Question about Kenmore Elite 45986 Front Load Washer
Won't drain I have a Kenmore Elite HE 3t keep getting f2 and sud on panel won't drain. cleaned front filter. What next?
  • 5,911 Answers
"F02" is a Long Drain error code. This indicates that you have an obstruction in the drainage system, as you well know by now. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
I enclosed this information just in case you may have missed somethins. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail. Also, check the connector plug on the pump to ensure it is making contact. It can come loose from vibration.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. In addition, the "SUD" error can occur in conjunction with a drain pump failure as this error occurs when too much air is sensed in the drainage system.
Posted on Oct 02, 2009
My Kenmore Elite front loader keeps on showing the same problems
Cut down on your soap i only use very little soap and it works great.No more SUD code
Jul 02, 2014 | Kenmore Elite 45986 Front Load Washer
What does the trouble code f2 mean for the kenmore elite 4t washing machine?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 22, 2011 | Kenmore Elite 45986 Front Load Washer
It won't drain or sometimes it drains slow.The F2 code will appear or the Suds code will show up.
The drain filter is blocked and needs to be cleaned. Unplug the machine or disconnect power then remove the three screws attaching the bottom of the lower front access panel and pull the panel down and off. Once the panel is off, you'll find the drain filter attached to the drain pump.
Place a container or a piece of towel
underneath the filter to catch spillage. You may need to drain the water from the machine by putting the end of the drain hose over a container on the floor. Position the container as low as possible to extract as much water.
Remove the filter by turning the knob counterclockwise and clean it.
Also take a moment to inspect the drain pump impeller by reaching it in with your finger and turning it. The impeller should turn freely. Otherwise, replace the drain pump.
Click on the link below if the problem persists after cleaning the filter.
Kenmore Elite and Whirlpool Duet Sud/F02 Error Code
Jul 20, 2011 | Washing Machines
My Kenmore Elite HE 3t keeps flashin the F02 error code i cleaned the hose that dispenses the water and the connection to the hose but the problem continues can you help me
u might have a drain problem u need to take the front panel off at the bottom there are 3 t20 torque bits take them off and the water pump should be in front or to the right side theres a filter for the pump u need to take that of and see if there is any objects in the filter if so clean it out.then check your drain two if this does not work u might need to replace the pump good luck
Feb 15, 2010 | Kenmore Elite 45986 Front Load Washer
F2 code coming on several times during a wash
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Regarding 'suds', the junk in your filter could be affecting the thin tube going from the pump area to the 'pressure switch' near the controls. This should not be blocked, remove clip from top & blow into it (after cleaning out the filter). If blocked clear it out. Do not wait for filter to clog up. Check it now & then, according to usage.
Nov 06, 2009 | Kenmore Elite 45986 Front Load Washer
F2 error code on my Kenmore Elite HE3 washer
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
ERROR CODES ON MY WASHING MACHINE
join todays crowd!!! im in the same issue it is f2 error thatfollowedf suds error huh?
f2 is long drain issue after 8 minutes occurs anf the water valves to machine can be not fully iopoen; unplug ist
next keep off 2-5 minutes tpo clear memory
replug in
check drain hose not kimked
check drain pump inside is the next issue for prom is filled with foriegn objects that is known for this unit!!!! their a tech online kctech thats great try his answer online to use a shop vac and **** out any water in the inside and the hoes: and the drain pump inside the machine: see solution #6 may 2008 posted by washer gut in knasas that is eceptional to follow great day danw.
Mar 19, 2009 | Kenmore Elite 45986 Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 3T - clean drain pump filter
Take the front panel off and there is a pump, be sure that you have towels or a bucket, there will be excess water and junk since it is clogged
Dec 30, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
90 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
