Question about Vacuums
Eureka Boss 4D (5892BVZ) - Switch Replacement & Fried Wires
I have a Eureka Boss 4D (5892BVZ). The switch burned out frying the wires in the handle. Can I fix this myself? What parts would I need? How would I go about doing the repair? I was able to take the handle apart easily, but I do not know how to go about replacing the switch or if I would need to replace the switch, the cord, the wires. All the wires around the switch are frayed or fried, but the wires beyond that point look fine. Thanks.
  • primeeagle Jan 31, 2010
    I was able to order the part (the whole handle assembly) through Chris at govacuum.com The part number I got was 74074-2. It was amazingly easy to change the part - so far it's working quite well. They emailed me the parts diagram as well. Thought about contacting Eureka since it seems like they have a design flaw, but from all the other comments I saw about how un-helpful they were, I decided to save myself the aggravation - even though I'm frustrated I had to pay to fix something that should not break.
  • 8,404 Answers
If you got the handle apart, Id say you can probably fix it yourself. You might be able to patch it but I would say to maximize your effortrs please visit RepairClinic.com to find the exact replacement parts you need. They also have expert advice and guidance available.
I hope this works for you.
a
Posted on Oct 02, 2009
    Problem Solver:
  • 13 Answers
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Posted on Jan 30, 2010
  • 4 Answers
Changed the switch and/or handle assembly several times as described. When parts were no longer available, I had this rewired with heavier gauge wire. Problem solved.
Posted on May 27, 2011
Primeeagle, were you able to find this replacement switch? I also have one that burnt up.
Posted on Dec 10, 2009
Screeching noise from eureka bagless the boss 4d
replace beater bar belt, check and insure beater bare rotates freely with belt removed.
May 19, 2012 | Eureka 5849A Boss Bagless Upright Cyclonic...
I have an Electrolux Epci 3500 Sr upright vacuum cleaner ... 100 percent positive switch is shot and one of the wires inside is fried but before buying a new handle assembly online how do I check the...
The switch is replaceable, so you don't need to replace the complete handle assembly. I've got a 3500 that I replaced the switch on and it works great now. You can get a new switch at the local Aerus Electrolux store. To find the nearest store, just follow the directions on the below site.
I do recommend letting the service tech do the replacement.
http://www.aerushome.com/storelocator/
Nov 26, 2010 | Electrolux Epic 3500 Vacuum
Handle gets very hot on my 5892BVZ vac
i have a 1998 chrysler sebring convertible stop starting by the ignition switch,we changed starter,ignition switch been changed,changed starter relay,trace the wire haven't found a broke are burned place in it,checked igniton fuse its good,didn't see a linkable fuse
Sep 23, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Spin brushes wont spin and the switch wont turn machine off. I have to unplug it.
for the spin brushes it is most likely the motor is fried if you smell something burning it could be jammed or the wires have be shaken off the motor terminals. for it not turning off you need a new switch.
Jul 29, 2009 | Hoover F7431-900 SteamVac Vacuum
Eureka boss smart vac 4870 upright-How to replace on/off switch
This just happened for the second time with our 4870. It about $8 part with shipping (total of $12) from 24x7 vaccum. Pretty easy to change out.
Mar 19, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Boss Smart Vac 4870 evidentally overheated. Allowed unit to cool and observed a spark/smoke at outlet when it was replugged into the power outlet. Unit will not power up now. Circuit breakers in...
The wires leading to the switch inside my Eureka 4870 are fried...black and melted. Don't know why that happened, but it may be what is happening to the others listed on this site as well.
Dec 18, 2008 | Vacuums
Eureka boss vacuum, model 4331
it is posible you do not need the other wires have you replaced the original switch for the same or similar some of these switches have lights on could this explain the extra wires? also vacumcleaners sometimes have interferance surpresors they work fine without these but they interfear with tvs etc if not fitted mabe its missing?
Jul 19, 2008 | Kenmore Progressive Bagless Upright with...
Eureka 2961AVZ
http://geeksquad.fixya.com/ThreadView.aspx?prdid=538511&thid=720558
Eureka 2961AVZ
Posted by Joanschmuck on Jun 29, 2008
Will not start ...I get a momentary flicker of power about every 3rd or 4th time that I flick on the power switch. Outlet is fine / Plug looks good / cord looks good / I see no obstructions ........Would appreciate any helpful thoughts ....Trying to get Mom's Eureka 2961AVZ back up and running. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a bad switch or the worst scenario would be a bad motor and or armature, and the armature is almost the cost of the new motor, so I would replace the motor, but check the switch and the cord because sometimes the cord looks good but there might be broken wires inside the cord that you can’t see. If the vacuum is less than one year old the motor would be covered under the factory warranty if one year and maybe the switch as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 29, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka Bagless Widetrack, The Boss, Vacume, model 5893
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis. It is Part #27871.
Jun 05, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka 5892BVZ ON/OFF switch burnt
COUNT ME IN ON A CLASS ACTION IF ANYONE KNOWS A GOOD LAWYER.
Here's my story, posted on other solutions here, especially on the Model 5893; many people with burned wiring and switches. Major fire hazard imo! Okay, here's the skinny on my upright Eureka POS vacuum:
Had a problem with my upright Eureka Model 5893 bagless kinda starting and stopping. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Feb 01, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Vacuums Logo
954 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
