Question about Whirlpool Duet GHW9150P Front Load Washer
What does f and dl mean on a front load washer whirlpool
  • 5,911 Answers
"Fdl" is a door latch error code. This indicates that you have a failure of the door latch, the latch pin on the door, interconnecting wiring, or the Central Control Unit (CCU). A physcial inspection of the door latch should be done first to determine, if there is any physical damage to any of the latch components. Next, unplug the washer and remove the top panel of the washer by locating and loosening the three screws that hold the panel n place in the rear of the washer. With the screws removed, the panel will slide back then lift off. Perform a physical inspection of all the electrical connections on the latch and trace them to the CCU and do the same. Often, simply diconnecting each connector plug one at a time and reseating them can clear this problem. If you determine that you need to replace the door latch, the following link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
You can purchase replacements at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites offer great service, so shop them all for the best price.
If you need further assistance in troubleshooting this problem, there is a technical data sheet included with you washer. The tech sheet is located behind the bottom panel directly below the door. If not located behind the panel, it will be affixed to one of the interior cabinet walls. The sheet lists all the fault codes, diagnostics procedures and troubleshooting tips. The panel comes off by removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off. NOTE: For better access you can prop the front feet of the washer up ( a 2x4 works well for this).
If the door latch and interconnecting wiring check out good, the CCU will require replacement.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Posted on Oct 02, 2009
Dl f error code kenmore 11045081400 washer. what does it mean?
Here is a youtube video , you code has to do with door lock assembly ! Troubleshooting and Repairing an dL Error Code on Whirlpool Duet Washer . your washer is the same as this . Kenmore is built by whirlpool !
Feb 27, 2015 | Kenmore HE2 Plus Front Load Washer
Door lock
These fault codes are caused by a failure of the main control circuit board (the brain of the washer), this is the board that is behind the washer control buttons.
Feb 07, 2012 | Whirlpool GHW9150 Front Load Washer
I trried to start washer and a code dl came up
dl means there is a problem with the automatic door locking mechanism that engages before the wash cycle is started
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting message F DL. ASSUME MEANS DOOR NOT
IT APPEARS YOU HAVE A MAGNETIC CONTACT FOR THE DOOR,YOULL HAVE TO HAVE A REPAIR MAN REPLACE THAT CONTACT,
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing codes
you have a communication problem between your door lock and your ccu board. Are you hearing a click click click before it fails? If so this is a relay inside your ccu board. Replace the board this will solve your problem
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer code
Hi Keitha1
I'm Harvey the Master Plumber
You want to know what code dL means on a whirklpool duet washer.
This is what works for me 99% of the time:
Simply unplug the washer for ten minutes. The onboard computer will reset and work like new.
Please understand that you are not being shortchanged. There are hundreds of codes and with this new computer tech. they mostly require a repareman. To save you money the manufacturer has designed it to reset itself after ten minutes to solve most problems. Try this first, you can always call a local pro later if you want.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LIGHTS ON WON'T TURN ON DL CODE
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
see this fix
Jan 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
145 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
