Question about HP LaserJet 2420 Printer
2420 cleaning
Directions for cleaning cycle 2
Posted on Dec 28, 2007
Hp jeserjet 2420 printer problam how to remove error 55
Power cycle the printer.
If the error reoccurs replace the ECU board.
Oct 31, 2010 | HP LaserJet 2420 Printer
My printer hp 2420 same day I up side doun my
Clean the powder with inside with the blur. clean the toner drum from all the sides. shake a bit if still there is a power leakage then there is a problem in the toner,that needs to be fixed.
Jul 21, 2010 | HP LaserJet 2420 Printer
Hp laserjet 2420 paper jam 13.20.00
Hi, check throughout the printer for small pieces of paper stuck, broken sensors etc, clean the rollers in the paper tray 2, check for wear. clean the registration rollers (under a metal flap under the print cartridge) do not clean the transfer roller (the spongey roller sitting under the drum!)
Feb 09, 2010 | HP LaserJet 2420 Printer
HP Laserjet 2420 will not print from tray 2
Take out the toner cartridge and paper cassette , turn the printer upside down. The feed roller should not free wheel. Sometimes the roller ends break off,
Jan 28, 2009 | HP LaserJet 2420 Printer
Need Directions on how to change a maintenance kit for hp 2420
Hi Bromo381
Here is the link which gives you steps to change the maintenance Kit.
You need to copy the link and open it in Internet explorer and then when the page loads up click on the option that says HP LaserJet 9000 Series Maintenance Kit - Install Guide (multiple language) in the bottom of the page.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&docIndexId=64255&prodTypeId=329290&prodSeriesId=65013&lang=en&cc=us#2
all the very best for you.
Please do reply me back if there is any issues.
Jan 21, 2009 | HP LaserJet 2420 Printer
Hp 2420 vrtical line in page
This issue can be due to fuser. I am sure you have changed the toner cartridge.
To confirm its a fuser issue, please perform the following:
1. Try printing a configuration page from tray 1, pull the top cover, as soon as the media is 60-70% inside the printer.
This would stop the paper before reaching the fusing assy.
2. Remove the paper and check if the line exist.
If exists, fuser is not faulty.
If it does not, then transfer roller, laser/scanner assy is faulty
- If fuser is faulty, perform the cleaning page as following
1. go to configure device > print quality > create/process cleaning page
perform cleaning page 5-6 times, however, if the line is due to fuser, then fuser needs to be changed.
Let me know the next update.
- Nikhil
Nov 21, 2008 | HP LaserJet 2420 Printer
HP Laserjet 2420- Late Paper Jam
1) Your paper tray may be too full, makes it heavy to lift and not enough pressure for the pick up roller.
2) Pick up roller is slippery, wipe it clean with alcohol to make it abbrasive.
Apr 15, 2008 | HP LaserJet 2420 Printer
Keyboard laptop removal for acer 2420
I took it apart b4, and took them apart roughly (the notebook is now not with me) as follows:
1. Wiggle or pop out or take out the cover plate, i.e. the cover with power switch and lights
2. You will see 2 or 3 screws, unscrew them and then wiggle the keyboard out (pull the KB towards the screen direction).
3. Be very careful with the ribbon behind the keyboard .
The most diffiuclt part was to re-assemble the ribbon back to the motherboard. Its very easy and took about 10 minutes to replace the KB. Thats about it.
Sergio
Mar 13, 2008 | Computers & Internet
Print quality problem
Hi there sound to me like the toner cartridge is either faulty or leaking. Is it or has it been refilled if so remove cartridge vacuum out the insides of loose toner install brand new toner cartridge then test again. It cannot be the fuser unit as it will have quality problems all the time so try above and I hope it works for you.
Thanks J
Jan 14, 2008 | HP LaserJet 2420 Printer
Hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Nov 01, 2007 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
541 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
