Question about Motorola Mobility KRZR K1m Cellular Phone
I can recieve texts and answer calls but the keys aren't working. when i take the battery out and turns it on, it turns on. but i'm not able to view them and none of the keys work
Cannot send out or recieve calls and texts
try turning off off for a min. or two that always help. call your co. and find out if the tranmitters are working they may be working on something in the area you are at. they can tell you if you have fair, good, or great coverage just by telling them the area ( zip coded) you are in. If all else fails like it my case, request a new phone.
Jan 17, 2012 | Cell Phones
I cant recieve calls or make any calls from my cell phone
Hello:
You need to restore factory settings of your k800i .
your phone default code is 0000, go to setting then select restore setting or factory setting and enter code 0000 .
If this solution is helpful please click a thumbs-up rating below.
good luck .
Feb 03, 2010 | Samsung Cell Phones
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
? auto answer?
1. Messages
2. Settings
3. TXT Auto View
4.a. On (Will display text automatically, no readout)
b. On & Readout (Will display text automatically and read text automatically)
c. Off (When text is recieved, option are given to view text now or later, read out will not happen automatically)
No Problem
Jul 31, 2009 | LG VOYAGER VX10000 Cellular Phone
My phone got wet
ur mobile keypad might got slight damage... since it got wet.... u can go to th authorised service centre for motorola an get ur keypad service.... so that ur prob get solved..... kindly rate me .... thank you....
Jul 01, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Motorolr RAZR v3 screen and key pad went black
No solution really. Apparently it was a malfuction with my phone and so my carrier is replacing it. Whew! Thank you for trying to help.
Apr 08, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Keys wont work
send it back under warrantee. I had the same problem and let them fix it. They'll have a new phone to you in 2 days and they'll save your contacts and put them on your new phone. Let me know how it works out.
Cindy
Jan 30, 2008 | Motorola Mobility RAZR V3
Razr troubleshooting
none of the keys work and key pad is not locked. Recieved phone last night worked fine. Today I can only answer calls and only by flipping phone open.
Nov 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility KRZR K1m Cellular Phone Logo
50 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
