Question about Dell Computers & Internet
I want to attach my St2310 monitor to a support
I want to attach my Dell St2310 monitor to a support arm rather than it's stand. It does not have VESA attachment points however there appears to be heaps of room between the outer case and the monitor components. Would there be any unforseen issues with having someone attach the monitor using appropriate fasteners?
There is a Bracket for sell on ebay the item nubeItem number: 200519763403
Item number: 200519763403The item number is: 200519763403
Posted on Sep 17, 2010
Fix pedestal for samsung 740BF
you can buy a wall mount for under 12 bucks. Or alternately you can buy an VESA 100 mm compatible stand for about 30 bucks
There're are out there lots of solutions for LCD, arms for mounting in desk, wall or poles.
Mar 22, 2014 | Samsung Computers & Internet
Dell ST2310 goes blank
Change the settings to "always on" (both of the monitor and the computer).
Dec 08, 2013 | Dell ST2310 23 inch Monitor
The stand of my E173FPs monitor is broken. What can I do?
Sorry to hear that the stand had broken on your monitor.
many times there is a mounting in the center of the monitor back that accepts a standard 4 screw mounting, which almost any brand monitor will fit on, many of these type stands will adjust in height and also sometimes rotate to a portrait if you should like to read documents with the narrow side to the top.rotated 90 deg. some monitors do not have this option the mount is called (VESA mounting holes, 100mm (Behind attached base plate) but eBay is a great course for this type of part. I should have one of the Dell original mounts in my older parts area. but i see (Problem with Dell E197FP LCD Monitor) and (E173FPs) both in this unsolved problems, and knot knowing exactly the broken area, not sure of all you need to repair the broken area in question. Sprint6@zoominternet.net for personal help with this unit.
Dec 03, 2013 | Dell E197FP LCD Monitor
Dell st2310
power supplyboard overheated!
Nov 28, 2013 | Dell ST2310 23 inch Monitor
My dell ST2310 monitor is not enough bright even though setting up 100 for brightness level. Except that, it is working well. What is the problem?
That means one of the capacitors in the monitors' board is damaged.
This will be evidenced by a capacitor that is bulged or its leaking on the monitor's motherboard. You need to open up the monitor. If you do not know how to do that, then you must find a technician to do that for you. Then after you open it, check carefully on the power board of the monitor and look for a capacitor or capacitor that has a bulged head or its leaking. Now you have to replace the capacitor. This can be done well by a technician. Make sure that the capacitor being replaced, is of the same number rating as the one being removed, and make sure that it is replaced in the right position
Sep 09, 2013 | Dell ST2310 23 inch Monitor
My lcd works fine untill i flip upside down
There is may be a problem with your power cable. You need to fix it properly.
Jul 23, 2013 | Dell ST2310 23 inch LCD Monitor
How do I remove the base from the TV so it can be wall mounted without leaving the stand attachment attached to the TV
depends on what TV you have. Most TV models i've dealt with, you need to remove the whole back of the TV and take the base out. Some smaller LCD monitor bases like Dells are attached only by a latch. Some bases are held together by 4 screws where the VESA mount would go.
Mar 22, 2011 | Computers & Internet
Monitor stand
I have one or two nice used Original ones available.
Where are you located ?
email bammbamm@ptd.net if you want pictures and costs
Mar 05, 2009 | Acer AL2017 20" LCD Monitor
Cannot find VESA holes...Samsung Syncmaster 970p
I have looked at the specification for this, and although it does show as being VESA compatible (This is a display standard) There is no mention of any "wall mounting" capabilities at all, which would lead me to believe that this is not designed to be put on a mount. also the "Magic Rotation" Technology which is part of this device may rely on it using the proprietory stand, it may well be possible to remove the stand however, but it would require some significant dissasembly as the power connector is on the signal box, and this would need to be seperated from the stand itself. The mounting bolts look to be hidden behind the round pivot cover on the back, and it may be possible to see if mounting is possible simply by removing this, however I would seek information from the manufacturer about this as removing any of the covers would most likely invalidate your warranty, it is possible that this was missold to you and you should be able to take it back as not being fit for purpose.
Sep 15, 2007 | Samsung SyncMaster 970P 19" LCD Monitor
Computers & Internet Logo
690 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
