Question about Kenmore 53542 / 53544 Side by Side Refrigerator
I have a Kenmore Coldspot refridgerator model #106.53554202 and the little electric box in the fridge side is emitting a high-pitched non-stop whining noise. I took the cover off the box (located in the top back of the left side wall of the fridge) and see a bunch of wires and a black bulky electrical plug looking thing. The whine is not coming from a fan and is not coming from the freezer. It's definitely the fridge side. The fridge was made in 2002 the label says. I tried turning it off for a minute and turning it back on. I tried to adjust the coldness levels. Nothing stopped the whining. Any ideas how to fix this?
HVACRH20
  • 237 Answers
SOURCE: Kenmore 596-76512 fridge not cooling freezer seems to be working still
If the fan above the evaporator coils in back of the cover isn't running then no cold air will be blown up to the fridge area. That's a common failure item and very easy to replace yourself. And by the way... $200 bucks and 2 weeks out is about normal these days believe it or not. It's what we would charge ya! :) At least you did the troubleshooting and saved yourself a couple hundred bucks.
Posted on Jan 15, 2007
SOURCE: Kenmore side by side no longer freezing on freezer side and not as cold as it should be on both sides
We had the same thing happened. We called Sears and scheduled a repair. Apparently there is a small electric heater that keeps the coils from freezing up and had to be replaced, about $80, I think. Not sure if that is your problem.
Posted on Mar 03, 2008
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore Coldspot 106.9552610 not cold enough
Inside the fresh food compartment look for an opening that will allow you to turn the defrost timer clockwise slowly. When you hear it click the refrigerator should go into defrost. If the timer is bad it will need replaced. Let me know. Below is a photo of timer.
Part number 6
Posted on Feb 27, 2009
Where do I find a manual for the kenmore coldspot # 59099990 refridgerator
Model number is not valid check plate inside refrigerator. Usually Sears Kenmore start with 3 digit model number like 590.xxxxxxxx, and usually have characters that tell u what characteristics the model has and what color scheme.
May 10, 2014 | Kenmore Side by Side Refrigerator
I have a kenmore elite coldspot side by side refridgerator and it is not cold enough on the fridge side. How can i fix this?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 08, 2011 | Kenmore 56983 Side by Side Refrigerator
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Coldspot EM5119829. The Freezer works
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
or..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 03, 2009 | Refrigerators
We have a kenmore coldspot refridgerator model #62854100 Since we've owned this model we've had a leaking problem from whatever the part is at the top and back of the refridgerator. We go through three...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Refridgerator will not run
if it have a thermostat it can be your problem
Jun 16, 2009 | Kenmore 64802 Top Freezer Refrigerator
Refrig shut off and will not restart - light bulbs still working
this refrigerator sounds like a 'frost free' type, and as such can, usually, only be repaired by the manufacturer. local refrigeration engineers cannot get the parts. your fault sounds like a PCB (printed circuit board) has gone, which only the manufacturers have in stock.
Jan 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
189 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
