Question about Tools & Hardware - Others
My pnumatic h.k porter 9190 cutter piston not returning to
My pnumatic 9190 cutter piston not returning to oringal position after cut it jus stick up
    New Friend:
  • 4 Answers
On the 9190 HKP cutter there are 2 large springs. they may have been stretched or even missing. These return the jaws to the open position
Posted on Jun 07, 2017
  • 5,603 Answers
Usual cause of stuck pistons in air operated tools is lack of lubrication. Most you have to either put drops into the air inlet before each day's use or use a mist oiler.
Lube your tool at least twice the amount recommended and try to get it to cycle. After it starts to work, make sure you lube it daily.
It is possible that the O-rings were damaged by insufficient lube oil.
Posted on Oct 02, 2009
I have an H K Porter 9190 that is leaking air
what you are doing is not right
take it to an air tool repair shop and have it fixed proeprly
Oct 01, 2016 | Porter Air Tools & Compressors
I have a 2002 sunfire... and i have trouble turning it on. Once it startes it is stuck there because it will not turn at all. Once it is in this position the wipes wont work, the windows wont roll down,...
sounds like you need a new ignition, reason nothing works cause once it doese turn over n starts the car the tumbler is stick in the starting position jus not far enough to keep the starter engaged but far enough the it still trying to go trough the start process which cuts the power to everything else till the ignition returns to the on postion
did you try jus turning the ignition far enough to when the starter engages jus let go of it so the car doesnt start and see if everything else still doesnt work if it dont i belive its the igniton
also with out starting it or engaging the starter as in just turning the key on to get power does anything work?
Jul 12, 2012 | 2002 Pontiac Sunfire
What position should striker be in a Bosch 11203
It works on a pnumatic system, Light oil or grease is fine on the piston its self but grease in the gearbox. (don't over do it) Have the piston partially sticking out. Make sure you locate it onto the ecentric cam correctly. If it does not hammer at first just run it for a while against the work, stopping and starting it in short bursts.
Jun 06, 2012 | Drills
The driver sticks and won't return
Here are a few things to check. It should not be difficult to push driver to top position (should move smoothly up). If difficult to move, remove head and pull out driver to check for obstruction/debris from crumbling bumper or piston oring too tight in cylinder. Repair as needed. If piston moves easily, pull cylinder and replace checkvalve that fits snugly around a series of holes on cylinder (you can also use several orings to fill slot if you don't have new checkvalve band). Replace parts and check for proper function. Piston may not return properly if lower bumper is missing parts/cracked or too worn. Also headvalve parts must be in good order and lubed. Make sure that the upper pumper is not cracked. Good luck
Jan 25, 2011 | Porter Cable Cable Roofing Coil Nailer...
Drive rod will not return to top position.
Open up the owners manual, review the parts list diagram blowup. remove the four screws (allen key) and pull top head off unit. You need to get at part #116, a plastic shock absorber that breaks off and falls between the main drive piston and part #120 piston cup. its a $15 part and $10 to ship it.
Dec 18, 2010 | Porter Cable RN175 Roofing Coil Nailer
The nail gun is sticking ever shot and will not reset
Driver not returning to top of cylinder is caused by several issues. Bent driver, piston oring, and check valve. Remove head and pull out driver. The blade should be straight with no missing pieces. Driver piston should fit snuggly into cylinder and not drop down cylinder under its own weight. If driver / piston look ok, pull out cylinder and look for check seal in place. It looks like rubber band and fits in groove with row of holes. Parts are available at www.toolpartsdirect.com
Sep 18, 2010 | Porter Cable FactoryReconditioned DA250BR...
In the paper and quality options I have only sheet or CD/DVD to select from. Roll option is not showing
The Roll Paper button cuts, feeds and returns paper to the printing position when the automatic cutter is used. When held down for three seconds, it reverses the roll paper out of the printer. The cutter can make either one cut precisely between images, two cuts with a margin between images or no cuts. The driver lets you select which method you prefer. The Utility program has an alignment option for the cutter that you should use whenever you reinstall the cutter.
Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
Mar 17, 2010 | Epson Stylus Photo 1400 Printer
Porter Cable 18 ga Brad nailer - BN200 Will not reload
Strip and clean the whole diaphragm and spring arrangement. Also check whether a bad nail hasn't damaged the piston guide and caused it to jam when on return stroke.
Jun 13, 2009 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Porter Cable 2 inch brad nailer piston does not return
Sounds like the cylinder check seal. That`s the o`ring on the outside of the cylinder sleeve. With little holes in the groove. You have to remove cylinder sleeve to get to it.
Thanks,
Jeff
Jun 04, 2009 | Tools & Hardware - Others
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
Apr 13, 2009 | Dewalt Tools & Hardware - Others
Tools & Hardware - Others Logo
426 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
