Question about Cisco Universal Access Server AS2511-RJ Remote Access Server
What cables do i need to configure as2511-rj to my other router for reverse telnet - can you also send be the configuration
weaponx69
  • 58 Answers
SOURCE: cannot configure d-link 524 router to cable modem
Hmmm.... I would call the cable company and make sure that they are leasing an IP to your cable modem. I had this trouble one time when I had to move my wireless to another room. The procedure is to unplug everything and then reconnect them one by one starting with the cable modem. Since this router was used before, I would use the reset switch on the device to reset the router to factory settings before reconnecting it. Try that and see if it works. If it doesn't work then write back.
Posted on Jan 18, 2009
dante777
  • 623 Answers
SOURCE: configuration
That is a very good question, but that would take way more space than this forum offers. A good router tutorial, which covers the configuration from the IOS command-line interface can also be found here.
You should check out Cisco's page on EIGRP (link) or Petri's Blog about configuring EIGRP (link), but if routing protocols are in general a new thing for you, you will be better advised to get a book that covers all protocols, otherwise this might not make any sense to you.
Look for this:
CCNA - Cisco Certified Network Associate Study Guide by Todd Lammle, Publisher: Sybex
You can get it at amazon and it costs you only 20$ (used) or 30$ new including shipping. Here is a link.
If you have specific questions, I'm happy to help, but in the book it's already more than 60 pages on IRGP/EIGRP alone, so I don't really want to type that all up, plus you would need some general information as well.
Posted on May 22, 2009
dante777
  • 623 Answers
SOURCE: I would like to configure port fowarding on the CISCO 857 Router
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Oct 24, 2009
  • 30 Answers
SOURCE: VPN (ipsec)
the full instructions are here:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_configuration_example09186a008073e078.shtml
Posted on Dec 05, 2009
  • 163 Answers
SOURCE: i need router configuration password for Zyxel P-660H-D1 modem
Download a userguide from http://us.zyxel.com/Support/Download-Library-Result.aspx?mif=20050726121025
I think the password is 1234 for admin mode
Posted on Aug 01, 2010
Tip
Cisco 3925 Router Password Recovery
TheCisco 3925 router is part of a family of networking equipment produced byCisco, which has been a network equipment giant for many years. Used 3925routers are available on the Internet at reasonable prices, so acquiring one isnot difficult. However, if the password is unknown or lost, reconfiguration isimpossible until the password is reset or recovered.
Cisco has built in aprocedure for rescuing lost or forgotten passwords or entering new passwords.
ThingsYou'll Need: Serial to RJ-45 cable;Terminal emulation software
Instructions
1.Connect your computer to the router with the blue serial-to-RJ-45 cable thatcame with the router.
The 9-pin D-shell end connects to your computer's serialport, while the RJ-45 end connects to the console jack on the router.
The RJ-45end resembles a slightly larger telephone jack connector.
2.Turn on your computer and establish a terminal session to the 3925. You can use any terminal emulator, and many are freely available on the Internet.
Configure the session settings as follows:9600baud8data bitsNoparity1stop nonflowering controllable router's power cable into an electrical outlet, and as the 3925 boots, you should see the Cisco boot messages.
If you don't see any output on your computer's terminal session, check your settings on the session and restart itif necessary.
Press "Break" within 30 seconds of powering on the router to enter rommon (rom monitor) mode.
3.Type "confreg 0x2142" and press "Enter" at the "rommon1>" prompt. This will cause the router to boot from its internal flashmemory without loading the configuration into memory.
At the following"rommon 2>" prompt, type "reset" and press"Enter."
This will cause the router to reload and ignore thepreviously saved configuration file.
4.Respond "no" and press "Enter" when prompted for responsesto enter the initial dialog or basic management setup.
Type "enable"and press "Enter" at the following "Router>" prompt.This will put you into enable mode and display the "Router#" prompts.Copy the non-volatile memory into memory with the "copy start up-config running-config" command, followed by the "Enter" key. Type"sho run" at the prompt and press "Enter" to display the current configuration, including the passwords, some of which may be encrypted.
5.Type "config t" at the prompt and press "Enter." At the"Router(config)#" prompt, type "enable secret <pswd>"-- where "pswd" is the password -- and press "Enter." Atthis point, your enable password is reset. Press "Ctrl" +"z" to return to the "Router#" prompt.
6.Type "config t" at the "Router#" prompts and presses"Enter." At the "Router(config)#" prompt, type"config-register 0x02102" and press "Enter" to reset theboot register to its normal setting. Press "Ctrl" + "z" toleave configuration mode. Type "copy running-config startup-config"and press "Enter" to save your changes. Reboot the router and youshould be able to login with your password.
on Sep 05, 2011 | Computers & Internet
How to configure netgear router with hp laser jet pro L7380
you need not to configure the router. It seems that you wan't to connect the printer as a network printer through netgear router. In this case you need not to do anything with the router. Simply connect both the router and printer via a UTP cable crimped with RJ 45 on both end and give a static ip in the printers settings and that will become a network printer. Just take care about the subnet mask and other gateways they should be the same as your local network is using.
