Question about Cameras
My fujifilm j150w camera says communication error time i try to upload pictures
    Top Expert:
  • Cameras Master
  • 14,162 Answers
this video shows you different ways to get you pictures
Posted on Nov 19, 2014
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
SOURCE: communication error when uploading pictures on computer
I had the same problem. My problem was that there were more than 1,000 images stored on the memory card. Once I deleted some of the images from the camera memory card, I was able to download pictures again.
Posted on Oct 31, 2008
  • 3 Answers
SOURCE: I got a pink Fujifilm Finepix Z20fd and pictures won't download
You don't have to use the software that came with the Fujifilm. I have the same camera. If you're on a laptop that has a slot for SD cards, (if you have an SD card) you can just put your card straight into your computer and load the pictures that way. Also, if you have an SD card reader, you can use that. And if you're on a desktop without either of those options; once you plug your camera into your computer, go to your start menu and click 'My Computer,' then your camera should come up as a removable disk device in the folder. From there, you can drag and drop the pictures onto your desktop or your My Pictures folder.
Posted on Jan 08, 2009
  • 241 Answers
SOURCE: Communication Error when uploading photos
You may have switched USB mode to Pictbridge by mistake.
Press Menu/OK, select Setup, choose USB mode (on 3rd page) switch from Pictbridge to DSC, press OK.
Posted on Oct 13, 2009
  • 244 Answers
SOURCE: my fujifilm j150w says frame no. full and i cant
Read the post on my tips page on my profile for how to reset.
Posted on Oct 26, 2009
  • 48 Answers
SOURCE: i keep getting a communication
There are a couple of things you should try, remove the memory card from the camera and try connecting, if you get no error then chances are your memory card is corrupted.
If you still get an error then start looking at the cable you are using, try another if you can get one, cables are easily damaged.
You should also try checking the camera settings for USB connection and make sure it is set to Mass storage
Posted on Oct 27, 2010
Uploading pictures from camera to pc get run time error
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Mar 17, 2014 | Fuji J150w Digital Camera
Date, time, year on camera J150 inncorrect
The Date/Time command is in the setup menu. Follow the instructions beginning on page 72 of the manual.
Jun 25, 2012 | FUJIFILM FinePix J150w Compact Camera...
User manual for fujifilm finepix j150w
You may download a copy of the manual here.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 19, 2012 | FUJIFILM FinePix J150w Compact Camera...
I tried ALL the suggestionas for my fuji fine pix J150W camara. still have the message of "frame no full". Thanks for all the efforts. I will be buying a new camara.
Don't buy a new camera yet. This solution will help you correct your camera problem. If this helps consider voting me.
1). Insert a new memory card.
2). Format the memory card using the FORMAT function in SET-UP menu in the camera.
3). Set RENEW as the FRAME NO. setting in the SET-UP menu.
4). Start taking pictures.
5). Set CONTINUOUS as the FRAME NO. setting in the SET-UP menu.
Good luck! And thanks for using FixYa!
Sep 05, 2011 | FUJIFILM FinePix J150w Compact Camera...
My fujifilm j150w says frame no. full and i cant take any pictures
Oct 26, 2009 | Fuji FinePix J10 Digital Camera
My photos wont upload
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 10, 2009 | Fuji FinePix S1000FD Digital Camera
I have a fujifilm j150w and it keeps on sayin card not initialize
i dont think there is a solution to this problem. i have the same problem with fujifilm j150w and this stupid error usually happens when you are at the height of excitement in taking pictures. it is sooooo annoying.
a temporary solution to it though is just format the stupid memory card using the stupid digicam. you can still you it though. but you can't depend on the digicam for special occasions and important events. i really dont think its worth it
Jun 25, 2009 | Fuji FinePix A400 Digital Camera
Yellowish line on LCD, pics, and video. Digital zoom gets rid of this problem, but isn't acceptable.
Fuji is Good in warranty dont worry
ur problem might be small as some dirt inside the lens or
might be big as CCD Fault but very rare in this model
kindly call Fuji for the repair FREE offcourse they are a good company and very good at customer support
Pls rate me WELL !
May 22, 2009 | Fuji J150w Digital Camera
Fujifilm finepix j150w has slow shutter speed
Most digital compact cameras suffer from this shutter lag, though some cameras have managed to reduce it considerably. This is normal.
Feb 14, 2009 | Fuji J150w Digital Camera
Communication Error
Try connecting the camera to another computer. Is the camera reading the same error? If not, it's a computer issue.
If the camera is reading the same error, see if there's a way to restore camera back to the factory settings, and try all over again. Good luck :)
Apr 07, 2008 | Fuji FinePix S5100 Digital Camera
Cameras Logo
180 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
