Question about MSI K9NU Neo-V Motherboard
Memory upgrades from newegg dont work! i have 2 corsair cm2x512-5400c4 mem. mods installed,i purchased 2 corsair twin2x4096-6400c5 mem.mods from newegg,installed them ,wouldnt boot.tried them one at a time,found out one of them were bad,so...i returned them,recieved the replacements today,installed them,NEITHER work this time! whats up? newegg? shipping? i have msi mainboard K9NU Neo w/amd x64 dual core +3800 processor. mainboard will accept 8 gb's, i have 2 512's (1 gb) in it now,they work, neweggs wont! any help much appreciated!
  • 28 Answers
One DIMM Slot could only support 2 GB Memory module, so try twin2x2048-6400c5 mem.mods
Posted on Oct 03, 2009
I have an Acer Aspire T180 and would like to upgrade the memory and add a wi-fi card. can you advise what cards I need to purchase?
Memory:
Looks like the Aspire T180 takes DDR2 533/667/800 memory. This is pretty easy to upgrade. Check to see how many memory slots your computer has (Probably 4, might only have 2). You should probably just replace what you have with new memory.
I recommend this memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
It is 2x 2GB modules. 4GB of RAM is a good amount of RAM to have, you will see a noticeable performance increase.
WiFi:
I would recommend a USB wifi adaptor. It is easy to instal and most ones work well, even the cheap ones. Just stick it in the back of your computer and forget it it's even there.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833130066
I recommend this one, I have been using it for 2 years and have had no problems.
Apr 26, 2011 | Acer Aspire T180 PC Desktop
Trying to upgrade memory, have tried three sticks purchased at Best Buy terrific Geek Squad. None work. Where can I purchase a upgrade memory?
You may have non OEM memory, your system may not be able to handle that much mem, or you could have something wrong with the connector that your mem fits into. If your original mem still works then the connector is not the issue. You should also make sure you are putting in the memory stick correctly. Make sure it is put in straight and is firmly placed in the connector. If you don't it will cause your problem. Capacity is 1G. If you are trying to put in a 2G it will not work. Hope this helps.
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=61473
Try this site. They say if it doesn't work you get your money back.
Feb 07, 2010 | Gateway MX3215 Notebook
Not upgrading 1gb ram to asus p5vdc-mx
yeap its the wrong memory.
max mem is 2GB DDR2 533/400 non-ECC, 2 x 184-pin DIMM
or you can use. 2GB DDR 400/333/266 non-ECC,
Note, you cant use both DDR2 and DDR in the same time. so set both memory stick as same type.
so if you set 2x1GB DDR2 533 you get the optimized speed.
hope it helps.
Jul 06, 2009 | ASUS P5VDC-MX Motherboard
Wont boot 2 windows xp home when 2 gig memory installed,works with 1 gig,tried both slots with both 1 gig sticks.Screen goes black.
Seems the memory is not comatable with the motherboard. Replace the old memory and visit http://www.crucial.com, they have a scanner tool which will confirm what mem can be installed.
Apr 30, 2009 | Computers & Internet
Amd a64 x2 4 athlon 64 x2 dual core processor & Corsair xms2 2 gb
What we really need to know is the socket type for the AMD. AMD makes sockets 939, AM, AM2, AM2+, AM3, etc. www.newegg.com will be the best friend you could ask for. I highly suggest their expert forums and chats as well, they'll help if someone here doesn't. But either way still need to know what socket that amd is. 5200, or 4200 or something like that is also more descriptive, thats how they ID their products. Mine is an AMD phenom II 920. Good proc.
Apr 19, 2009 | Computers & Internet
PC freezing up after memory upgrade
You can use a utility called CPU-Z to find the timing of the memory installed in the PC. Then check your memory documentation (I could find no specs at the Samsung site) to make sure they match in the BIOS. I would remove one stick and see if the problem is better, and also try another brand (Kingston, Corsair, other major brand) to see if any of them work.
