Question about KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender
I'm having a hard time disassembling my Kitchen Aid blender. Does the container come apart from the screw on the underside, detaching the plastic from the glass?
    New Friend:
  • 87 Answers
Have a look at the instructions here:
http://kitchenaidblenders.co.uk/KitchenAidBlenderGlassJugJarDisassembly/tabid/157/Default.aspx
This is for the glass jar which may be slightlt different.
Posted on Jan 24, 2010
Broken magnet of a Kitchen Aid Blender. Where can I find another one? KSB5WH4
From Kitchen Aid they only come on a new motor. I am a Kitchen Aid service agent and I remove them from burnt out motors and keep them. Look for a service agent near you and see if they can help you out. I have no idea where you are, I'm in New Zealand.
Apr 26, 2016 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Changing the coupler
Lever it off with a screwdriver, it is aluminium and the threads on the ring will break away. Pick them out of the thread on the motor shaft and screw on a new coupling, it will be left hand thread.
Apr 22, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Two buttons are stuck in on my kitchen aid blender.
I have been searching for an answer to this same problem. My chop and mix buttons were stuck and I was getting no power or blinking lights. After finding no help on-line, I decided to take it apart and fix myself. It was easy and it worked!
1. Take the bottom of the mixer off by removing the rubber foot pads and remove the exposed 4 screws.
2. Remove the 3 sets of wires that are attached to the inside panel with clips. Very easy to remove, just squeeze at the base of the clips and pull up.
3. Remove the 2 screws holding that panel in place and gently lift off.
4. Remove the panel found under the top panel by also removing 2 screws. When you flip this panel over you will see what operates the switches.
In my blender the black plastic nubs that push against the buttons that were stuck and got twisted off kilter so they were not resetting properly. I just put a small screwdriver in there to try and straighten them as much as possible. All of these steps will be obvious as you disassemble the blender.
5. Push on the back of the buttons that were stuck to get them unstuck before reassembling everything back together.
I was surprised how easy a fix this was and how obvious what the problem was when I opened the blender up. No soldering or fancy tools needed, just 5-10 minutes and a phillips head screwdriver!
May 21, 2013 | KitchenAid KSB560 5 Speed Blender
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
Putting glass and washer together
  1. Place glass container upside down on safe working area.
  2. Place rubber gasket/ring on top of opening first.
  3. Place stirring or mixing blade on top of rubber gasket/ring.
  4. Take the plastic retainer and screw it on over everything previously assemble.
  5. Hand tighten only enough that you can reverse the whole operation when comes cleaning and disassemble time.
Feb 13, 2010 | Elite 072-04-1198 Blender
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blender leaks
Well, that's not good. Call the manufacturer and they should be willing to dend you one. Good luck.
Jul 21, 2009 | VillaWare 5785 Smoothee Bar Work Top...
KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender Logo
522 people viewed this question
Top KitchenAid Blenders Experts
eyecam
Lawrence Oravetz
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
