Question about Poulan "Poulan" Push Mower
I need an intake for a poulin push mower with a
I need an intake for a poulin push mower with a 6.5 B&S quantum engin and there are no part numbers anywhere on the engine how do i get the part ?
  • Paul Marks Jul 28, 2012
    howdie the no. youare lookin for is on the cover of the lawnmower it will be stamped in the cover all what you need
  • 148 Answers
"Model-Type-Code" numbers on a Quantum Series are usually located on the sheet metal right above the muffler. If not there, remove the plastic cover from the blower housing and check on the blower housing near the spark plug wire.
Hope this helps
Posted on Oct 02, 2009
What are the torques on a 22hp ohv briggs and stratton head and also push rods
VERIFY your engine model numbers
Briggs & Stratton Intek V-Twin
Engine Model Numbers 407777 and 44P777
Cylinders 2 (Dual cylinder)
ITEM N m (Newton metres) lb-in Spark Plug Torque 20 180 Back Plate (to cylinder) 11 100 Blower Housing Screws 9 80 Breather Screws 6 55 Carburetor to Manifold 7 65 Cylinder Head Bolts 25 220 Cylinder Shield 7 65 Crankcase Cover 23 200 Engine Mounting Bolts 48 35 lb-ft Electric Clutch Mounting Bolt 75 55 lb-ft Exhaust Manifold 16 140 Fan Retainer Bolts 16 140 Flywheel Nut 203 150 lb-ft Armature Mounting Screws 3 25 Intake Manifold Bolts 9 80 Rocker Arm Adjustment Lock Nut 7 62 Rocker Support Screws 11.3 100 Valve Cover Cap Screws 11 100 Carburetor to Intake 7 65 Valve Clearance (Cold) 0.10-0.13 mm (0.004-0.005 in)
WARNING: Uneven tightening will warp the head. Tighten Cylinder Head Bolts down evenly by hand. Then using torque wrench tighten in sequence, in 9 N m (80 lb-in) increments to 25 N m (220 lb-in).
Intake valve push rods are aluminum.
Exhaust valve push rods are steel.
DO NOT interchange push rods.
Removal and Re-installation sequence for bolt removal and tightening.
Mar 21, 2015 | Garden
Manual for briggs and stratton 12000 series mowers quantum
B/S makes the motors for several brands of mowers. Go to the web site and search your model for a download.
Oct 07, 2014 | Briggs & Stratton Quantum Lawn Mower...
Quantum 4hp powerpro
you have a blocked primer passage take off filter huosing blow dirt out of passage and out of prmerball it might be bad enough to rebuild carb
Jul 05, 2014 | Garden
What is the correct gap setting for a Champion RJ2YLE spark plug used in a Toro Lawn mower?
Briggs & Stratton Part Number 799876 replaces Champion plug RJ2YLE. For use in Quantum Series 625, 675, and 725 engines built after Date Code 110701xx. The gap for this spark plug should be set to .020". This spark plug should not be used with Quantum Series 625, 675, and 725 engines built before Date Code 110701xx, or any other L-head engine family.
Apr 20, 2013 | Toro Garden
Powerkraft ultimate 3n1 5.5/21 quantum power
Where can I find carburetor kit for
Powerkraft Ultimate 3n1 5.25/21 quantum power push lawn mower
please advise.
Vince
Apr 22, 2012 | Snapper 217020b Lawn Mower Mowers...
I need a schematic drawing for a Poulan 445 PRO Chain Pole Saw
Go to this page:
http://www.jackssmallengines.com/help.cfm
Choose
1. Poulin
2. Poulin Pro
3. Pole Pruner
4. Gas
Then select either PP446E Type 1 or Type 2
If you need parts for the attachments then choose attachments and find yours.
This will get you straight to the engine:
http://www.jackssmallengines.com/help.cfm#AssemblyPartsSearch'model_3hfQcmydHGxAIk/GvlHpyA=='assembly_/GhQJfqNUvNbNmAjA03NAg=='brand_ahjxOQtsOoMBNqd6InjYkA==
Thanks for choosing FixYa.
Kelly
952-051549
Oct 02, 2010 | Garden
ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS, BUT THEN DIES, IF I CONTINUE TO PUSH PRIMER BULB IT KEEPS RUNNING, BUT STOPS AS SOON AS STOP.TROY-BILT SELF PROPELLED MOWER MODEL E189- BRIGGS&...
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Jun 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
What spark plug should be used for a Murray Quantum XNP 6.5hp mow
Home Depot has the plug you need for briggs 6.5hp engines. Don't worry about it being a Murray. Buy a Briggs 6.5hp plug.
Jun 26, 2009 | Garden
Wont stay running without pushing primer
Hi... I have a Poulan PRO Quantum xnp 6.75. Garage kept, unused approximately 2 yrs. Added fuel, primed & mower started but then shut down immediately. Then fuel began leaking from the primer button. I'm a single mom & CANNOT afford to have anyone fix this. However I am attempting to repair myself. PLEASE.... If you have any suggestions &/or solutions I would LOVE to know.
Apr 12, 2009 | Garden
Poulan "Poulan" Push Mower Logo
77 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
