Question about Dell Dimension 5100 (D51L1) PC Desktop
Blue screen error with stop code 0 X 000000ed. Also when test was performed I got a Drive 0: WDC WD1600JS-75MHBO-Fail Return Code 7
  • 3,940 Answers
Unmountable Boot Volumes almost always indicate a failure of the hard drive. You can try running CHKDSK /R from recovery console or a clean installation of Windows. If those fail, replace the hard drive.
Posted on Oct 02, 2009
Drive 1 wdc wd10eads 00m200 fail return code 7 dell
looks like your drive is failing,go to safe mode on start up back everything up ,it could fail today or next year there is no time scale on the drives,just back up and replace it to be on safe side,make sure u get correct drive or bigger if possible ,then put your stuff back on good look.
Oct 09, 2013 | Dell Computers & Internet
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
WHERE SHOULD JUMPERS BE SET ON WD1600 SSC / PM2 /OPT1 /OPT2 ????? USED AS A SINGLE DRIVE
hi wiggbone
Western Digital is usually given a choice, do not put the jumper to set the disk to a single drive / master, or you can refer to the stickers that were pasted on the hard disk
thanks and regards
Dec 08, 2010 | Western Digital Caviar SE WD1600JS...
Windows has stopped this device because it has reported problems. (Code 43)
This is some information on from the Western Digital website: information library.
http://www.wdc.com/en/library/index.asp?language=en
0009 - 0014 SMART Error Self Monitoring, Analysis, and Reporting Technology (SMART) Error returned during SMART Status/Self Test Command. Retest the drive. Replace the drive if the error repeats. Re-test Drive
Sep 09, 2010 | Western Digital My Book Essential 500GB...
On start up it blue screens. HD check gvies Return Code 7
The hard disk is dead. To recover some of your files from it just boot from a Linux Live-CD like   http:pclinuxos.com/  and copy whatever you can recover to a USB memory stick.
May 19, 2010 | Dell Dimension 3100 PC Desktop
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
When turning on, all I get is a balck screen w/ a
Your hard drive may be dead, the partition/boot sector is damaged or the motherboard seiral ata chip is bad. If it is one of the first two you will need to delete the partition, re-create the partition and format the drive. Take the drive out and install it in another computer as a slave and see if the drive is recognized and files are all there. If it works in the other computer try backing up the drive and then re-install it in the problem computer and try to format and re-install the system either using the installation discs that came with the computer. If the system utility to restore the computer is located on the drive you might have an issue. You can try using that utility if you have it and it may or may not work.
Sep 25, 2009 | Dell OptiPlex GX270 PC Desktop
Return code: 7
sounds like you need a new hardrive, i would reccomend getting a replacement drive and then hooking up the dead/dying hardrive up as slave to recover what you can, disabling S.M.A.R.T might get you to a situation where you can get what you need and then bin the drive
Sep 25, 2009 | Computers & Internet
Dell Dimension 5100 (D51L1) PC Desktop Logo
2,002 people viewed this question
Alun Cox
