Question about Garden
Fly wheel removal ? - Garden
  • dontbother10
    dontbother10 May 11, 2010
    View this; the piston rotation must be stopped to allow removal of the flywheel nut. This illustrates how. R² Drive Link Outboard Clutchhttp://www.youtube.com/watch?v=cdqkIuVNU... Check at the IPL for your saw to see if any special tools are needed. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises. It is probably a left handed thread (tighten it to loosen it). Let us know how it worked for you. GL Lou
    President:
  • 2,220 Answers
View this; the piston rotation must be stopped to allow removal of the flywheel nut. This illustrates how. The nut is a normal right handed thread.
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check at the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
Lou
Posted on Oct 02, 2009
  • doit4me Nov 09, 2010
    The question was about removing the flywheel, not the drive sprocket. Different side of the beast.
How do i replace shere pin on lawn tractor
have to remove the fly wheel nut then remove the fly wheel. to remove the fly wheel first take off the nut on top, then use a puller if you have one or pry up on the fly wheel and tap the top shaft to it gets loose, there is a notch in the fly wheel and one on the shaft make sure you remove the broken key first then line up the two notches and insert a new pin, you can buy them at any mower shop,, or look it up on u tube on how to remove fly wheel and pin, hope this helps,
Oct 20, 2014 | John Deere Garden
My craftsman 190cc 625 series lawn mower stopped and a friend said that there is a pin that drops when the mower blade gets caught and stops, I'm really in need of help on how to get to the pin if possible...
Wow it's a lot of work it's called the fly wheel key that is sheard. In every case like this you have to make sure you remove the spark plug or uncap the spark plug. Remove the pull cord assembly and then use a pipe or wooden board to keep the blade from moving underneath the mower. VERY VERY IMPORTANT TO USE A CLAMP TO HOLD DOWN THE CLUTCH BRAKE AND DO NOT REMOVE IT TILL YOUR FINISHED OR YOU'LL BRAKE OFF THE BRAKE FOOT ON THE LEVER. Use a breaker bar to remove the bolt holding the fly wheel down. Now here is the hard part. The fly wheel is made of aluminum and can brake easily as well as the fly wheels blades. If it cracks or the fly wheel blade is cracked or broken it's junk. If you don't have a Briggs and Straton puller you can use a lug wrench and pry the fly wheel up. You must first place the nut back on the 1 inch bolt on the center shaft so the threads are not showing at the top of the drive shaft. You have to hit the nut on the center hard but not like to hard to brake anything. After you get the fly wheel off you have to use the model and serial number to get the key from a lawn mower shop. Place the key under the fly wheel and very carefully watch to see if it lines up as you push the fly wheel down. Push it down from side to side so it fits flush. Tighten the bolt. Don't start it first see if when you pull the pull cord it moves with out pulling the rope back into the mower. You'll have to make sure the top bolt is tight like maybe 60 pounds. MJ
Sep 29, 2014 | Garden
Why does my chain saw lose power and shut off as soon as it gets hot.can't restart until it cools off.
Check coil pic up or the electrical pick up in the pull string housing. Remove that and u will see the fly wheel next to that is the electrical pick up .look at fly wheel make sure magnets are clean surface ,they are in the fly wheel itself.after that remove coil and clean surface that faces fly wheel. Using a match book cover place it between fly wheel and coil ,make sure it moves but not falls out snug ,tighten coil screws and remove match book cover. If it dose it again re place coil look for small engine shop in your area and the can help get u a new one .weak spark means coil,sparkplug
Sep 15, 2014 | Poulan PP4218AV 18" Chain Saw
How do remove the flywheel ?
first remove the cover and metal cover over the fly wheel, remove the bolt and the cup it sits in, next hold the break handle tight with rope or something, next put the nut that you removed from the cup and screw it back on the shaft just even with the top. next using a pry bar fit it under the fly wheel and pry up and at the same time tap the nut wit a hammer until it comes loose. i did this on my mower change the fly wheel key and it runs great, or check you tube on how to remove a fly wheel
Sep 04, 2014 | Garden
Fly wheel on air compressor
you need part book and manual book that same as the type of air compressor, you can very easy to replace, maintenance and trouble shooting about your compressor
Feb 14, 2014 | Air Tools & Compressors
The starter cord has snapped. Can it be replaced?
Yes.Go to a harware store they or at least most sell the cord you need in bulk.Keep the handle as you will need it.Remove the fly wheel cover and the cord attaches to the fly wheel.Tie a knot in one end of the cord and slip it through the handle.Thread it through the hole in the fly wheel cover.Then just wrap it around the fly wheel.Reattach the cover,and you are done.
Jul 09, 2011 | Briggs & Stratton Garden
I have a 6 hp self propelled Craftsman mower with
Ok this may be a simple fix. it has a high chance that the fly wheel key has sheared, this will cuse the timing to advance and bite your hand with the rope.
remove the pull starter and the cup ontop of the fly wheel, if you look straight down at the fly wheel nut you can see a cut out in the crank and fly wheel they should be aligned up if not it has sheared. use a lever under the fly wheel and put some pressure on to to lever it up then hit the fly wheel oposite side of the lever AWAY from the the magnet. and the fly wheel should pop up. replace the key and of you go..Make sure you use the OEM brigbs and strat key it is made out of alloy. The cause of this is the blade hitting a kerb or somthing hard,
Jul 02, 2010 | Garden
Trying to remove magneto on 1987 honda xr80 bike will not fire
first you need to get a fly wheel puller. then remove the nut in the middle of fly wheel,insert fly wheel puller,reverce thread,tighten pin and it will pop off fly wheel.when you put it back on remember to line up "woodruff key",its a little notch on fly wheel whitch lines up with a ridge on cam shaft. if you cant fix your problem and you have spark its probobly your coil and condencer.
Sep 05, 2009 | 1987 Honda XR 250 R
Fly wheel needs to be replaced
Yes you do. If it's 4x4, i find it easier to pull the motor.
May 04, 2009 | 1989 GMC Sierra
How do you get to the fly wheel to check magnet. I removed the pully but their is a screen over the fly wheel, how do you remove the screen?
there should be about 3 screws that hold the screen over the flywheel. If you have a compact wrench it is the easiest way to remove the flywheel. Remove the nut and using a fly wheel puller, which can be made with a few screws and a piece of 2" x 4 " metal with drilled holes the exact distance of the flywheel puller holes in your tiller (much cheaper than purcasing one), work the flywheel loose and ta da there is the magnet.
Apr 17, 2009 | Troy-Bilt Garden
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