Jan 19, 2011 | Computers & Internet
Can i connect my xbox to my laptop /w pc usb
Xbox Network Connection using Hub
This is the most common network configuration and is also the easiest to setup.
Step #1: Plug your network cable(RJ-45 cable) that comes from your cable/DSL modem into the uplink port of your hub. (Make sure that your uplink is switched to "on").
Step #2: Take an RJ-45 cable and run it from one of the ports of the hub, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your hub directly to your xbox.
**NOTE** A switch may be used in place of a hub with the same basic setup.**
That's it! No other network changes should be needed for this configuration. Your Xbox is now on the same network as your PC.
Xbox Network Connection using Router
This is another common network configuration.
Step #1: Plug your network cable(RJ-45 cable) that comes from your modem into the WAN port of your router.
Step #2: Take an RJ-45 cable and run it from one of the ports of the router, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your router directly to your xbox.
**NOTE** In steps #2 and #3, you should not use a port that is directly beside the "uplink" port on your router, if your uplink port is being used to connect to another routing device.** If your router has a built in firewall, you will need to forward ports 8602 both incoming and outgoing to the internal ip address of your pc. Consult your device manaul for port forwarding.
That's it! Your Xbox is now on the same network as your PC
Xbox Network Connection using Crossover Cable
This is the last network configuration. For this setup you need at least one NIC card.
Step #1: Plug your USB cable that comes from your modem into your PC's USB port. This should already be done, if you have a usb modem for your current internet connection.
Step #2: Take an RJ-45 cable and run it from an installed NIC card on your PC, directly to the Xbox.
**NOTE** A crossover cable is only needed if you are connecting the Xbox directly to the second NIC card. If you have a device such as a switch, hub or router in between you should use a standard RJ-45 cable. This type of network setup also requires "Winroute©", a program downloadable from the world wide web. Consult the manual for specific instructions on how to set this up. Also if you have a USB ethernet adapter, you may use any of the setups described herein. USB ethernet adapter basically converts a USB cable into an RJ-45 cable.
That's it! Your Xbox is now on the same network as your PC.
Aug 14, 2009 | Video Game Consoles & Games
Adtran Telnet
Are you getting any failure msgs? Where are you telnetting from? Has your router been restarted? If you have web access turned on the router, you might be able to login via your browser, or you could directly connect to your router via a console cable to check your configuration.
Jun 23, 2009 | Adtran Total Access 850 Router...
I have a 2wire HG-B modem/router and I want to extend my wireless network by using a Hawking HWRN1A router. How do I configure my 2wire with my Hawking router, so it can work?
this hint is only possible if your hawking can be used a an access poit. if yes then try try the following:
connect you adsl line into your modem/router,
connect the lan cable of your modem into a switch
connect both your PC and Hawking into the switch
have your modem/router provide DHCP and DNS
configure your PC to gte its ip address and DNS dynamically
configure your hawking access point to also get its dns and dhcp dynamically (do this by getting into the hawking http page configuration, or telnet if you are good with commands)
now set a wireless lan with WPA or higher through your hawking.
there you have it.
doubts??? i have more solutions
Mar 23, 2009 | 2wire Computers & Internet
Configuring remote access
Here is a document which describes this.
Please download, it then:
1. Connect the console.
2. Configure ip address of the router
3. Enable telnet access.
Here is the document location:
http://www.adtran.com/adtranpx/Doc/0/UL9SGGEDF2I4D51F3K4IIEE2FC/61202860L1-13B.pdf
Jan 09, 2009 | Adtran NetVanta 3200 Router
Troubleshooting
Telnet is an application layer protocol. If you can telnet to the other router, then you do not have any network issues. However, the fact that you can telnet but not ping suggests that icmp messages have been blocked in the configuration of one or both routers. This is a security feature, because attacks can be launched via icmp messages.
Apr 18, 2008 | Computers & Internet
About adding ptinter
no issues first configure the ROUTER DHCP>and the printer have a ether net port-RJ-45 jack>so run a CAT-5 cable from printer to one of the ether net jack on the router if teh printer is wire less then configure w/l on the router the mode is mixed>and configure the printer like the way and reboot rate me solved if its helped or more info let me know
Oct 23, 2007 | Linksys Wireless-G RVS4000 Router
Configuring of ISDN Router
you can telnet by going to Start, run, type "telnet 192.168.1.1" hit enter a black window will open and your in the router. Youl have to call your ISP for the propper settings.
Aug 29, 2007 | Microsoft Office Outlook 2003 for PC
Cisco Universal Access Server AS2511-RJ Remote Access Server Logo
191 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
