Question about iLO DVDR05 DVD Recorder
Ilo dvd recorder is not working
Hello, when I connect the power suply cord, the DVD recorder produce a sound like a buzz. The display on the DVD player don't show nothing.Do you have any idea what is the problem. Regards
  • 2 more comments
  • Anonymous Feb 01, 2008
    SAME PROBLEM HERE
  • Anonymous Sep 08, 2008
    replaced the caps in the power supply
  • Anonymous Sep 19, 2008
    i have the same problem it won't come on either , it just buzz like a freekin bee
  • nrgreeleya Oct 29, 2008
    Mine is doing the exact same thing, When I first plugged the damn thing it came on no problems and then it turned off and, started making a whistling sound. Fudge!!!!
I have had the exact same problem with the buzzing and no power. I have been able to get mine to power up by first unplugging it from the wall and then plugging it back in...sometimes it takes several times of doing this to get it working again...not a fix but at least I can still get some use from it
Posted on Dec 29, 2008
I have replaced the caps today,2200uf and 1000uf all ten volt.(voltage on new parts are close enough-25v.),buzzing has stopped,everything comes on ,and it plays just like new again,this is actually an easy fix if you have the parts,and a solder gun,and the know how to put in these power supply caps correctly.Good luck.
Posted on Dec 24, 2008
Double check all you audio cables
Posted on Aug 27, 2008
How do i play a dvd movie in ilo dvdr05 dvd recorder
You may have to connect to a different output until you can change the settings back.
Dec 03, 2014 | iLO DVDR05 DVD Recorder
No power on when connected
Switch mode power supply is very difficult to troubleshoot even for an expert technician. All SMPS operate at high frequency. If you have a miltimeter that can detect frequency, You can set it to that, then get the red prob close to the switching transformer, you don't even have to touch it with the probe, and you will get a reading in thousands of hertz. If its working. A guide to fixing it is way too complicated.
Jun 28, 2009 | iLO DVDR05 DVD Recorder
Will not power up/"Hello" message will not go away/ Say's "Bad "
I have used my Protron portable DVD Player one time -- I am taking an overnight trip and tried to charge it up -- it will not charge, the LED light will not come on and it will not work when plugged in the a wall outlet. I can seem to get a toll-free support number -- please I do HELP!!
Apr 02, 2009 | iLO DVD Recorder DVDR05
Ilo dvd recorder do not recognize any dvd
According to www.dvdrhelp.com that this unit is very picky on what discs it will record on. Look up unit and read the large number of reviews in DVD Recorder section
Dec 25, 2008 | iLO DVDR05 DVD Recorder
Buzzing on DVD recorder when recording
The buzzing sound were feed back from power supply regulator if you can replace all of electrolytics capacitor in power supply block you will fix this problem or replace complet PCB
I need the correct model of your JVC DVD recorder
Dec 07, 2008 | Televison & Video
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Ilo DVD recorder Dvdr05
i have the same recorder i picked up for free in a thrift shop,does anyone know what to fix on power supply? it wont display anything..
Jun 08, 2008 | iLO DVDR05 DVD Recorder
Dvd player turns on and that's it
I have ILO dvd ro5/zu Burner walmart cheapy and I read Capacitors for power supply go bad and leak there are 2 (fuhjyyu 2200uf 10volt) also it runs very very hot so I put in an old computer fan to cool it down works great now, problems with clock flashing and humming noise while recording and playing back. It still has a little hum but other than that it works great 3-4 years old over 150 dvd's burned.
Sep 29, 2007 | iLO DVDR05 DVD Recorder
Mr ilo dvd R04 recorder is locked at the hello screen!!!!
The unit is not finishing the start up diagnostic. This could be forseveral reasons. The most common problem with the Ilo04 is power supply. On the power supply board check the two big capacitors to see if they are swollen or leaking. If so then change them and try that.
Jul 13, 2007 | iLO DVDRH04 DVD Recorder
Customer Support ILO DVDR05 Recorder
I got my dvd recorder at wal mart. I have used it for a few months but never recorded with it. A friend hooked it up a second time as I got another tv. The manual got misplaced, and I can't find it anywhere. So I wanted to record this tv special, and couldn't get it to record. I contacted wal mart to try to get a phone # to contact the manufacturer to send me another manual. Talk about a run around. I was told that sansui made it, then orion, then cyberhome, then liteon, and also that it was a wal mart brand product. Everyone passed the buck. I contacted ilo tv, hoping they would get me in touch with the dvd recorder/player dept., they gave me ilo service, and ilo help. Nothing, I got nothing from either site. One site I talked to said the company was raided by the government and was now defunct. That is why you can not reach them. When I tried cyberhome, I got to their site, but nothing on my recorder, just sales on different machines. From all the negativity I have heard and read about concerning this product, it is no wonder you can't reach them. And it says alot about wal mart, they won't stand behind their products and they too are just out to make a buck, to heck with the customer, just give me your money, as if they don't have enough of a monoply and billions of dollars already. So I suggest you save your money and get a name brand recorder and throw your ilo products in the trash where they belong. If you haven't experienced problems yet, you will. We all learned a lesson in trying to save a buck, don't count on wal mart, think before you give them your money, and buy name brand products, you might think they are more expensive but at least you know they will be around to stand behind their products.
Sep 05, 2006 | iLO DVDR05 DVD Recorder
iLO DVDR05 DVD Recorder Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
