Question about Hitachi 53UDX10B 53" Rear Projection Television
The power will not stay on. turns on then off within seconds
My camera is turning off within seconds of me switching it on.
Select "auto power off" on the Main menu. Select a longer time for the camera to stay on before powering off.
Feb 24, 2010 | Pentax *ist DL Digital Camera
Unit only has power for a few seconds
could be a couple of things..1. issue with your ground connection 2. ventilation
May 29, 2009 | Kenwood eXcelon KDC-X879 CD Player
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Tv will on stay on
Ur DM power board is dead.
Have burn capacitors,buy rebuild board or parts to replace with sordering iron.Or new board.
Apr 05, 2009 | RCA HD61W66 61" Projection HDTV
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Yeah remove the unit from your car,
Go to car audio store and buy Kenwood receiver without the
fancy opening front.
Dec 17, 2008 | Kenwood eXcelon KDC-X879 CD Player
SONY DSC-H9 WON'T STAY POWERED UP
I think that both your batteries are bad. Because the batteries have sat on a shelf not being used the batteries will only take a surface charge and not fully charge. Bum a battery from someone with a Sony that uses the same battery and see if that works.
Sep 20, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Onkyo TX-DS989 not staying on
This sounds like the action of some protection circuit that is monitoring some condition or voltage that isn't within its design limits. If it was mine, I'd look for an Onkyo forum to see if others have experienced the same problem.
Sep 10, 2008 | Onkyo TX-DS989 Receiver
Hitachi 53UDX10B 53" Rear Projection Television Logo
27 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
