Question about Freedom Health & Beauty
IF U PLUG IN YOUR SCOOTER AND THE LIGHTS BLINK ON AND OFF NON-STOP TILL U DISCONNECT.. IS IT UR BATTERY OR CHARGER THATS BAD?
  • Will May 11, 2010
    are you turning your chair off? What lights are blinking? It is common for the controller to blink to indicate it is plugged into the wall, it's the inhibit to keep you from pulling the plug out of the wall
  • Freedom Master
  • 1,271 Answers
Please try another charger, and check the connections to the batteries,
If you can try another batteries,
Regards
GeWiz.
Posted on Oct 03, 2009
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
Jan 14, 2014 | Pride New Mobility Victory XL 4 Wheel...
Rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
Battery charger indicating that batteries are fully charged, but battery meter on the scooter shows no power at all. also the lights, indicaters etc arent working, im presuming that is resulting from the...
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
Mar 14, 2011 | Pride New Mobility Victory XL 4 Wheel...
Battery is charged, scooter is assembled, but when the key is turned on, the scooter and all gauges are dead
Has the scooter been sitting unused for a while? Will the horn honk when the scooter is connected to the charger?
If the batteries are charged and NO LIGHTS come on at all when you turn the scooter on, please check all of your connections, most importantly the fuses as your circuit may be incomplete.
If there was any power getting to the scooter at all, the lights would at least blink to let you know there was a problem.
When batteries sit for a while they will oxidize and go solid which may prevent them from getting a full charge. The charger shows them as full but it is just the current bouncing back from the solid core. Try replacing the batteries to see if that solves the problem, if not, contact the manufacturer.
Dec 18, 2010 | Health & Beauty
My mobility scooter batteries are put on charge but the charger green light to indicate that they are chaged no longer lights up
hi, now that could be one of three problems,
1. first check the charger ,is it possible to try the charger on another scooter ?
2. The batteries will no longer accept a charge ,this creates a fault condition with the charger. (try these batteries on another scooter if possible).
3. the actual charger plug in, you need to check the pins here , just the outside ones with a electrical meter, no voltage implies a bad connection to the batteries.
Regards
GeWiz
Please rate this reply.
Apr 22, 2010 | RTO Mobil Line Mobility Scooter Chair...
On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Jan 25, 2009 | Razor E100 Electric Scooter
Health & Beauty Logo
199 people viewed this question
Top Freedom Health & Beauty Experts
Robin Hill
Robin Hill
 steve
steve
Tom Chichester
Are you a Freedom Health and Beauty Expert? Answer questions, earn points and help others