Dec 31, 2008 | E-Machines (T3104) PC Desktop
Question
First, you will not be able to upgrade the video card on your laptop, since video cards for laptops are specifically designed to fit onto the motherboard and the design of the laptops body.
Secondly, sound cards as well are also deisgined that way, some sound cards on laptops are built in to the mother board and higher end sound card for laptops are specifically designed to fit onto the motherboard and the laptop's body.
Hard Drives on the other hand can be upgraded to a higher capacity but you can't add an additional Hard Drive. I have checked the specs of your laptop has 80GB IDE. You can upgrade to 120GB IDE or higher if you like. Just make sure that you purchase a 2.5" HDD (5400RPM/7200RPM speeds).
Here are examples of Hard drivers that you need for upgrade. I checked newegg.com for available laptop hard drive. You can check other online stores or other computer shops near you if you as well.
links (Hard Drive) :
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136130
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148073
http://www.newegg.com/Product/Product.aspx?Item=N82E16822146200
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136114
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148130
**Since you have installed Windows Vista, I suggest that you upgrade the RAM (Memory) on the laptop for smooth performance for Windows Vista. The maximum memory on your laptop is 2GB DDR SDRAM. Buyin RAM for laptops are a little but tricky so you can just go to the link below for specific memory upgrade for your laptop (I suggest that you purchase 2 pcs of 1GB since your system can accomodate up to 2GB).
Link for RAM (Memory) :
http://www.edgetechcorp.com/memory/upgrade.asp?cid=29695
**If you decied to upgrade the Hard Drive, you can still use you old Hard Drive as an USB external Hard drive for storage purposes. You will just have to purchase a 2.5" External Hard Drive Enclosure. Click on the link below for the example of the product :
http://www.newegg.com/Product/Product.aspx?Item=N82E16817145136
http://www.newegg.com/Product/Product.aspx?Item=N82E16817145329
**If you can't click on the links, just copy the link and paste it to your's browser's address bar.
Oct 28, 2008 | Sony VAIO PCG-GRT360ZG Notebook
2 GB or more RAM is not functional
try maybe theres a problem in memory compatibility...dude first try to put same memory card brand and specs
Sep 01, 2008 | MSI K8N Neo4-F Motherboard
P35-611 Memory upgrade question
hi try going in to your bios at the start when starting your pc up press f2 this should get you in to your main board settings finding the sys on your bios when you go into the bios it should come up with your cpu hard drive and mem installed if you need to reset this to 2 gig if you dont and its reading 2 gig then go to save exet yes to this and reboot your pc this may fix your problem .
this may just be a read problem and it needs to learn that you have a 2 gig mem
if not let me know and we can try another way for you ok
hope this helps ok
all the best
May 26, 2008 | Toshiba Satellite P35-S611 Notebook
Upgrade my Harddisk and memory
Good idea to do this. Most laptops will take any 2 1/2" hard drive you buy. There may be an issue with whether you can use a SATA or must only add an EIDE (regular hard drive). Still, the laptop may only be able to access the first 120 Gigs or 160 Gigs it depends on the laptop and hardware running your laptop. Call Acer and ask them. Once you know, go to NewEgg.com or ZipZoomFly.com or even TigerDriect.ca and you'll get a good/fair price with more than reasonable shipping and a solid guarantee if your part is damaged on arrival.
Memory is another issue altogether. Laptops are rather particular on what memory you can put in them. The only way to know for sure it to contact a manufacturer directly who also will sell it to you as well. You can google these solid memory makers and they will talk you through the upgrade:
Corsair
Crucial (Micron)
Samsung
These all have lifetime warranties on their memory. Follow their instructions carefully and follow static precautions when handling memory (basically only handle memory by the edges and never touch anything else).
Hope this has fixed ya!
Worldvet
May 15, 2008 | Acer Computers & Internet
MSI K9NU Neo-V Motherboard Logo
102 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
