Question about Kodak Cameras
Everything through the lens looks pink and the photos are coming out with pink lines
    Problem Solver:
  • 8 Answers
That sounds like a sensor problem.to me... its nothing that you'd be able to fix, it will need to go back to the manufacturer/trusted repairer to be fixed. it can cost a huge amount though. a broken sensor normally means the end of a camera's life unfortunately.
Posted on Oct 01, 2009
Why, when turned on, my Stylus 840,shows an LED display that looks like night time with pink and blue colors. If photo is taken, it comes out pink. Why is this? Any suggestions as to why this is do
I'm afraid you have a defective camera. Or the sensor is defect, or the connection to the sensor is not good. (lose, oxidised, broken or lots of other stuff) also the main board can be defect. If also the pictures come out (on the computer) dark and pink, I.m afraid you have to start saving for a new camera.
Make sure the lens is clean and not greasy.
Sep 21, 2014 | Olympus Stylus 840 Digital Camera
My photos come out a pink-violet hue. camera is set on auto.
That is a problem with either old film or poor processing. Unless you're using a filter on your camera lens, colors like that are related to unstable film or poor/contaminated film processing.
May 07, 2014 | Nikon N50 35mm SLR Camera
My kodak easyshare cx7430 camera has pink in my pictures, how do I get that out?
follow this steps and fix it. God bless youVersion:1.0 StartHTML:0000000168 EndHTML:0000003236 StartFragment:0000000502 EndFragment:0000003219
1. The batteries may need replacement. Somedigital cameras continue to function when their battery power is low, but produce grainy photos with incorrect coloration. Make sure you aren't using Ni-Cd rechargeable batteries, which are generally not recommended for cameras.
2. For the best picture quality, make sure the camera is set to its highest resolution. This may have been adjusted by accident. The process for doing this varies greatly among different digital cameras. Keep in mind that fewer photos will fit in the camera's memory and it will probably take longer to transfer them to the computer, at a higher resolution.
3. Digital
photography tends to be more prone to blurring (caused by slight movement of the camera while the photo is taken) than 35mm film, especially with very small or lightweight digital cameras. To remedy this, try using a tripod and/or the camera's timer, if it has one. Adjust the camera's shutter speed if possible.
4. If colors are too pale, using an image editing/viewing program (such as PictureWorks MediaCenter) to increase the Saturation level may be helpful. If the camera has produced colors which are entirely wrong (everything is in shades of black and purple, for example), you can turn the saturation all the way down so that it becomes a black & white photo.
5. The lens may need cleaning. Make sure you use a cleaning material which will not scratch the lens. If possible, refer to its manual for specific cleaning instructions
Jan 30, 2013 | Kodak EasyShare CX7430 Digital Camera
Hi there, I have purchased over 270 fuji finepix xp10 I am having problems with: When i take a photo it looks perfect in LCD when i replay the photo it has pink horizontal lines through the whole...
Have you tried display the photos on another PC? (Or you can try to display the photos to you TV)
If the problem still exists, then the problem is likely to be with your camera.
If the pink line only appears on your PC, then this is likely to be some software/hardware problem of your PC/Monitor.
Mar 01, 2011 | Cameras
Pictures are pink with lines
The camera is a wonderful Kodak product and takes beautiful 8.5 Megapixel photographs. When you save the pictures to an SD card, you must at some point remove them digitally from the card.
Either by linking it to the USB cable and going from there to your PC, OR by removing the SD card from the camera and inserting it into an SD card slot in your computer, printer, or card reader. Occasionally the card readers such as the ones in your PC, printer, or card reader devices do not connect properly and will only transfer part of the data, resulting in pink ugly lined photographs. This problem can be fixed by using the USB cable instead of the built in card readers in your other devices.
Jul 02, 2009 | Kodak EasyShare M853 Digital Camera
Photos are turning out pink and green from my powershot A85
Its is bad ccd imager known problem in Canon A85 camera.
Canon will repair A85 free of cost in ccd imager problem.
Click Canon CCD Imager Advisory for details.
Apr 22, 2009 | Canon PowerShot A85 Digital Camera
Everything's magenta!
Check in your printer driver settings "advanced" section, and see what the presets are. if the RGB or CYMK settings have a slider, see if the magenta is set at 100%. If it has a slider, try it at 90%, 80%, etc until you have a less pinkish hue. You can then create a printer profile which will work with the photo paper you are using.
Different photo papers can cause hues like this.
Also, you can remove pink any unpleasant hues with most photo image editors through color correction.
It's possible that you have a contaminated cartridge...especially if it's a refilled tri-color cartridge.
Dec 09, 2008 | Canon Office Equipment & Supplies
Sony T1 lines/pink photos
This is a CCD sensor fault and it has to be replaced . Fortunately Sony carries out this particular repair under warranty so contact them ( fault is completely a component failure see enclosed pic and lens assambly to understand what I am talking about . The sensor is the small device to the right )0dc6cc8.jpg
Dec 23, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Cameras Logo
51 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
