Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
12.5 hp murray tractor while running started to mis-fire then large puff of smoke out of muffler. wont re-start gas smell in oil all remainder of gas leaked out of tank overnight!
  • 389 Answers
Sounds like you have dirt in your float bowl or your float needle and seat are worn out. Pull off the float bowl and look for contamination, remove the float and see if it is full of gas (it should NOT be) and check the float needle to see if it is grooved, cracked or badly worn. Be sure you change your oil as it has gas in it!!!
Posted on Oct 02, 2009
Oil and smoke shooting from the muffler. Please help!
check the oil to see if it smells like gas if so a carb problem was it stored other than flat?
Jul 07, 2012 | Garden
Helping a Friend
the damage may already be done white/blue is oil smoke i would start it up and let it run it may just be oil in the muffler if not your not going to cause any more damage then what is already done
Apr 21, 2012 | Murray Garden
23 hp b&s leaks oil but also as mowing you can see
well if it runs the carb is okay the smoke is just changes in how the carb loads up most of the time unless its not smoking all the time.and most mowers leak from around the dip stick or the crankshaft seals.hope this helps would be curious as to where the oil is coming from.good luck
Aug 26, 2011 | Husqvarna Garden
I have CraftsmanLT1000 lawn tractor, Smokes heavily.
First check the oil, not only the level but the smell
if its overfull and it smells like gasoline then the problem is that your carb is dirty or the float is sticking and flooding the engine with gas. If the oil is at the correct level then the problem is more likely the valve stem seals, as the engine warms they leak. I presume you have checked the airfilter is clean? The choke is comming off completely when you move the throttle cable? The LT 1000 is the entry level rider in the sears line. The engine usually starts wearing out in about 50 hours use. Remember the sweetness of low price is long forgotten with the bitterness of low quality!
Nov 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Hard starting smokes white like gas is getting into cylinders
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
117 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
