Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Were to but mitsubishi lamp 915P028010
I have a Mitsubishi WD 62526 and i''m having problem were to buy a lamp cartridge type 915P028010. and how much it cost...please can any one can help me.
  • 68 Answers
TRY ENCOMPASS.COM THEY HAVE SEVERAL SELECTIONS AND DIFFERENT PRICES
Posted on Oct 02, 2009
  • 37 Answers
You can google 915P028010 and get a variety of hits. Be careful where you buy though. There are a lot of lamp variations. Some companies are selling the bare bulb and neglect to tell you that when you place the order. This option is fine for the mechanically inclined, but it is not for everyone. You also can find generic (original copies), hybrids or "Diamond" (generic lamps that use the original bulb) and original complete lamp assemblies.
Posted on Oct 22, 2009
Mitsubishi WD-62526 turns on-n-off
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Dec 12, 2013 | Mitsubishi WD-62526 Projection TV
Don't know how to take out the lamp
If you're looking at the tv from the back there is a square shaped panel with 2 screws on the extreme left side. Unplug your tv and remove the 2 screws. Underneath you will see the lamp cartridge being held in by 2 screws. Loosen completely (they should not come all the way out) and remove the lamp cartridge. Replace with 915P028010. Goodluck.
Jan 20, 2011 | Mitsubishi WD-62526 Projection TV
SCREEN IS BLACK ,BUT HAS SOUND
this is most likely just a lamp issue this lamps a made to last a average life span of 2-3 years of use
replacing the lamp should fix your problem that is the first thing to replace in this cases
here are few good online stores that have the lamp you need
http://www.discounttvlamps.com/915P028010-Housing-p/mitsubishi-915p028010-enc-ph.htm
http://www.discount-merchant.com/Mitsubishi-915P028010-915P028A10-Lamp-Enclosure-p/mitsubishi-915p028010-lamp-enc.htm?1=1&CartID=0
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Nov 05, 2010 | Mitsubishi WD-62528 62" LCD HDTV
My mitsubishi wd-62526 red light is on for lamp and there is no picture
this indicates a bad lamp. your owners manual has instructions for replacing. there will be a lamp door on the back or behind the speaker grille. if the lamp is shattered or bulged/white it is bad. if the lamp looks good, you may have bad capacitors on your power supply.
May 26, 2010 | Mitsubishi WD-62526 Projection TV
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
Mitsubishi wd-65831 one night worked fine next day nothin..
If you hear a whining noise, the odds are it is the color wheel, the bearings are bad in it and will need to be replaced as a whole unit, kinda pricey, my suggestion, sale the bulb and all boards in it and which should fetch about 400+ and invest in a new TV, a color wheel is pricey unless you can find a deal
Dec 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62526
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 13, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
171 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
