Question about Coleman 10' X 10' Sundome Tent 9160K101
How much oil for a coleman powermate 3750 with a 5.5 tecumseh
FRANKSFIXIT
  • 72 Answers
SOURCE: Oil for Coleman Powermate 5000 PM0545305.03
My answer:
First of all - Almost every 4-stroke Genset engine out there should use a minimum 10-30 or else a 10-40 oil blend tops. Best NEVER to use just a straight weight, as in a 30 or 40 weight, as that would be way too "high viscous" at colder temps and could destroy the engine due to overheating at MAX Genset LOADS!
Next - If the Genset is indeed brand new then you need to use the proper fuel in it, as certain mfr's require different fuel blends (such as with certain B&S - Briggs & Stratton - engines), and those engines are set up that way to run on that blend alone. Using the wrong gas blend could damage the engine.
You really need to get a factory Users Manual for your Genset there and read it through thoroughly!
If it has gas in it now (and hasn't run in 3 years?) chances are the whole gas tank, and fuel lines, and Carb as well will need to be cleaned out from contaminated fuel - as there definitely is gum and varnish built up everywhere in those fuel delivery areas esp the most important component - the Carb! Been there - seen that - cleaned that! So I KNOW for FACT.
As for the OIL LEVEL - that is fairly simple - as all you do is unscrew (or in some cases pull out) the dipstick, and check the oil for proper level on the stick as well as cleanness (2 finger test like with car oil), and if it's even black or a silvery color then it definitely needs to be changed out NOW! Refill with fresh oil and your done there.
Check the Air Cleaner for cleanness as well, and service the filter if a foam element, or replace it if a paper element.
If the fuel tank has an in-line fuel line filter and it looks dirty change it out as well. Esp if the gas tank is made out of metal.
Check the spark plug for proper gap, and heat range, and burn color if the Genset has been run already. Should be a nice "light tan" color. If dark and wet - then you have Carb flooding problems.
That about covers it...
Anything else problem wise feel free to ask me here in post follow-up and I'll be glad to answer it for you.
Please post me a reply as to the found problem there, and the resolve to it by following my recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Posted on Sep 04, 2008
SOURCE: generator fuel-oil mixture
My manual for my Powermate 1000 says 18:1 fuel mixture.
Posted on Sep 13, 2008
  • 195 Answers
SOURCE: Coleman Powermate 5000 no electricity, runs fine
Hello;
Take a look at your outlets. Some of these units use pretty cheap outlets and short out. You will know if it is bad when you look at it. Hope this helps.
Thanks;
Rich
RPM Northwest
Posted on Jan 23, 2009
protek480
  • 1723 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
Posted on Aug 01, 2009
SOURCE: What oil do I use in a Coleman Powermate 1850
Even though Powermate generators are discontinued they still have a website with owners manuals at www.powermate.com.
Posted on Sep 30, 2009
My Coleman 3750 generator normally starts on the 1 st or 2 nd pull. It will not keep running unless continue tom choke it?????
You have a lean fuel condition. Your carb is slightly clogged. By choking the unit you are manually changing the air/fuel ratio to richen up the mix. Your carb needs to be removed and cleaned. Hope this info helped.
Sep 07, 2013 | Coleman Cable COLEMAN POWERMATE PM0433750...
I have a coleman maxa 5000 PM525202; I bought it at a garage sale (didn't run); cleaned and rebuilt carb, changed oil, etc, and now it starts great and idles great. But ther eseems to be a part of the...
Parts lists for Coleman generators are here: http://www.jackssmallengines.com/coleman_parts_lookup.cfm
More detailed information about the engine can be found by using the engine model number. Look around the fan shroud or engine block. Coleman used different engnes, however your gen may have incorporated a Tecumseh 10 hp engine. Good luck
Sep 02, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Jun 18, 2010 | Coleman Powermate Powermate 5000W...
Coleman powermate with 10 hp Tecumseh. Never started before this attempt. Full gas and oil. will not start. No spark to plug, checked with plug out. Engine switich on position.
There are a couple of switches on these things, and their positions and the little icons on them are NOT intuitive - well maybe they are intuitive to the under-20 crowd. I lent mine (which starts right up) to a friend who spent an hour or two pulling the cord before he noticed how to turn it on. I'm not trying to be a smart-alec. I hope this helps.
May 17, 2010 | Coleman Powermate Premium Plus 6250W...
I have a Coleman 5500 with Tecumseh motor and it has a really, really slow oil leak when it when it is sitting in the shop not running. I can't tell where the oil is coming from. Any suggestions?
Look for a crack in the crankcase... possibly near a mounting boss. Also oil filler plugs sometime leak if overfilled.
Suggestion: Use some "gunk" engine degreaser to make it sparkle so you can spot where the leak originates. You probably need to put it up on a bench OR use an inspection mirror.
Apr 29, 2010 | Coleman Powermate Premium Plus 6250W...
Need to know what oil to use in 10 HP 5000 tecumsah engine - goes on our generator and I lost the manual
It depends on what temperature range the generator will be operating in. Below is a chart from Tecumseh that shows different oils for different temperature ranges. It says on their website to use a high quality brand name oil so you don't have to get actual Tecumseh oil.25b21be.jpg
Feb 26, 2010 | Coleman Powermate Premium Plus 6250W...
How to remove coleman powermate 5000 generator from Tecumseh 8 HP motor for engine model number hm100.
4 bolts to the engine then altenator will just pull off may need a puller to get it moving
Feb 01, 2010 | Coleman Powermate Powermate 5000W...
Coleman powermate 3750 wont start
Check your oil level and add a little if it's low. Don't overfill. Also, make sure the unit is level. You may want to change the spark plug. Depending on the hours you've used it or the length of time since you've used it may have taken a toll on the plug.
Beyond that, have a professional look at it.
Aug 29, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman powermate 3750 watt brand new I started it
Check the oil level & try again to start many times until it became loose because the engine became stock up for long time not use.
Mar 12, 2009 | Coleman Powermate Powermate 5000W...
Coleman 10' X 10' Sundome Tent 9160K101 Logo
88 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
