Question about Maytag Neptune FAV6800AW Top Load Washer
Apron stuck under the spinner
After the washing machine has finished washing all the clothes, I took them out and found out that an apron was stuck under the spinner, and only a corner of the apron was appeared, and the rest hte part i think was spun under the spinner. I tried so hard to pulled it out but i couldn't, is there a way to lift or take out the spinner, so i can remove the apron...please help me with this problem...
  • 335 Answers
Hello blubear0105 ,
Download the Service Manual and take a look at Page 37 “Tumbler Removal” You will need a #20 Torx driver to remove the tumbler the SM doesn’t call that out. It’s easy to remove, post back if you have any questions. Rich
The Service Manual for reference. Sears Parts Direct for reference.
Posted on Oct 02, 2009
Clothes stuck under the agitator
I have the same problem with clothing getting trapped under the agitator. Strings from Hoodies, apron strings, bra straps be caught under it all the time. There is a gab between the agitator and the tub. I have owned the machine for about 3 months, I like it in all other respects but this is crazy!! I have never had a machine that did this. GE needs to address this and fix this issue. It is NOT a matter of making sure your pockets are empty before washing, anything that is thin such as a strap or a string gets caught!! I would think twice about buying this machine if you are looking to purchase it. I don't think this machine will last as long as my others, and I don't think I would recommend this machine due to this very annoying issue.
Jul 17, 2012 | GE Washing Machines
Money fell under the spinner
I take it that you mean that there is monetary coin or coins stuck between the Wash Bowl and the Spin Bowl. If the diameter of the coinage is greater than the Wash Bowl outlet, the coins will never find their way to the emptying pump of the machine, and will continue to rattle around inside. However any of the coins can enter the Wash Bowl outlet this could result in the water pump becoming jammed or damaged requiring replacement. I have solved this problem by removing the top of the machine (HOB) above the washbowl then completely removing the shroud over the Wash Bowl...then replacing the top of the machine firmly. By then turning the machine upside down, the coins will drop out and can be retrieved. Finish the job by returning the machine to the upright position.
Oct 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Apron caught under wringer
Hi Karen,
That is a real pain when that happens, but let me see if I can help.
First on the top of the agitator or wringer you will see a small cover. You will need to pop that off to reveal the screw hidden underneath. Remove the screw and then the agitator will pull upward and off. The agitator on the hotpoint washing machine is really hard to pull off so you will really have to pull. When the agitator comes loose you will ofter be pulling so hard that you could hurt your arm on the top of the tub so be extra careful or get some guy to get hurt for you. Once removed I am sure the apron can be easily removed and all will be well again. Good luck to you and please dont forget to rate me. Have a nice day.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Oct 28, 2008 | Hotpoint Washing Machines
The spinner gets off balanced make knocking sound
Ok first is it a top load or front load and I need the model number inside the lid or door.
Sep 23, 2008 | Kenmore 24032\24036 Top Load Washer
A t-shirt is stuck under agitator/spinner thing. How do I lift off the spin assembly?
yes, remove the softener dispenser at the top of the agitator and there is a bolt there that is holding the agitator assembly. if you remove that bolt, the whole piece can be pull out and you can remove the clothe that was stuck in there.
tnx 4 using fixya,
drcool
Sep 06, 2008 | Kenmore 24032\24036 Top Load Washer
My washing machine is not draining the water properly,so when i do a wash, the clothes inside after its finished are still soaking wet and then i have to manually drain the water from the clothes. I have...
  • That the outlet hose is not kinked or raised more than 40° from the floor.
  • If you wish to remove articles when the water will not pump out, place the end of the drain hose into a bucket on the floor and allow water to drain out by gravity, noting that more than one bucketful may be present. Hook the hose into the sink again and try the spinner before removing the articles - if this fails most of the water can be baled out with a cup.
  • If the above method fails to remove the water then the pump is probably blocked - do not open the door, but contact your nearest Service Engineer.
  • Thanks for using Fixya!
    Aug 26, 2008 | LG Washing Machines
    Maytag washer top load
    good guess...is the washer balanced? That can make the spin cycle work ineffectively.
    Feb 15, 2008 | Washing Machines
    Maytag Neptune FAV6800AW Top Load Washer Logo
    134 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
