Question about Whirlpool GS6NBEXRS Side by Side Refrigerator
Ice dispensing motor (IDI Motor) inoperative
I have a Whirlpool refrigerator with the Fastfill Dispensor system.
The ice dispenser motor (referred to as the IDI motor in the tech repair manual) has stopped working.
At first, it was intermittent. I suspected some part was freezing since I would wiggle the auger to get the motor to run again. Then, it would run off and on and finally just quit working completely.
Today, I removed the ice bin and plastic piece which covers the top of the drive shaft. Nothing appears to be frozen. While depressing the "door closed" rocker switch and activating the dispenser, the shaft did rotate a few times and then stop.
The "door motor," however, is operating properly.
All indications are leading me to believe a new IDI motor would fix the problem. Since this is an expensive part, I wanted some advice to see if anyone thinks this might be a "core board" or electrical supply, or any other common problem. Thanks!!
  • 1 more comment
  • flyabus Oct 02, 2009
    I already removed the coupling, spring, and shaft. Nothing appeared to be rusted together or frozen. But, thank you for your suggestion.
    I'm wondering how common it is for the IDI motor to fail on these refrigerators. It is only two years old, but we use a lot of ice. And, since the door motor is properly functioning 10 seconds and 1 hour after pressing the ice button, I'm assuming the overall logic is still correct.
  • flyabus Oct 07, 2009
    For anyone reading this thread with the same problem..
    I replaced the IDI motor and the dispenser works like new...
  • flyabus Nov 05, 2009
    Thanks. I don't know if you saw my comment above, but I replaced the ice motor and it works like new. Maybe we'll get more than 2 years out of this one! :)
I had the same problem. GS6NBEXRS00 is 4 years old. Intermittently the ice dispenser would stall. Usually in crush mode, but occasionally stalled in cube mode. A sharp bang on the front of the door or the back of the ice dispenser from inside the freezer would get it working again for a short time. Went through the same steps you did. Replacing ice dispensing motor 2252130 fixed it.
Posted on Nov 05, 2009
This seems to be a common failure. What is happening is the thermistor inside the motor is going bad. $100 fix for a $0.33 part.
Posted on Jun 01, 2010
  • 1 more comment
  • johnny-metro Jul 05, 2010
    @bmathews2
    you can crack it open with a steak knife. if you position the knife on the perimeter seam and knock it with something working your way around the perimeter, it cracks the sonic weld allowing you to get inside. Unfortunately the thermistor (Vishay CM 307C 1170) is nearly impossible to source. I suppose you could fake it with a 250ohm resistor, but that might represent a fire hazard.
    I've seen the 2188860 motor listed as replacement item for the old one, haven't tried it yet, but it is cheaper.
  • johnny-metro Jul 09, 2010
    I received my 2188860 and in my case it is NOT a direct replacement for 2252130. I can shoehorn it in, but don't recommend this approach. Worse than that, even though it is made by a different supplier, it appears to contain the same circuit board with the faulty thermistor. :/
  • Tyson Fish Mar 08, 2012
    I had the same problem. It turned out that the thermistor was fine, but a solder joint on it was bad. I re-soldered and the motor works good as new. No money spent!
    Thanks for the post!
  • 30 Answers
Second auger motor on my Whirlpool too. Must be a poor design, or need a beefier motor.
Posted on Dec 19, 2010
Johnny-metro: This part (#2252130) has just gone bad on my Kenmore Elite for the second time in 3 years (fridge was new in 2007)! How did you know what was going wrong inside the motor? The ones I have seen have sealed cases and don't come apart for inspection. I'd sure like to be able to break the cycle of planned obsolescence on this part!
  • Whirlpool Master
  • 1,606 Answers
Remove the ice bucket . Remove the 2 screws , holding the coupler on , on the door itself . Also remove the long shaft . The coupling is probably rusted onto the shaft . Remove the coupling , possibly with hot water or by tapping on a wrench , below the coupling on the shaft . When removed , a spring will come out also . Clean the shaft where the coupling goes , and put a light coat of grease or oil on it , so that the spring can push the coupling freely . Reinstall shaft , spring , and coupling .
Posted on Oct 02, 2009
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
Door Ice Dispenser not dispensing Ice
Jeff; I would start by taking the ice bucket out and totally defrosting it! Sometimes water will freeze holding the auger in place and a simple defrost will cure that problem.
Hope this helps!
Hal aka ImJustAvg
Jan 08, 2012 | Whirlpool Refrigerators
Water dispenser quit.ice maker works fine you can hear motor hum when pressing water dispenser button
You should not hear the noise of a motor unless you are trying to dispense ice. Is that the case your ice dispensor is not working?
Sep 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice dispenser not working on whirlpool side by side.
Andy_hall800, we're sorry to learn of your experience with the ice maker on your Refrigerator. We apologize, but we wouldn't be able to provide you with any technical assistance due to we aren't certified Technicians. We recommend service.
Oct 24, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Dispenser not dispensing ice
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
Oct 31, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
My ice maker stopped making ice all the sudden. there is no water in the ice maker
do you have a water dispensor in the door? if you aren't getting water check the filter. if the water line is not clogged you may have a bad water fill valve or the motor/gear in the ice maker is bad.
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side model # ed25uexhw00
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
Sep 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore side by side icemaker
Your product is an IDI (In Door Ice the bucket is in the door) or a Non-IDI? By the way, you mention the Ice maker. The thing is that if the ice maker is not runnning then you don't have ice to dispense and obviously the fact that the motor is working or not is irrelevant. So that's why I suppose that the problem is not the ice maker but the trajectory of the cubes from the bucket to outside of the door.
In the Non-IDI sometimes it happens that the safes in the bucket jump the locks were the bucket resides so the auger motor (the one that move the shaft so you get the Ice) is still running but you can't get ice because the bucket is not in the right position. Just try to relocate the bucket.
You can see if the motor is moving the shaft pressing the light switch that is at the top of the freezer. Then dispense, when you press the switch the main board thinks that the door is closed so you can dispense and see if the motor is moving the shaft.
Other failure mode is the flapper door, it depends if the dispenser works with full electronics or if it's an electromechanical dispenser. Full electronics dispenser use a stepper motor to move the flapper door so the failure is that when you press the pad and the flapper door is closing, if you press it again then it get stucked, the motor dispense but the flapper door is closed. With electromechanical dispenser, maybe is the dashpot mechanism.
If any of these solutions couldn't fix your problem please tell me. I think that I can solve this particular problem.
Feb 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Need to change the ice dispenser motor. How do I get to it?
if alllyou have ot change is the dispensor motor, not aproblem at all, the acess to teh motor cavity is located under 2 screws above the lower freezer door shelf, remove the 2 scres and youll find four more screwsholding in the motor , take all of 5 min, no chance of wrecking anything else, its the only thong on the compartment
Nov 09, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice dispenser motor not working
try removing the ice bin from unit, try using dispensor now, can you hear it turning now??? if so empty your ice bucket possible frozen water on bottom of bucket preventing auger from turning
Feb 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6NBEXRS Side by Side Refrigerator Logo
1,329 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
