Password is locked can not get into comptuter
  • 77 Answers
Is you locked you Pc then open the casing then remove the battery from the mother board then reconnect it again then boot the PC
Please VOTE 4 ME for better attention
Posted on Oct 02, 2009
How to connect a sound card behringer FCA 1616 firepower into a comptuter
Install all necessary audio drivers on your PC.
Connect the unit to AC power.
Connect the unit to your pc via either USB 2.0 or firewire serial bus.
Press and hold the DIGITAL SELECT button while powering the unit on to switch the bus mode from firewire to usb and vice versa.
Feb 18, 2015 | Behringer Computers & Internet
Tip
Polaroid LCD TV Parental lock/unlock
Program Lock
Input the default password of 1235, the submenu
of Parent will display if the password is correct.
(a) When changing the password, the changed
password will be updated after four digits are input.
The word "ok" appears after you input the same
number twice, if the two passwords are different the
word "Failure" will appear.
(b) When All Clear is selected, all programs are unlocked.
(c) After you exit from the Program Lock menu and switch to a locked channel, the picture and
sound will be locked unless you input the correct password. The channel will remain unlocked
until the TV is turned off. After the TV is turned on again, the password must be re-entered to
view the locked channels again.
(d) If your program is locked, input the correct password to enter the Auto Search submenu.
Operating Auto Search will cancel the locked status.
(e) The default password is always effective.
(f) Entering the default password allows you to go to the Program Lock menu, then change the
password while the default password is still effective. This branch menu cannot be entered if a
wrong password is keyed in, In this case, press MENU to return to the previous menu.
(g) There will be slight delays while using the Lock All and Clear All functions.
● Child Lock
In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being
locked" will be displayed. However, the remote control buttons will still function. When the TV is
on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote
control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
on Aug 17, 2010 | Televison & Video
Forgot administrators password, have no reset disc, windows 7. need pathway in command promt
This article describes how to reset windows 7 password without disk when forget login password and locked out of your laptop or computer.
If you are still bothered about forgetting windows 7 password and have no reset disk, the methods described in this article will help reset the lost password with or without disk. You just need a few minutes to read these methods in this article, and pick the right one to take it to carry out.
Method 1 and Method 2 describe how to reset a user account password under the condition that you can login your comptuter with another administrator account.
Method 3 shows how to reset a lost password with windows 7 password reset disk which you have created before forgetting login password.
Method 4 tell you how to reset or recover windows 7 login password with a password recovery software.
Sep 11, 2013 | Computers & Internet
Remote accsess on a dell desktop
If you want to access remotely dell desktop when u need is to right on my computer ---------------- click on property------------------click on remote setting-------------------- and check allow connection from remote comptuters
Dec 15, 2011 | Dell Computers & Internet
Forgot user name n password for Windows 2000 Professional
You will need the Windows 2k disc. However you won't be able to find one unless you check out like ebay. Win 2k has been EOL for years now. I would suggest even buying the lowest end computer for around $250-300 and it would be tremendously faster than what you have currently. You could also check around at pawn shops, mom and pop computer stores for cheaper ~$50-100 dollar comptuters that would be better than this. I wouldn't waste your time trying to fix such an old computer.
Dec 10, 2011 | HP Computers & Internet
Frozen computer
Check your memory module. Reseat or clean its edge connector with soft eraser. Do this if the unit is unplugged and turn off. Commonly this is a sign before going to POST.
If not, this is also sign of failing component, short circuit or loose contact. Getting the faulty will force you to have the basic setup to run the computer. And try to isolate the faulty one.
May 03, 2009 | Dell Dimension 8400 PC Desktop
When hitting the shift keys, the comptuter registers a q or a z?
try cleaning the keyboard
under the keys
sometimes helps
Dec 17, 2008 | Logitech 967437-0403 Keyboard
Please help updating
What type of updates are you doing, and what is the error code?
Jul 28, 2008 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
