Question about HP PSC 1410 All-In-One InkJet Printer
We had a cartridge error. We refilled and replaced the cartridges but still have a cartridge error. We have restarted and unplugged and replugged the printer a couple of times and still have the cartridge error light on. The last time the pc was restarted and the printer was un and replugged, it printed a calibration sheet but now 3 hours later, the cartridge error light came back on.
  • 159 Answers
Your cartridge has something wrong with its electronics. There is no way to "fix" this problem. The reason you could print a calibration sheet is because the printer does not need an electrically functioning cartridge to print this test page. You need to purchase an ink cartridge that has good electronics on it. It doesn't matter if you get a refill or original manufacturer cartridge.
Posted on Dec 30, 2009
I replaced my tri colour cartridge on hp2540 and keep getting message i need to buy hp cartridge how do i get it to print
1) If you replaced it with a refilled cartridge you may need the "latest" version of the cartridge in order to print with refills. See this link for more information: Updated HP 61 301 122 and 802 Ink Cartridges
If this cartridge is from their monthly print program you will not be able to refill it and taking it out and replacing it in the same printer can also through an error code.
2) Have you tried turning off the printer, unplugging it "FROM THE WALL" for three minutes and replugging it back in and turning it back on?
3) If one or the other cartridges have electronic problems, it will not print.
4)If an update was done on your printer software? Sometimes this will not allow you to use anything but HP. However, sometimes if you use an genuine HP and then go back to the refill it will reset it and work again.
Hope this helps you to understand this printer cartridge.
Jan 15, 2015 | HP Office Equipment & Supplies
I have a Canon iP6700D. I refill my carts. I have a resetter and use it every time. This time the printer won't recognize the magenta cart. I refilled it, reset it and replaced it as always. I...
If your printer did not good in times of reseting the cartridges do check the cartridge holder if the is some dirt inside or the terminal of your cartridge had wet by the ink when you refill the ink of your cartridges.
Aug 12, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
How to error e5 how to go to service mode
Hum....e5 error.
The truth is...there is no solution for e5 error.
U may see some solutions through web, however, non of them works..
The only way you can get out of e5 error, replace with new cartridge..
or...
prevent it...before you face it!!
How?
Whenever you take out the cartridge from printer, make sure unplug the power code first..
and then take and refill or whatever...
And then when you put it back....do it when power code is unplugged as well.
Personally, I refilled and used CL831 more than 8 times..
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 19, 2011 | Canon PIXMA MP150 All-In-One InkJet...
U051 error message. Won't print
Well, you must be using PG30, CL31 cartridge for your printer.
Did you refill your cartridge?
For error 051 means printer is not reading the cartridge. (cartridge is not readable)
When you put refilled cartridge, that's what it happens.
(after 3~4 times of color refill, color cartridge is no long to use, only applies in Canon
and there is no solution for it.)
Pls replace with new one.. and will work again.
Or if you need to refill again with other cartridge, pls....unplug your printer before you taking out the cartridge. In this way, you can re use your cartridge. Little trick... but no solution will work, once cartridge is not readable.
May 11, 2011 | Canon PIXMA MP470 All-in-One Printer
Printer said always that right cartridge incorrect. I have used 35color print cartridge and changed many times and do not work.
Try to remove the cartridges from your printer. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Also, make sure you are using genuine Lexmark cartridges. A refilled/remanufactured cartridge by third-parties might not have the quality compared to genuine ones. If error continues, please contact Lexmark technical support for additional assistance.
May 07, 2011 | Lexmark X5495 Printer
Error 50c
The 50c error indicates that your cartridges or one of your cartridges has shorted. Please check which cartridge is causing the error. Remove both cartridges from the printer and close the cover. Unplug and replug the printer to the power source to reset it. When the printer turns on, insert one cartridge first and close the cover. If no error appears, insert the other cartridge. Replace whichever cartridge is causing the error. I hope this information has been helpful. Thanks.
Dec 12, 2010 | Lexmark X5150 All-In-One InkJet Printer
What does the cartridge error code 50c mean and how do I fix my printer?
The error indicates that your print cartridge has shorted. Check which cartridge is causing the error. Remove both cartridges from the printer. Close the cover. Unplug and replug your Lexmark printer to the power source. When the printer turns on, install one cartridge first and close the cover. If no error appears, insert the other cartridge. Replace whichever cartridge is causing the problem. Hope this helps. Thanks.
Nov 10, 2010 | Lexmark C533DN InkJet Printer
I have a lexmark 7300 and I've been refilling my cartridges @ cartridge world, but this time my printer is saying Right Cartridge incorrect! And I've tried to clean it and even tried a different cartridge,...
make sure to properly seat the cartridge
unplug the printer...replug it
buy a BRAND NAME cartridge
P.S: don't have your cartridges refilled, it may void the warranty and damage the printer if done wrong
hope this helps
Apr 10, 2008 | Office Equipment & Supplies
HP PSC 1410 All-In-One InkJet Printer Logo
297 people viewed this question
Seeker5211
Seeker5211
