Question about Ovens
Ge electric broiler inoperative
Merry Christmas!
My JBP26GV3 electric oven broiler and temp sensor went out. Replaced both. Temp is now good but broiler and self-clean won't work. What's the next step?
From what little I could find, it might be a fuse on the mother board.
Thanks,
- Peter Birren   Elk Grove IL
  • peterb01 Dec 20, 2007
    Yes, the clock and timer are functioning normally. The door locks and self-clean appears to start but the broiler element, after being replaced, doesn't turn on either in self-clean or in broil mode.
    What's the next thing to check?
    Thanks,
    - Peter
  • peterb01 Dec 21, 2007
    Thanks. I'll do it this weekend and inform you if successful or not. Are there any fuses or fusable links to be aware of, or any particular readings other than opens or shorts?
    I'm a former USAF aircraft radio repairman so I know about different readings as well as the normal precautions... but ovens are not radios!
    Sergeant:
    Champion:
  • 298 Answers
Link to manual
check page 22 for self cleaning oven
(door is latched )
make sure clock and timer are operative
Posted on Dec 20, 2007
  • Eugene Merritt Dec 21, 2007
    That leaves only the wiring terminals & ground
    connections.disconnect power and check wiiring
    terminals, grounds etc
    There was no mention of fuses in the users manual
    make sure power is off to the range fron the breaker
    panel. check at the plug to be sure power is off berfore
    checking anything Maybe theres a wiring diagram on
    the range somewhere
I have a self-cleaning older Frigidaire oven RE36BNL*2 and have had several power interuptions. I went to use the oven and the timer and oven controls won't work. There is an OFF displayed and it...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
My Frigidaire FEFL77ABF gets way too hot. When set at 350, temp soars to over 450. Have cleaned oven and tried resetting procedure, but neither worked. High temps are not consistent, so I can't...
Hi
Daniel
Aug 02, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
F2 error code while in self-cleaning mode
Hi
F2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Mar 20, 2011 | GE JTP15 Electric Single Oven
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Temp control
No adjustment. Could be bad temp control unit or bad oven temp sensor. You would have to purchase a repair manual and test the current flow to and from the circuit. And then testing the oven temp unit with multi-tester.
Jul 23, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
May 22, 2009 | Stoves Ovens
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
GE JTP56 Double Oven
Hello there,
This may be related to the F7 problem even if you are not getting an error message. Go to my web site at the following link:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
Please let me know if this works for you. I have sent my fix to over 1300 folks.
Good Luck,
Powerman
Oct 20, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
108 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
