Question about Mtd LAWN MOWER PART # 791-180705 Assembly, 13.5" 135 GU
The second gear is not working sometime
Help me
  • Chuck
    Chuck May 11, 2010
    WHAT IS YOUR MODEL AND SERIAL NUMBER!!! ?????
  • 78 Answers
Im sorry the number you have posted is NOT a valid number
Posted on Oct 22, 2009
2006 yzf600r when shifting to 2nd get a loud,fast,hard knocking. I can hit the clutch and rev up fast and go to 3rd,or if not the bike will roll about 15 ft and stop then I got to turn the bike off to...
sounds like the shift rod is worn its a common problem in sports bikes if they have been shifted a lot without the clutch most of the time they get where they will kick out of second gear on there own but sometimes they can get stuck in second depending on how the wear has gone
Nov 14, 2013 | 1997 Yamaha YZF 600 R thunder cat
1991 dodge stealth es transmission
The only thing cheaper is to drain the fluid and replace with the correct fluid and ask the Parts Salesman of what additive might work best in your transmission. Check the Fluid in the Clutch Cylinder. Bleed it after it is topped off.This could help.
Feb 13, 2013 | Dodge Stealth Cars & Trucks
Hello, My car transmission (auto) seems to disengage for too long sometimes when changing gears. The revs will raise up but then after a second or two drop back into gear. It seems to happen when i a
I tried the DIY service and repair manuals from a website and it actually helped me
repair transmission problem in my ford explorer. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.com
Feb 26, 2018 | 1996 Subaru Legacy
I have a problem with the reserve on my car sometimes it works and sometimes it doesn't when I can't get reserve first and second gear is in reverse position on Volskwagen Passet 1994
pardo me for asking but is there not a method of selection of rverse gear by either pressing or lifting the gear lever so it will move over further so as to select reverse? or a lift up circular boss on gear lever itself that has to be lifted then reverse position can be selected ? hope this helps ?
Dec 19, 2009 | 1997 Volkswagen Passat
Crunching Gears
thats common for the reverse gear to grind if you go right for it i always go to fist then reverse. it sounds like you might have a week slave cylinder and the pressure is to low to go into a high gear does this happen in 5 th also or only 3 rd?
Jun 10, 2009 | Toyota Yaris Cars & Trucks
Transmission wont shift until about 4000rpms from 1st to 2nd gea
Have a code check done and see if speed sensor or controller is working properly. if bought from a dealer, get it back there asap...they can't sell it in that condition!!...No test drive before you ploped down your money?
Apr 16, 2009 | 2004 Jeep Grand Cherokee
DIFFICULTY ENGAGING SECOND GEAR
the transmission needs to be taken apart and have the second gear synchro replaced. i would start with just have BG sychro shift put in at a local shop that sells BG. that will help with the problem.
Jan 17, 2009 | 1999 Audi A4
A klicksound like a slipping gear every 4th second and no copying working
is this a laser machine that takes dry toner if it is it sounds like it is out of toner.
Nov 04, 2008 | Sharp AL-1217 Copier
Mtd LAWN MOWER PART # 791-180705 Assembly, 13.5" 135 GU Logo
37 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
