Question about Goodman GMS90703BXA Heater
I'm installing a CHPF coil to the furnace set to the left side . that gets the A top part of the coils to close to the burner tubes. Is that correct or should something else should be done? thanks
  • 80 Answers
Model # for furnace is needed to better answer. The coil should sit directly on top of the furnace according to pic shown.
Posted on Oct 03, 2009
  • Josh White Oct 07, 2009
    I need to update my reply. The CHPF is a horizontal coil and I read the post to quickly to properly answer you. Sorry. Here are the instructions for reversing from factory shipped right-hand application to left-hand.
    To reverse from right to left application, relocate the front rail to
    the back, and the back rail to the front. Then attach flanges to
    the discharge side of the unit.
Why would the flame and pilot keep going out changed the thermocoupler
Remove the cover over the burners so an inspection of the heat exchanger is a bit easier. Take an LED flashlight and a small telescoping mirror and inspect the heat exchangers front section above the burners giving special attention to the two sections of the chamber on either side of the pilot light. Many times there will be a hole in the chamber or a crack that will allow the blower that circulates the air into the duct blow out the pilot light.
If you are handy enough, consider turning off the gas and remove the ribbon burners prior to performing your inspection. The pilot assembly is probably attached to one of the burners. Lay them on the floor in the order in which they install in the furnace as some furnaces have dedicated left and right end burners and most older standing pilot furnaces have the one burner with the pilot mounting bracket.
To remove, many times you gently pull backwards towards the gas manifold while raising up on the front of the burners. Once elevated enough, the burner then slips off the brass spud (orifice) and forward and out.
The next reason the pilot can go out is because the safety 'holding' coil in the gas valve is defective. Its responsibility is to hold open electrically a safety circuit proving the pilot gas is burning so that main gas can flow. The thermocouple generates just enough electricity to hold the safety coil open. Coil bad = pilot out.
If your furnace is over 25 years old, there is a good chance there is a hole or crack.
Feb 19, 2015 | Dayton Gas Furnace Heater
Goodman heater not igniting, coil does not glow. Do I replace the coil and would that not allow the gas to open if there is no glowing coil?
your correct the gas valve will not open ifnthe glow coil does not ignite the flame which then hits a flame sensor (looks like bent piece of wire usally on the opposite side of burners from glow coil) you can with a long lighter thats is used for lighting a gas grill light the furnace manually that will allow it to run through one cycle only. you must first have the door off to the burner area, have someone else turn the furnace up to when it turns the exhaust blower on. when that blower starts running you have to listen for a click , that click is when you will hold the lit lighter right where the glow coil is, the pilot will light and your furnace will run, providing its only the glow coil that is bad. you may show your ex how to do this and leave her do it for the rest of the winter that would help keep her off your back and you could kill two birds with one stone so they say. if you do get a new glow coil i recommend getting the new style they cost a little more but they are not as fragile, you cant touch with hands or bump the old ones but the new ones take a lot to break and seem to last longer. Good Luck
Dec 29, 2011 | Goodman Heating & Cooling
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
Our dryer runs but doesn't heat. I have checked the obvious things but have not got into the ignitor etc. In order to access the burner etc. on this model do you have to access through the top. Older...
dont forget about thermal fuse on back of dryer white plastic with two wires can jump out for testing see if you get heat if so replace thermal fuse and clean venting adn venting flapper for opening and closing .... if no heat tthen open lint screen on top of dryer remove two phillips screws pull lid forward from back corners towards u and lift lid up remove front screws should be two 5/16 screws on in each corner and door switch harness connected lift front upwards and to the right remove drum belt tensioner bottom right side .. release belt remove drum set out of the way ... plug in dryer watch ignitor in burner tube bottom left corner should glow redish orange then a click and then a flame
no glow aslong as thermal fuse has been checked bad ignitor....
if glows and no click replace flame switch black and silver box on left side of burner tube
if glows and clicks and no flame replace two black round coils on top of gas valve
Jan 28, 2011 | Dryers
Heat won't go on...don't know if it's an ignitor problem, or a coil problem
UNPLUG DRYER REMOVE TWO PHILLIPS SCREWS UNDER FILTER ON TOP LID ....
