Question about ADIC TV Superscan 2 (SFN-201RACADEMIC)
Tv remote code
Superscan sss2435 35 inch sears tv on dish cable need remote code for oneremote to controls all functions
0 characters
1 Points
I need code number
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
Jun 23, 2016 | Apex Digital DT250A Digital TV Converter...
Need codes for radioshack 4 in 1 universal remote for apex tv converter box
The code(s), if applicable, are stored in the remote. Use the code search feature to find one that will handle some or all functions of your Apex STB. If unsuccessful, you may have to try a different universal remote. All universal remotes do not store all possible codes.
May 02, 2016 | Apex Digital DT250A Digital TV Converter...
If your Bright Star remote is programmable, you probably have a "code search" function that you can use to find a code that will control your Sansui TV. If a thorough search through all codes stored in the remote produces no result, you may have to try another programmable remote.
Sep 11, 2014 | TV Accessories
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | TV Accessories
Magnavox converter box codes
There are no available codes for these, if you are using an universal remote, use the scan function. Typically when scanning you hold down setup on the remote, press SAT/Cable, then power. If it doesn't shut off the box, you press Channel up, and power again. Repeat the Ch. Up and power to keep going to the next code. When you do find the correct code the converter box will power off when you hit power. Press Enter on the remote to store that code for SAT/Cable. Enjoy
Dec 18, 2011 | Magnavox (TB100MG9) Video Converter
Need code for magnavox television with cable (remote control urc-3220)
URC 3220 One for All Big Easy Remote Control
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Magnavox TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Oct 22, 2009 | Philips TV Tuner Video Capture PCI Card -...
Is my tv digital ready?
If you have cable or satelite hooked up to it now and it works,Then it is digital ready.
Please rate this a fixya
Feb 13, 2009 | A D S TV Superscan 2 (SFN-201)
My Superscan tv will not stay on. How do I fix it?
the vcr tape mechanism may not be all the way up or the tape sensors need to be cleaned or replaced
you can test for voltage on the sensors and test each sensor for an open
Nov 26, 2008 | A D S TV Superscan 2 (SFN-201)
Innovage jumbo universal remote code
try this website, you have to scroll down and find "Innovage" on the list and then it will download the pdf of the manual.
Dec 28, 2007 | TV Accessories
you must opend the set to remove manualy the cd, the mecanims coul be staket, or a damage driver circuit is causing the problem, I has found both in the past, any how dont doit your self if you dont know about tvs, there are verry dangerous parts in tv circuit, get a tech....good luck
Aug 08, 2006 | A D S TV Superscan 2 (SFN-201)
ADIC TV Superscan 2 (SFN-201RACADEMIC) Logo
113 people viewed this question
Top ADIC TV Accessories Experts
Brian Sullivan
Brian Sullivan
Are you an ADIC TV Accessory Expert? Answer questions, earn points and help others
