Question about Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A
5MONTH CHESTFREEZER WHICH WAS WORKING .PUT IT IN SOTRAGE FOR 3MONTHS NOW IT WONT FREEZE WHY CAN IT BE FIXED WHAT IS CAUSES IT NOT TO FREEZE NOW
I am having this problem also with my freezer not freezin after been unplugged for about 3 months, is it just stuck in refrost mode and if so what do I do? I has been plugged back up for the past 5 days and nothing but a hot freezer...yuck
Posted on Apr 21, 2010
Where is controller knob on freezer
Brenda, haier freezer control quite often front lower right corner, some may be behind freezer by compressor, check the links to see if you can find your model and manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://image.haier.com/manual/southeastasia/haier/freezer/chestfreezer/201203/P020120309357074931017.pdf
Haier Freezer manuals
Haier Freezer controls Google Search
Jun 12, 2016 | Haier Freezers
My ge freezer wont freeze
Did you lay it down when you moved?, if so you may have oil in the lines . Did you bump any Freon lines and cause a leak?
Aug 31, 2014 | Freezers
Zanussi freezer Zut 6246. Superfreeze button won't go off
Probably is switch for fast freezing mechanically defective.
Dado
Apr 07, 2014 | Zanussi Freezers
17 cu fridgeidaire freezer wont freeze
More than likely the compressor is bad. A lot of times technicians will change the start device on the compressor and if it runs for a minute they are satisfied its fixed. The proper way would have been to monitor the amperage drawn by the compressor and then there would be no doubr if it was start device or compressor.
Mar 31, 2012 | Avanti Freezers
Carpingani 161 wont freeze --plenty of gas in machine
if there is gas in it. no frost buid up and the evap coil isnt crested all the way across. then you have a blocked filter. your gage will give an inconsistant reading when the filter is blocked. may read normal but other times will give a higher or lower reading. try changing the filter. the other thing i see is the compressor maybe too weak for the freezed. very common that the manufacture has put a small compressor that may only work adequetly for a few years.
Aug 01, 2010 | Freezers
My chest freezer does not freeze over 80% of the case.it only freezes a small seccion of the upper part of the case.
This one sounds just like a refrigeration problem.
If the freon leaked out then it will definitely do this...
I would recommend to get a new freezer here's why.
if you call someone to put the freon back in it will cost you anywhere from $80 to $150. it will freeze and work good but eventually it will go back to the same problem because the tech did not fix it only put it back in... its just a matter of time then you have the same problem... save your money and move it to a new one...
hope this was helpful
Mar 06, 2010 | Whirlpool 14.8 cu. ft. Chest Freezer...
Bottom 2 shelves not freezing
if it does not freeze it is because the refrigeration system is low on freon. this will cause the bottom shelfs to not freeze...
you have to decide if it is worth putting the freon back in (they wont fix it because very hard to find)
so you could spend anywhere from $80 to $150 to get the freon back in... then after a while it will leaks out and you will have the same problem
why dont you instead move that money to a new freezer
Mar 04, 2010 | Freezers
I have a media dishwasher, it's new. works but
possibly your drain hose is blocked maybe packaging or something if it is new did you have another one before this if not check you have drilled out the drain spigot under the sink if this is where you connected your hose let me know how you went
Nov 12, 2009 | Midea Chest Freezer MCCF10WMD
COMPRESSOR WILL FREEZE A CYCLE OR 2 THEN STOP WORKING
a symptom of low refrigerrant is that the evaporator coil will develop a small very cold area but wont cool the entire surface .. that cold area can ice up and block air flow .. the result can be an overworked compressor with little or no cooling ... other things that can cause the same trouble
1. bad or blocked air flow on the external coils or condenser fan ..
2. a leak in the door seal will allow moisture that can cause icing
if there is icing then you can turn it off with the door open until the ice melts .. then start over ..
Jul 24, 2009 | Freezers
New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Feb 04, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A Logo
126 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
