Question about Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228
I have three wires to connect to the emerson 1081 pump. My wires are 1. Blue, 2. Purple, 3. Green .... Which wires (color) to I connect to on the pump??
    President:
  • Emerson Master
  • 1,378 Answers
Is green your ground wire? Assuming it is put it on the ground post and the other two go to the line connections as shown on the motor. If it is a dual voltage motor, be sure you set the motor selector to be the same as the line voltage you are supplying the unit.
Posted on Oct 02, 2009
Emerson 1081 1563
Electricity is "Color Blind" it does not care what color wire is used!
3 wires normally is a single speed motor, where 4 wires would indicate a 2 speed motor.
Now, if you had someone connect the motor with NO ground, I guess you would have a very unsafe 2 speed motor wiring setup???
It would be very difficult to assist you without actually seeing the application.
But I will presume you also have a "Green" wire since you stated: "More than 3 connections"
  • Green wire is normally/usually Ground. Ground wire is always securely mounted to the casing of the motor with a green screw.
  • White wire is usually a Common/Neutral. Neutral wire will go onto the Common position or sometimes it is labeled as Line1/L1/LN1
  • Black wire is usually a Speed wire. On a 1 speed motor, Black wire is a Line wire. A Line/Hot wire is connected to Line2/L2/LN2 position
  • Red wire is usually an indication that there is an additional speed so therefor an additional Line/Hot wire is required. An additional Hot/Line wire will "Alternate" with the other Hot/Line wire. or "SeeSaw/TeeterTotter" between the 2 hot lines.
    • These type of motors will have a label indicating where the Line/Hot wires will go and will be labeled as "High/H or Low/L"
    • You will need to know, and only you will be able to know this, or any technician at your site, will be able to know. No one will be absolutely able to tell you which wire is High Speed or which wire is Low Speed. e.g. "Red wire is Low Speed" is something you will not hear from me or any other person assisting. We would be able to tell you that normally this brand/manufacturer of spa uses the red wire for Low Speed, but that may not be the case for you!
  • But if you have a red wire, and a black wire, and there is definitely a green wire, then your red & black wires are Line/Hot wires and is possibly a 2 speed pump motor and they will be placed on the High & Low positions. White will be common and the green will be attached to motor casing - Usually!
  • Remember, electricity does not care what color wires are used! So, if somebody who did not know what they were doing, re-wired something down the road and/or did not know "Usual" colors for identification purposes then Color of wire is of no use.
Good Luck
Sep 03, 2014 | Pool & Spa
Vga wiring i want to know what each coler wire represents so i wont burn my pc wiring my stuff into it
Here's some wiring diagrams:
First according to pin: http://hot-flash-games.com/web/vga%20cable%20pin%20connection-2875.html
And in this post you have pinouts according to standard color: http://www.diyaudio.com/forums/diy-projectors/30458-vga-pinout-wire-colors.html
db15 male
1)brown
2)red
3)orange
4)salmon
5)yellow
6)dark green
7)light green
8)dark blue
9)NC
10)light blue
11) purple
12)grey
13)white
14)black
15)brown/black
DB15 Female
7)light green
2)red
11)purple
13)white
1)brown
6)darkgreen
8)dark blue
10)light blue
3)orange
that's all oh yes you also have a ground wire from connector base to connector base.
Hope this helps. So from these two, you should be able to figure out witch wire is witch. Let me know if you need more detailed information.
May 03, 2011 | VIA ASUS A8V-E Deluxe K8T890 chipset...
Breaker keeps tripping when turning on pump.
The red and black wires if ran correctly are the load lines(power). The white is neutral or ground. If its a 1/2 to1-1/2 hp motor connect the red and black wires to terminals #1 and #4. If its 2 hp use #1 and #4. If its 3 hp use #2 and #4. Connect the white wire to the green colored screw. A grounding conductor should always be connected under the green grounding screw, which is located within the terminal compartment of the motor. You can check the breaker for the wire colors, one should be black and the other red. The white wire should be terminated to the neutral/ground bar in the can.
May 16, 2010 | AO Smith 1 HP 115/230V 56C Replacement...
Wiring diagram, sony cdx 3100 car cd player
Pin Number Wire Color Description
1 White Left front +
2 Green Left rear +
3 Purple Right rear +
4 Gray Right front +
5 Blue/white AMP Remote
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
9 White/black Left front -
10 Green/black Left rear -
11 Purple/black Right rear -
12 Bray/black Right front -
13 Sky blue ATT
14
15 Orange/white Illumination
Feb 24, 2010 | Car Audio & Video
Sony cd player, CDX-3100 wiring diagram
This is the pinout shown on the Sony website for the CDX series players. Pin numbering is as follows:
1 2 3 4 5 6 7 8
9 10 11 12 13 14 15 16
This is looking at the connector with the wires towards you.
2 Green Left rear +
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
13 Sky blue ATT
14
16 Yellow Battery
Feb 24, 2010 | Sony Car Audio & Video
I need to know where the wires comming out of the plug go to?? wiring diagram. thank you sony cdx-3100
1 2 3 4 5 6 7 8
2 Green Left rear +
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
13 Sky blue ATT
14
16 Yellow Battery
Jan 05, 2010 | Sony CDX-3100 CD Changer
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228 Logo
412 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Mike Squire
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
