Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
What does it mean when it say's card locked on my 40D
  • 58 Answers
SD cards have a little sliding lock switch on the side you can set to prevent accidentally over-writing the card.
Posted on Oct 02, 2009
Testimonial: "Thank you ! so simple "
Is there a way to fix my memory card when it says cannot create folder?
The memory card may have the write protect switch on.
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Mar 13, 2013 | Canon EOS 40D Digital Camera
My canon 40d says can not format card
your card is locked,unlock it by flipping the little tab on the card.
Dec 21, 2012 | Cameras
Got Error 99 on my 40D. Have done all the obvious: remove battery, replace battery, check lenses, SD cards. Have talked with several people who tell me it's "common" with 40D. Any assistance you...
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks!
Mar 27, 2011 | Canon EOS 40D Digital SLR Camera Digital...
My Canon 40D suddenly came down with the dreaded Error 99 for no apparent reason. I have tried all the usual, battery, memory card, lens, but no luck. Even on the bulb setting the shutter won't stay open....
Welcome to Fixya
Thanks
Jan 30, 2011 | Canon EOS 40D Digital Camera
My Canon 40d keeps saying' CF card not formatted Format card with this camera'. I tried to do that but it says ' Cannot format Change the CF card. I have 6 cards and I've tried them all with the same...
My 40d keep saying the cf card is not formatted. I used three different cards and it says the same thing. Is it anything I can do to fix this problem.
Nov 29, 2010 | Canon EOS 40D Digital Camera
Canon 40D and 64Gb CF Card
What i find is that the larger the card the slower the write recovery in taking pictures. If you are an action photographer this is a pain as things happen fast . To have the camera take so long to recover from a write leaves you open to losing some excellent shots. So my rule of thumb is use smaller value cards. If you are just a happy shots photographer then this probably doesn't really matter.
Thanks for using Fixya
Sep 15, 2009 | Canon EOS 40D Body Only Digital Camera
My canon EOS 40D with 18 - 55 IS , when continuous shooting mode is selected, slows down after taking 6 shots. However as per the spec its capable of taking 75 jpegs or 17 RAW images.Please resolve this...
Slow down after taking 6 RAW files ...
A RAW file is Approx. 12.4MB.
The memory usage is approx. 74,4 MB
The internal memory (Buffer) has a size for up to 75 JPEG compressed images.
Which size has the smallest jpg?
JPEG/Small: Approx. 1.2MB (1,936 x 1,288)
The Buffer is approx. 80 MB.
The data are calculated under Canons laboratory conditions.
The maximum Burst (the 17 shoots) means that the camera is writing to the card and the buffer is full. Than the cam will stopping taking pictures.
Which kind of Card do you use?
Check the spec for the card (write speed) and maybe buy a faster card.
Jun 07, 2009 | Canon EOS 40D Digital Camera
Eos 40d error 99
Error 99 can mean many things. Have you installed the latest firmware for the camera (version 1.1.1)? If you don't have, download it here (for equipment purchased in USA or Puerto Rico):
http://web.canon.jp/imaging/eosd/eos40d/eos40d-firmware-e.html
If you have the latest firmware, try this:
  1. Switch off the camera and remove the CF card and battery
  2. Keep the camera idle for 30 min
  3. Clean all the contacts of the camera (battery contacts, lens contacts etc) with an eraser. Do this keeping the camera facing down so that no debris fall into the camera.
  4. Attach the lens and insert the battery.
  5. Switch on the camera
  6. Insert the CF card
  7. If the error persists, format the card again
  8. If this does not work, try using another CF card.
Feb 06, 2009 | Canon EOS 40D Digital Camera
Canon 40D LCD Wont come on buSY flashes in view finder
Okay, this is simple. Your camera can take several pictures at one time in a burst. However when you release the shutter button your processor takes a second to actually SAVE the pictures to the card in the camera. One thing than has helped me in my wedding photography business is to buy the fastest speed cards I can find. It significantly reduced my "busy" time.
Nov 30, 2008 | Canon EOS 40D Digital Camera
Can 40D camera
Unfortunately, the ERR99 code is a catch-all code that means an UNKNOWN error has occurred. Because of this, it is going to be very difficult to pin down exactly what is causing the problem.
It could be a fault with either the camera (main circuit board, software, shutter mechanism etc.) or even the lens.
For starters, I would make sure that the lens electrical contacts are clean and the lens is mounted correctly and fully locked home. If you have a spare lens, try that also.
Next, I would reformat the memory card (do this in camera). If you have a spare memory card, try that also.
Check that the battery contacts are clean, and also the contacts of any external hardware such as vertical grips.
If none of these solve the problem, the only option left is to return the camera to Canon for a warranty repair, however if it is brand new, I would take it back to the store for an exchange.
Hope this helps,
Matt
Mar 08, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
63 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
