Question about Garmin StreetPilot C330 GPS Receiver
Installing my new street pilot
Where is the small round black disk with the red top supposed to go?
    Problem Solver:
  • 7 Answers
It is a mount for your dash that your suction cup mounts to just paste it to your dash ans put the suction cup on it and install your unit
Posted on Dec 21, 2007
I bought a Leviton 1201-PLC 15 Amp, 120 Volt, Toggle Pilot Light, Illuminated ON to replace a traditional 3 way switch (without a pilot). I replaced it by connecting the existing wires to the new switch in...
Your screw terminals are 2-brass and 1-dark.
Dark screw is considered 'common'
http://waterheatertimer.org/ST01C-program.html#3-way
Leviton shows a 3-way 1203-2, but not 1201
Wiring diagram indicates that pilot light is ON whenever switch has power.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=2681§ion=10046&minisite=10026
Check your instruction sheet that pilot light is supposed to turn on-off with Load.
I don't think it is, without additional terminal on switch for neutral wire.
And then it would only work on switch located closest to light.
You can wire this type of thing separately.
Buy ordinary pilot light or indicator light from WW Grainger.
Look at diagram on following image:
http://waterheatertimer.org/images/3-way-circuit-with-pilot-indicator.jpg
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 08, 2011 | Leviton Snap On Mount Switch Pilot Light -...
Hi there, the unit turns on and sounds normal, but is blowing cold air. i'm looking into the unit but can't see a flame, are u supposed to? should i ignite by hand?
Yes, if you open the top door you should see a pilot light. If you don't then the first thing is, do you have gas? If you do then there should be specific instructions on how to light it, on the door. Just to give you an idea first find gas valve, its the thing connected to the black pipe leading out of the furnace. Then find the aluminum tube that comes out of it (1/4" tube, silver, small) and trace it to the end, this is where you will light the flame. Then turn the gas valve to off position for 2-3 minutes to let any gas dissipate. After that turn it to pilot, push and hold the red button, then light the flame. once the flame is lit turn gas valve to on position. If the flame does not stay lit then you have a problem with your thermocouple (senses flame). If the pilot light does not light at all you either have no gas or there is air in the pipes.
Hope this helps.
Feb 10, 2011 | Goodman GMS90703BXA Heater
TDS 3-button keyless remote operating instructions please
RED opens the drivers door, BLACK opens all the doors, and GREEN turns on the head lights
Apr 30, 2010 | 1998 Toyota Camry
I am no repair guy and I can't see where to light the pilot? I am not keen on just strkiing a match and sticking it somewhere for the heck of it. What should I be seeing or what might it look like. It is...
Ok, throw the match at it> Just kidding. Right there at the main gas valve there should be a tube about 1/16 in diameter. It screws into the valve with a small brass fitting. Follow that tubing to its other end which goes into the burner . On the end of that is a bulb in a bracket. within a half inch or so of that bulb is the pilot flame or where the pilot flame is supposed to be, so push the pilot button down and get a lit match to that point and bingo.That bulb is a thermocoupler. It must get hot before you get main burner gas.so hold the pilot button down for a few minutes. Good Luck, Ned
Oct 17, 2009 | Heating & Cooling
What does the harddrive look like? I want to take
4by 6 in box with what looks like rings on it, and a small pcb, there is a round disk inside. hit box with hammer wear saftey glasses.
Sep 08, 2009 | Computers & Internet
87 S10 proportioner valve.
i DONT KNOW IF ANYONE MAKES A KIT TO REBUILD.I would check on a new one.or used remember regular o rings will get ate up by the brake fluid
Dec 10, 2008 | 1988 Chevrolet S-10
Installing mobo
here http://www.nvidia.com/object/designed_by_nvidia_support.html
Mar 01, 2017 | Computers & Internet
Garmin StreetPilot C330 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