FLIP TOP TOWARDS WALL REMVOVE 5/16 SCREWS IN TOP CORNER OF CABINET AN LEAVE DOOR AND FRONT CONNECTED REMOVE DRUM BT RELIEV IDLER BELT TENSIONER INFRONT OF MOTOR AND SLIDE BELT AND DRUM OUT OF CABINET AND SET OUT OF WAY TURN DRYER IN TIMED DRYER NEAR 60 AND LAY ON FLOOR INFRONT OF DRYER ON FLOOR INFRONT OF DRYER INFRONT OF BURNER TUBE AND WATCH AND LISTEN IGNITOR SHOULD GLOW RED THEN A CLICK THEN IGNITOR SHOULD LIGHT GAS ..... IGNITOR DOSENT GLOW CHECK WHITE PLASTIC FUSE ... IF IGNITOR GLOWS AND NO CLICK THE REPLACE FLAME SWITCH ALUMINUM AND BLACK BOX ON LEFT SIDE OF BURNER TUBE ...IF CLICKS AND NO GAS REPLACE GAS COILS
Jan 26, 2011 | Estate TEDX640JQ Electric Dryer
I have a sony xbr tv and after moving it, now THE TOP half of the screen is greenish. how can i fix this?
MAKE SURE NO SPEAKERS WITH BIG MAGNETS ARE ABOVE OR NEAR THE TOP OF THE SET--magnets can cause "purity" problems.
The set has a built in coil to correct this every time you turn the set on.
IF THE SET IN THE MOVE FELL FORWARD, IT MAY HAVE DAMAGED THE SHADOW MASK INSIDE THE TUBE.....
TWO REASONS FOR YOUR PROBLEM: COIL IN SET NOT WORKING FOR SOME REASON---ROTATE SET LEFT AND OR RIGHT AND SEE IF PURITY CHANGES OR BECOMES GOOD.
IF SO A MANUAL COIL CAN BE USED (CALLED A DEGAUSSING COIL) TO CORRECT IT--TAKES 5 SECONDS.
SECOND: SHADOW MASK IN TUBE (SCREEN) IS DISLODGED BY MOVE----THESE ARE VERY HEAVY SETS AND THE MASK IS EASY TO DAMAGE.
The mask is inside the tube and perforated with hundreds of tiny openings that line up with the phospher coating (stripes if you look close at set with it on) if mask got dislodged in move--damage is permanent.
If changing north,south, east or west position of front of set corrects it mask is good.
Unlike others who have bid I am answering this for free, if I told you something you did not know rate this free solution as very helpful.
SD TECH
Aug 21, 2010 | Sony KV-40XBR700 40" TV
I just bought this unit used and noticed the a-coil is bigger than the top of my furnace. Do I need to get another a-coil or build a bigger plenum for my furnace.
you should prob take the coil back an get the correct size for your furnance .you can build plenum if you like lotta extra work though
Aug 21, 2010 | Heating & Cooling
Janitrol furnace-circuit board code giving 3 blinks vent pressure switch or vent blockage where do i check on system / furnace was running fine up to this point /turned it off for about 1hr. and when i...
f this is a metal vent 80% furnace,Turn Furnace off
and remove the vent that connects to furnace and see if it is plugged.
If this is a High Eff furnace witrh pvc vents for
exhaust and intake air make sure they are not plugged on the outside.
Turn thermostat all the way up,turn furnace off and
wait a few minutes.This should reset any control
board fualt.
Turn the furnace back on, if you have a glow coil
ignitor it should glow red and then the burners should
ignite. If this doesnt happen then:
On High Eff Furnace if the glow coil does not glow red, remove the combustion door to the burners,
turn furnace back on, if the glow coil glows and
burner ignites, you have an obstruction in the intake
air side. If it still does nothing then:
Use caution and remove the exhaust vent from furnace, start furnace, if furnace runs then you
have a problem with the vent system
Feb 13, 2010 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
95 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
