on and look through the viewfinder. Do you see the eleven focus marks? Do you see the info at the bottom? Now turn the camera off and remove the lens. Don't touch anything inside the camera! Do you see a mirror at a 45-degree angle? Is it clean? Look at the focusing screen above the mirror. Is it clean? Now look through the viewfinder and point the camera out a window. Do you see a more-or-less white blob, or the same grainy dark film?
Apr 11, 2013 | Cameras
CANON SD1000 VIEWFINDER SCREEN WON'T COME ON
Do you have the user's manual? There should be a menu option to turn 'live-view' on and off. This option is to save battery power when not needed (if using the viewfinder only).
Jan 17, 2018 | Canon PowerShot SD1000 Digital Camera
Screen showing white via viewfinder
why does my camera show just a white screen
Jul 01, 2010 | Fuji FinePix S5000 Digital Camera
When I turn on the camera the viewfinder/display screen are white
if u take pics and they are also white in color and blank then my friend CCD failure! has occured just email FUJI or call them in ur region where u are get info at www.fujifilm.com they will repair free of charge it is the manufacturing fault , i had the same model S5000 and had the same problem and i got it repaired free from Fuji u have to call them , even thousands are facing the same problem all brands , they are repairing free of charge regardless to the nature of warranty see this link
http://www.imaging-resource.com/badccds.html
pls rate me FIXYA if i helped u
Mar 28, 2009 | Fujitsu Cameras
Powershot pro1 viewfinder show blank white
Hi
When the LCD screen is open the viewfinder will switch of and when it is closed the viewfinder will switch on. You can switch between the two by pressing Monitor select button to the left of the Eyepiece (Viewfinder). as you look at the back of the camera.
Hope this helps.
Jul 15, 2008 | Canon PowerShot Pro1 Digital Camera
ViviCam
Do you have a viewfinder and a screen? The screen won;t show anything if you have the viewfinder turned on.
Jun 18, 2008 | Vivitar ViviCam 5100 Digital Camera
Screen is white and doesn't display area being photographed. Can take pictures.
From camerahacker.com:
1. Hold camera firmly in left hand.
2. Smartly rap front of camera with knuckles of right hand on the "Cyber-shot" logo.
Worked for me :)
// Maxim
May 29, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Christmas URGENCY: monitor/viewfinder: blue screen, lines of white dashes
remove the tape and just test that whether its recording or not and try to change the tape and then try
Dec 23, 2007 | Panasonic Palmcorder PV-GS70 Mini DV...
Photo screen problems
This definitely sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 09, 2007 | Canon PowerShot S1 IS Digital Camera
Fuji FinePix S5000 Digital Camera Logo
64 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
